Remote Starter - 12 Volt Solutions ...
Discussion in 'General Tundra Discussion' started by Bob S, Oct 20, 2018.
  1. Oct 20, 2018 at 12:06 PM
    Bob S
    Bob S [OP] New Member
    Bob
    2018 Vintage Brown Toyota Tundra
    Shorty Antenna; Weathertech Ventvisors, 12 Volt Solutions Remote Starter
    Just finished the install of the 12 Volt Solutions Remote Start on my 2018 Tundra ... ! Works but, I cannot unlock the truck with the remote ...
    I can start the truck but I have to unlock the door with my key! I have done the programing a few times read: 5 or 6, but, it does no good.
    Can anyone help before I call the company on Monday ... ?
    Bob S
  2. Oct 21, 2018 at 4:25 PM
    Sharpienads
    Sharpienads New Member
    2018 Tundra SR5 TRD O/R
    Sorry bud. I ordered a remote start from them that should be here tomorrow. I'm no help, but let us know if/when you figure it out.
  3. Oct 21, 2018 at 5:47 PM
    Kevin1741
    Kevin1741 New Member
    I installed the same unit. It is nice being plug and play but the range is limited to the factory remote range. If i had to do it over, i would go aftermarket
  4. Oct 23, 2018 at 10:56 AM
    Bob S
    Bob
    Found the problem "operator timing and headspace" ... I was using the wrong socket for the TPMS Interrupt Harness ... everything works fine now ... 5-Star product and customer service ...!
    Bob S
  5. Oct 27, 2018 at 8:18 PM
    pitts101
    pitts101 New Member
    2016 TRD Pro
    Does the truck shut off when you open the door?
  6. Oct 27, 2018 at 8:19 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Glad you got it figured out!
  7. Oct 27, 2018 at 9:00 PM
    Sharpienads
    Just installed my system. Pretty straight forward. So far works great! I like not having an extra fob even if the range is less.
    Fishman57 likes this.
  8. Oct 27, 2018 at 9:03 PM
    Sharpienads
    No. The truck will only turn off if you press the lock button three times after you remote start it, let it time out (15 minutes), or press on the brake before you turn the key on.
    MotoTundra and pitts101[QUOTED] like this.
  9. Oct 27, 2018 at 9:14 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Any links on where to buy this system
  10. Oct 27, 2018 at 9:16 PM
    Sharpienads
    SWIPE and blue16[QUOTED] like this.
  11. Oct 27, 2018 at 9:18 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
  12. Oct 27, 2018 at 9:19 PM
    Sharpienads
    I installed one of their systems on my F150 and it was flawless. As far as plug and play systems go while using your original key fob go their products are excellent. Granted, I haven't used other systems, so I can't compare.
  13. Oct 27, 2018 at 9:21 PM
    Sharpienads
    No problem bud. If you add an item to your cart but don't check out, they'll send you a 10% off coupon. I think you have to create an account with them first though.
    ETA: it might take a day or two but you'll get an email.
    SWIPE, blue16[QUOTED] and MotoTundra like this.
  14. Oct 27, 2018 at 10:04 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    that's Awesome Thanks again
  15. Oct 27, 2018 at 10:35 PM
    Mikekoot
    Mikekoot New Member
    Canadia
    2018 MGM tundra sr5 DC /2014 SSM Toyota Tacoma sr5 DCLB
    Is this worth the 150$ more over the Fortin Evo? Also, what's the max range?
  16. Oct 28, 2018 at 4:51 AM
    Berettafan
    Berettafan New Member
    2017 CM
    Hmm is this only for 2018 and newer?
  17. Oct 28, 2018 at 5:05 AM
    Scpringle
    Scpringle New Member
    Jackson MS
    2015 red Tundra double cab 4.6 L 4x2
    running boards , TRD sway bar and tundra 08 SR5 wheels. FRACmod, pop&lock and backup sensors installed .
    just fill out the year, make and model info and they do have more years available .
  18. Oct 28, 2018 at 5:35 AM
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
    Mine works great so far. 2015 my stock remote goes pretty far.
  19. Oct 28, 2018 at 3:04 PM
    Bob S
    Bob
    Absolutely ... the system is, now, true plug and play ... no wires to cut in the truck ... the range is the same as your original key-fob ... works for me ... and, I'm too cheap to add the cell-phone app ...
    Mikekoot[QUOTED] likes this.
  20. Oct 28, 2018 at 4:58 PM
    hi_rawb
    hi_rawb New Member
    rob
    Bay Area
    2018 CM TRD SPORT 4x4
    2018 Trd Sport
    Had mine for about a good 6 months now! Couldn’t be any happier! I was kinda hesitant to install myself, but I watched the YouTube video for about 2 weeks and BAM did it myself.. Much props to @12voltsolutions!!
  21. Oct 28, 2018 at 5:02 PM
    hi_rawb
    hi_rawb New Member
    rob
    Bay Area
    2018 Trd Sport
    21EDD020-C6F1-426D-A2EE-5F3800764D3C.jpg ...and the app is a good to go too!
  22. Oct 28, 2018 at 5:44 PM
    TundraLuv
    TundraLuv New Member
    Kent
    IA
    2018 Midnight Black Metallic Limited Crewmax
    Does this tie up your OBD connector?
  23. Oct 28, 2018 at 6:18 PM
    Tiamat
    Tiamat New Member
    No, i did emissions 5 days after I installed it. No issues with obd
  24. Nov 5, 2018 at 6:05 AM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    I just put one in yesterday. It was really simple to do. The hardest part was removing the necessary panels from the truck, which wasn't bad.
    Range is that of the h-key fob. I think that's enough but if I decide that I want a longer range later, I'll invest the $199 and get the Smart Phone add-on module.
    Mikekoot likes this.
  25. Nov 5, 2018 at 6:09 AM
    Tiamat
    Tiamat New Member
    200.00 for a phone app and module is just too much
  26. Dec 12, 2018 at 7:54 PM
    MisterTundra
    MisterTundra New Member
    MGM CM
    You said there are no wires to cut, but the YouTube video for the 2018 tundra shows the installer cutting the TPMS wire and installing the TPMS interrupt cable.
    I’m confused!
  27. Dec 12, 2018 at 8:40 PM
    MisterTundra
    MGM CM
    Nevermind, just found out they now include a T- Harness that connects to the TPMS interrupt cable.
  28. Dec 13, 2018 at 12:56 AM
    CMENT_GREATNESS_4x4
    CMENT_GREATNESS_4x4 New Member
    Rob
    San Antonio TX
    2018 Cement TRD 4x4 Offroad Tundra
    Husky Weatherbeaters, Driver side grab handle, Nox-Lux kit... so far
    Yup, Just installed this one with the added T-Harness for the TPMS interrupt last week on my 18 Tundra and the system works great. Had it done in about an hour and 30 min from tear down to clean up with watching the video in between. I also installed a second on for my wife's 4runner and that was a bit more tedious. Not super hard just smaller to work in and the 4runner one I had to tap into 2 wires. Between both the Tundra was by far the easiest to install and feels great that I did not splice into anything.
  29. Dec 13, 2018 at 5:44 AM
    MisterTundra
    MGM CM
    Thanks! Can’t wait to install it!
  30. Dec 15, 2018 at 1:41 PM
    MisterTundra
    MGM CM
    Man, I may have installed it wrong. When I press the lock buttons three times (H-Key), the car starts up, but the factory alarm(horn) goes on until I press unlock. Any ideas why this is happening?
    2018 Tundra (platinum)
