Remote starter question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sylvirdog, Jun 20, 2024.
  1. Jun 20, 2024 at 4:06 PM
    Sylvirdog
    Sylvirdog [OP] New Member
    2018 Toyota Tundra
    So I just got off the phone with Toyota dealership and they told me putting a remote start in my 2018 Toyota Tundra he strongly advised me not to do it. Cuz he said something about it has a tendency to throw the truck into limp mode and it won't work properly has anybody ran across this issue
  2. Jun 20, 2024 at 4:19 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Nope. First I’ve heard about it
  3. Jun 20, 2024 at 4:32 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Nope, I put 12volt solutions ones in my 17 tundra and 21 rav4, zero issues after several years.
  4. Jun 20, 2024 at 4:38 PM
    BoyHowdy
    BoyHowdy New Member
    2021 Tundra
    Unless I am mistaken the key fob for your year should remote start it by doing three clicks on the lock button with the last click you hold until you see the lights flash. The range isn’t as good as some aftermarket systems but it works well enough. It will kill the engine when unlocking/entering the vehicle but it’s free.
  5. Jun 20, 2024 at 4:39 PM
    Kurt1011
    Kurt1011 New Member
    Kurt
    2013 rock warrior
    I put 12volt solutions on my '13 rock warrior five years ago and it has worked great- no issues.
  6. Jun 20, 2024 at 4:47 PM
    Sylvirdog
    2018 Toyota Tundra
    I just tried that clicking the lock button and holding it on the third time I heard the three beeps it didn't work it was worth a shot
  7. Jun 20, 2024 at 4:56 PM
    BoyHowdy
    BoyHowdy New Member
    2021 Tundra
    I’m sorry, for some reason I thought ‘18s did this as well. The 12volt solutions will probably be a good choice in that case then.
  8. Jun 20, 2024 at 6:11 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I put the 12 volt solutions in my 2019 and love it, no problems and pretty straightforward install with good directions.
  9. Jun 20, 2024 at 6:16 PM
    Sylvirdog
    2018 Toyota Tundra
    Thanks for all the info I actually just purchased that system the 12 volt solution thing. I hope all goes well.
    Joe333x and BoyHowdy like this.
  10. Jun 23, 2024 at 2:09 PM
    Islander
    Islander New Member
    2008 white crewmax
    Had a remote starter switch on my 2008 CM. Apparently installers like to use a low amp wire for convenience when installing. This intern can and dies cause problems. When the event happened the truck was 120 miles/ 200 km from a reliable repair shop. The truck gave a 'hot trans' wafning light. Shut it down for 45 min, tried again, no start.. nothing. Towdd to a toyota dealer. Long story short, fire in a wiring loom. New starter, new wiring, new battery... 4K$ covered by insurance. I now don't have RS.
  11. Jun 23, 2024 at 6:05 PM
    BushBandit
    BushBandit New Member
    2021 Tundra Limited TRD
    I went with 12 volt solutions on the wife's car. Easy install and has worked great
