Remove Wiper Arms
Discussion in '2nd Gen Tundras (2007-2013)' started by TXTundraFan, Jul 23, 2020.
  1. Jul 23, 2020 at 6:57 PM
    TXTundraFan
    TXTundraFan [OP] New Member
    How do you remove the wiper arms on a 2010 Tundra? I need to repaint them as both have faded spots. I also need to repaint the bolts that hold them on. I can remove the bolts just fine, but the wiper arms will not come off the bolt they are on.
  2. Jul 23, 2020 at 7:17 PM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    I haven’t removed them on this truck but usually they are splined and press on. Once the nut is removed a good pull will get them off. Might want to loosely thread the nut back on to avoid hitting yourself in the head when the arm pops off!
    TheBeast likes this.
  3. Jul 23, 2020 at 7:38 PM
    TheBeast The Beach
    I removed them to install the ditch lights brackets iirc or it might have been for something else but yeah, try to wiggle them and pull them out. I marked their position before I removed them.
  4. Jul 23, 2020 at 10:03 PM
    TechWrench
    TechWrench New Member
    Gary
    Hawley, PA
    '08 Tundra White, DC SR5 5.7, TRD Off Road Pkg
    Toyota Bedliner, Under Cover Bed cover, Oem back-up camera system.
    Once you remove the nut that locks the arm on the post, try using a small two jaw puller (like a battery clamp puller) to remove the arm from the post.
