Removed 5th Wheel What to do about holes?
Discussion in '2nd Gen Tundras (2007-2013)' started by SnowB0und, Apr 6, 2020.
  1. Apr 6, 2020 at 1:30 PM
    SnowB0und
    SnowB0und [OP] New Member
    2013 SR5
    Hello, I'm looking for ideas on what to do with the holes left behind from a 5th wheel hitch I removed. It came on the truck when I bought it. I'm planning on ditching the plastic liner and getting Line-X applied, but feel like I need to do something with the holes first.
  2. Apr 6, 2020 at 1:33 PM
    timsp8
    NY
    Wouldn’t the line x fill in the holes?
  3. Apr 6, 2020 at 1:36 PM
    SnowB0und
    2013 SR5
    They are about 1/2" diameter, I was thinking of maybe getting a D ring to bolt in there to use to strap stuff down. I just figured there might be some creative ideas.
  4. Apr 6, 2020 at 1:37 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    You could have some material welded over the holes.
    TheBeast likes this.
  5. Apr 6, 2020 at 1:45 PM
    TheBeast The Beach
    weld, sand and have line x applied.
    WNY PAT and 15whtrd like this.
  6. Apr 6, 2020 at 1:50 PM
    SnowB0und
    2013 SR5
    That seems to be the best way to fix it. I was just worried about it rusting underneath because the heat burning off all the corrosion protection. I could hit it after with some spray paint.
    I might see If I can get a body shop to do it, I'm not sure of my abilities with that thin of metal.
  7. Apr 6, 2020 at 1:55 PM
    15whtrd
    15whtrd Mr. Blonde
    I would want them welded up. Then get underneath the truck and sand it prime and paint. Obviously do the same to the top side. Otherwise your D ring idea could be cool.
  8. Apr 6, 2020 at 2:32 PM
    Stainless steel flat bolt with rubber washers on each side and a nylon lined nut then spray with bed liner.
  9. Apr 7, 2020 at 2:23 PM
    el_taco
    el_taco New Member
    Tundy for 5th wheel....nice
    mrmachinist likes this.
  10. Apr 7, 2020 at 3:42 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    My '07 had some sort of farm implement / device mounted in the bed by a previous owner, several holes were drilled through the bed mat & bed. There was a little surface rust under the mat, and it was filthy. The Line-X dealer told me that they used a thick metallic tape of some kind to seal the holes from the top before spraying. I'm not exactly sure what they did, but as you can see the underside is in great shape.
  11. Apr 7, 2020 at 3:47 PM
    55kcement
    55kcement New Member
    Troy
    Sonora ca
    2020 TRD Off Road limited Double cab
    Currently none
    Weld up and reseal the LineX .
  12. Apr 7, 2020 at 4:40 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    If your not a welder guy, how about some bumper bolts to fill then holes then apply bed liner
    I’m betting you’ll need 3/4 shank and 3” long.
    SnowB0und[OP] likes this.
  13. Apr 7, 2020 at 6:59 PM
    55kcement
    Troy
    Sonora ca
    Currently none
    That is a perfect diy way to go ! Good thinking.
  14. Apr 7, 2020 at 9:05 PM
    SnowB0und
    2013 SR5
    Thanks for all the advice. It looked brand new when I got the truck, I'm betting they didn't like how it towed the 5th wheel and traded it in.
  15. Apr 7, 2020 at 9:07 PM
    SnowB0und
    2013 SR5
    How did it look after you got the Line-X applied, could you see the holes? I'll call them and see what they want, I didn't even think of that.
  16. Apr 8, 2020 at 4:34 AM
    Rex Kramer
    Georgia
    It looks great, and I can't tell the holes were ever there.
    SnowB0und[QUOTED][OP] likes this.
  17. Apr 8, 2020 at 8:10 AM
    tnbndr
    tnbndr New Member
    New Berlin, WI
    2012 White Rock Warrior CrewMax
    I saw a post somewhere that there is a replacement bed bottom sold, kind of like a sheet of metal siding. You could do something along that lines.
