Remote start
Discussion in '3rd Gen Tundras (2022+)' started by murray01, Oct 22, 2024.
  1. Oct 22, 2024 at 8:22 AM
    murray01
    murray01 [OP] New Member
    Murray
    2024 Tundra Platinum 1794 Crewmax
    none
    I thought that Toyota corrected the issue in 2024 . When I have my truck started in remote, I open the door and the truck shuts off , is there and override for this ? Or do we live with it ?
  2. Oct 22, 2024 at 8:32 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    do a search, asked and answered
    Breathing Borla likes this.
  3. Oct 22, 2024 at 8:43 AM
    Tundra341
    Tundra341 New Member
    They updated it for the 2024 tacomas with TSS 3.0, even the 2025 tundras still have TSS 2.5 and haven't been updated. Just gotta live with it.
    Zudrick likes this.
  4. Oct 22, 2024 at 10:21 AM
    murray01
    Murray
    none
    Thank you for the info
    Tundrastruck91 likes this.
  5. Oct 25, 2024 at 9:28 AM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    In the minority, as don't feel it's a big deal ...now, if I had to turn a key and risk a wrist injury, that's a whole different jar of pickles.
  6. Nov 1, 2024 at 8:56 PM
    Polo08816
    Polo08816 New Member
    2014 BMW 335i
    So not fixed for 2025… disappointing.
  7. Nov 1, 2024 at 9:13 PM
    CrayCray
    CrayCray New Member
    WA State
    2024 Platinum 6.5
    How do you do remote start? I tried to do it the other day with the key but probably didn’t do it right. Clicked three times and nothing happened.:confused:
  8. Nov 1, 2024 at 9:28 PM
    Jer
    Jer New Member
    Jeremy
    2024 supersonic red TRD sport
    It’s not just pressing the button 3 times, you have to see the lights flash each time, keeping it pressed on the third, or it won’t work, and it needs to be fairly quickly between clicks, also holding it the third time until the lights start flashing. It’s finicky but does work.
  9. Dec 30, 2024 at 2:16 PM
    Jer
    Jer New Member
    Jeremy
    I need to correct myself here, I tried it just three times quickly holding it on the third and it worked fine, so you don’t need to see the lights flash each time you press the button, my bad.
  10. Dec 30, 2024 at 5:02 PM
    Gonefishingdave
    Gonefishingdave New Member
    Dave
    Central New York
    2024 MGM Tundra TRD OR Limited
    Bakflip cover, AVS vent visors
    The remote start with fob is very fussy. Three quick clicks evenly spaced apart and hold on the last click.
    Best to look at truck from a window and verify that lights flash repeatedly when it actually starts.
    My wife’s Avalon’s remote start is even fussier than my Tundra.
    She rarely gets the proper cadence right to start her car and I end up doing it.
    Toyota: it doesn’t need to be that hard!
    Now that I think about it, the difficulty and sucky range is most likely deliberate so you end up paying $15+tax a month to start via the app.
    mrfreeman likes this.
  11. Dec 30, 2024 at 8:58 PM
    mrlittlejohn
    mrlittlejohn New Member
    Michael
    2022 Toyota Tundra Limited
    And the range is less than FOB usage from my experience. I believe max range is 17' 7.38654276543"
    Quite irritating to say. I just gave up on the thought of using it.
    TundraDan723 likes this.
  12. Dec 31, 2024 at 5:02 AM
    volleyball
    volleyball New Member
    Mine works consistently from about 70' window. Not from 82' window though.
  13. Dec 31, 2024 at 6:26 AM
    GREENPUS
    GREENPUS New Member
    Scott
    2024 Black Tundra Limited TRD Off-Road
    every Toyota I’ve owned with factory remote is like this. Has nothing to do with subscription or app. Toyota fobs and sensor on car just suck. I can be over 500 feet from my BMW X6 and remote start. Just another piss poor design form Toyota. Just like when you touch the door handle the POS shuts down the engine and you have to restart
    Polo08816 and mrfreeman like this.
  14. Dec 31, 2024 at 9:37 AM
    Gonefishingdave
    Dave
    Central New York
    Another annoying aspect with the fob: if my cell phone is in the same pocket as the fob, keyless entry will not work. As soon as I raise the phone half way out of my pocket, it’ll work.
    I thought maybe the battery was weak, so I put in a new one and no difference.
  15. Jan 1, 2025 at 11:22 AM
    Xsierra
    Xsierra New Member
    Kirby
    I just purchased the 2024 Tundra Platnium and my remote start using the app works ok, but the engine does shut off when entering the vehicle or even when unlocking it with the fob. Stupidest thing I’ve seen for a vehicle. Toyota better fix that, or fire some engineers
    Polo08816 likes this.
  16. Jan 1, 2025 at 11:38 AM
    gdisarray
    gdisarray Short term member
    2023 Tundra Limited HV
    Tint and wheels. Decked box in the bed. S and B Cold Air filters under the hood. Shiftpower throttle response controller.
    I think they keep the transmission power turned way down for safety. If it is too strong and transmits too far it is ripe for someone clipping codes in car parking lots. They can record the signal and then dupe it to get into your vehicle. The shorter the range, the less chance of someone clipping the code. The cell signal remote start is a lot safer but it costs some duckies to use.
  17. Jan 1, 2025 at 12:05 PM
    mrlittlejohn
    Michael
    I will take that as a possibility. Especially in today’s world.
  18. Jan 1, 2025 at 12:23 PM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    Yeah, that does suck. My wife's Lexus on the other hand, does NOT shut down when you open the door. So, Toyota could do this for us, but for some reason choose not to.
    Polo08816 and Gonefishingdave like this.
  19. Jan 4, 2025 at 4:52 PM
    Xsierra
    Xsierra New Member
    Kirby
    Easy programming solution for Toyota. Shut off the engine only when brake pedal is stepped on! Can’t be stolen especially when it can’t be put into gear before stepping on the brake. JMO
    mrlittlejohn and TundraDan723 like this.
  20. Jan 4, 2025 at 5:08 PM
    mrlittlejohn
    Michael
    Exactly. No reinventing anything here. It’s how all others do it. Toyota just wants to lock down the Tundra for a weird unknown reason.
  21. Jan 4, 2025 at 5:11 PM
    TexasCabledawg
    TexasCabledawg New Member
    2024 Land Cruiser (had a ‘22 Tundra)
    I don’t get why Toyota made this sub-par in the Tundra. My LC fob range and operability is leaps and bounds better than the ‘22 Tundra I had. Also doesn’t shut off once you open the door. Just depress the brake and press the stop/start button and away you go. U also can adjust HVAC settings with the app (as well as other arbitrary functions such as honking the horn).
  22. Jan 4, 2025 at 6:38 PM
    trazerr
    trazerr New Member
    Oregon
    2024 Toyota Tundra Platinum LR
    TSS 2.5 vs TSS 3.0
