removal of the grill insert
Discussion in 'General Tundra Discussion' started by Motor71, Jan 22, 2017.
  1. Jan 22, 2017 at 7:04 AM
    Motor71
    Motor71 [OP] teufel hunden
    Rob
    New Jersey
    2016 tundra platinum
    TRD sway bar, matching mirror cover, 20% tint, esp aluminum box, Line-X premium, Undercover Flex tonneau cover, led interior lights, winjet smoked tail lights. Road armor rear bumper w/ road armor shackles, go rhino front bumper.
    anyone has a picture of the grill insert removed? mainly the 13 little tabs or how to get them out? I been trying to pop off the 13 tabs but none of them would budge and i don't feel like breaking any of them. Any advice would help; such as, which way to push the tabs or pic of the inserts already popped off would help, tia!
    Pigglet222 likes this.
  2. Jan 22, 2017 at 7:34 AM
    Motor71
    Rob
    New Jersey
    Thanks dude, maybe I'll wait til spring then...20170122_103206.jpg 20170122_103214.jpg
    Backslider and NewImprovedRon like this.
  3. Jan 22, 2017 at 7:49 AM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
  4. Jan 22, 2017 at 7:50 AM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    The above picture will be your insert out.
  5. Jan 22, 2017 at 7:51 AM
    Motor71
    Rob
    New Jersey
    It just seems the center clip barely fits back in the slit, since the slit seems so tight. I'll try the cloth method too. Btw why did you take off your insert? I'm thinking about either painting it black or plasti dipped it
  6. Jan 22, 2017 at 7:55 AM
    Motor71
    Rob
    New Jersey
    Thanks, but I need a pic of the back if anyone has it
  7. Jan 22, 2017 at 8:22 AM
    Achuop
    Achuop Stormtrooper 5.7
    Anthony
    Orange County, CA
    2015 Tundra Crew Max TRD 4x4
    TRD Pro grill, Magna Flow Exhaust, 3/2 leveling kit, TRD sway bar, black out emblems, Bakflip G2 cover, 20” ProComp wheels and Tires and lots of love and affection.
    If it's cold where you are at, apply a little heat to it with a blow dryer. It should help a lot. Like everyone has said, once you get it started it will go by quick.
    Motor71[OP] likes this.
  8. Jan 22, 2017 at 9:03 AM
    Motor71
    Rob
    New Jersey
    Thanks, maybe I'll just bring it inside and find a good excuse as to why the grill is on the dining room table...
  9. Jan 22, 2017 at 9:30 AM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    Those are are a make or break deal I'm sure. I tried the same thing then just cut the center out and mounted my new grill insert. Easy peasy.
  10. Jan 22, 2017 at 10:05 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Make sure you remove the screws first. And just be really patient and loosen each one little by little until it pops off. If you break a couple of tabs, it's not that big a deal, just don't go breaking all of them. The screws will get it back on tight.
  11. Jan 22, 2017 at 10:10 AM
    Motor71
    Rob
    New Jersey
    thanks! This patience thing everyone is talking about is what I lack in....
  12. Jan 22, 2017 at 10:12 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yeah, me too. I ran out of it and just yanked it and broke a couple. The bad thing is, the tabs break on the surround, not on the grille.
  13. Jan 22, 2017 at 10:14 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I wonder if you can shove in a flat piece of something in each one. Maybe like a paper clip or something even thinner. Then pull. That would probably help.
    SouthBoundSteve and Motor71[OP] like this.
  14. Jan 22, 2017 at 10:20 AM
    Motor71
    Rob
    New Jersey
    Never send a marine to do anything that requires patience...here's the first two victim20170122_131831.jpg
  15. Jan 22, 2017 at 10:20 AM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    I found getting the first one out was always the hardest (which I broke) ... work from one side to the other, not from the middle out and just like Joon said ... make sure you remove the screws first.
    SouthBoundSteve likes this.
  16. Jan 22, 2017 at 10:21 AM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    Those things were a real pain in the ass when I did mine for sure
  17. Jan 22, 2017 at 10:21 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  18. Jan 22, 2017 at 10:34 AM
    Motor71
    Rob
    New Jersey
    Lol, after the first 2 I just said f*** it, I already got the pro grille on and I was just looking to paint this one, but now maybe I'll put an after market insert in where they break off all the tabs anyway
    NewImprovedRon likes this.
  19. Jan 22, 2017 at 10:36 AM
    Motor71
    Rob
    New Jersey
    Yea they don't send the Marines in unless they want something killed or destroyed
  20. Oct 3, 2017 at 7:19 PM
    Mehoff
    Mehoff New Member
    They are definitely only made to go one direction. When you are removing the center section something is going to break: either the tab on the surround or the small plastic knob on the grill insert. I think the latter is something most people miss/don't realize when messing with these things.
    I just spent an hour trying to preserve both pieces, meticulously working through it and the above was my result. The knowledge I gained was:
    Start at the far sides, using a screw driver as a wedge for the two side tabs and then pull. It requires much more force than I had anticipated, so prepare yourself for a good tug (even pressure, slowly adding force. Don't just yank).
    Once those are out, work towards the center using the same method. The four tabs in the dead center are much more robust than the others, so you can just wank those.
    When all is said and done, as mentioned before, something will be broken at each tab location. It will be the tab itself or the little plastic knob below. If the grill insert is more important, sacrifice the tabs. If the surround is more important, sacrifice the little knobs by pushing them off with a screw driver slid in behind the tab.
  21. Oct 4, 2017 at 3:29 PM
    geno0506
    geno0506 New Member
    Michael
    MERCA!
  22. Nov 12, 2018 at 8:09 PM
    Pigglet222
    Pigglet222 New Member
    Did you use heat (hair dryer) to get 'er done?
  23. Nov 12, 2018 at 8:32 PM
    Pigglet222
