Remote Starter and TPMS
Discussion in 'Electrical' started by MRWOODMIN, Jan 31, 2025.
  1. Jan 31, 2025 at 4:51 PM
    MRWOODMIN
    MRWOODMIN [OP] Mrwoodmin
    Tony
    Vermont
    2019 Tundra limited
    REMOTE START
    Hi All,
    New here, just got my first Tundra after many Tacomas. So my 2019 Tundra Limited had what I assume was a factory remote starter as it worked with my Toyota key FOB, this is a key start truck not a push button. So I had the Toyota unit removed and a Compustar remote start installed in its place at a factory authorized Compustar dealer. All works perfect with the exception that none of the TPSM sensors are reading know so the TPMS light on the dash is always is always on, very annoying. I tried the reset on the dash. I am currently in debate with the installed if there needed to be a splice for the TPMS. Does anyone know the answer??
    Thank you in advance.
  2. Feb 9, 2025 at 6:34 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    I would check the wiring. Look at your tpms module on the passenger side, see if it is tapped into from the compustar system. Did the installer use a T-harness for the compustar install?
