Remote Start.. Yay or Nay?
Discussion in '2nd Gen Tundras (2007-2013)' started by 009m, Jun 7, 2020.
  1. Jun 7, 2020 at 10:46 AM
    009m
    009m [OP] New Member
    2010 Black Tundra Platinum
    Tuner, cold air intake, catback exhaust
    I have always wanted one and now that I have a vehicle I am in love with and really truly want to put time and money into, I was looking for some advice/guidance. I'm in a 2010 Platinum, and have done some looking around but not having much luck as far as reviews go. There were some cheaper options on sparks parts, and some $500+ options through best buy. Anyone have a particular model they like, or things to be aware of and to stay away from?
  2. Jun 7, 2020 at 11:04 AM
    FFSLJ
    FFSLJ New Member
    2016 Super White Tundra CrewMax 5.5 bed SR5
    Spyder Head lights, Spyder Tail lights, TRD grill/hood scoop, Rigid Industries Fog lights , and more to come/
    I bought mine (3rd gen tundra) off Amazon. Had good reviews and gave it a shot. Been good so far, easy install, good videos for install, uses factory remote, the range I get is about 250ft.
    Start-X Complete Plug N Play Remote Starter kit for Toyota Tundra 2010-2017 || Zero Wire Splicing! https://www.amazon.com/dp/B07VBHNBHS/ref=cm_sw_r_cp_api_i_IVs3EbPDBSY5W
    Wallygator and Danny3737 like this.
  3. Jun 7, 2020 at 11:04 AM
    TheBeast The Beach
    the one we got on the group buy last year is perfect. Easy install too.
    FORTIN EVO
    41bigdawg likes this.
  4. Jun 7, 2020 at 11:04 AM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    I’ve had a Prestige in a Mustang that worked really well .
  5. Jun 7, 2020 at 11:05 AM
    TheBeast The Beach
  6. Jun 7, 2020 at 11:13 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    ^I was going to recommend the same thing.
    James is awesome.
    I have a Compustar alarm/remote start on my 2014.
    Had a local installer install it.
    I use it almost every time I start the truck just to hear my BAM muffler..
    I use the DroneMobile app with it..
    Been very happy with it..
    https://www.dronemobile.com/
    Whatever you do, don't get the Toyota remote start..
  7. Jun 7, 2020 at 11:33 AM
    009m
    Wow thanks for all the quick replies guys! I will check all that out... I do like the idea of not needing a separate remote and to just use the factory fob. I like to keep my keys minimal and simple so was on the fence about a separate remote.
    TheBeast likes this.
  8. Jun 7, 2020 at 11:37 AM
    TheBeast The Beach
    and you can always add on accessories later by plugging extra modules to harness.
    the fortin evo 1 is very easy to install. plug and play. I think it took me 45 min to install and that is with removing the body panels.
    check your key code first to be sure.
  9. Jun 7, 2020 at 11:42 AM
    009m
    That is cool, what other accessories can you plug in?
  10. Jun 7, 2020 at 11:43 AM
    HailstorminMT
    HailstorminMT New Member
    Hailey
    Montana
    '14 Tundra and '04 4runner v8
    lift and lights
    I had mine installed by the toyota dealership and I think the brand is "viper."
    I loooove having a remote start. The only problem I've had is when I started my truck too early it shut off after 15 minutes but it leaves the headlights on if its dark and they are on auto. It drained my battery and almost didn't start back up that morning
  11. Jun 7, 2020 at 11:53 AM
    TheBeast The Beach
    for the cell access so you can start your car from anywhere through a phone app.
  12. Jun 7, 2020 at 11:56 AM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
  13. Jun 7, 2020 at 12:58 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Some aftermarket use your factory remote, others replace it.
    You won't end up needing to carry 2 remotes..
    I'm with you keys minimal.....
    This what I carry daily..
    Couple screen shots of the Dronemobile on my iPhone.
    As much as I do trust it, I'd never lock the keys in the truck and solely rely on it.
    There are also a few other options as far as smartphone control...
    009m[QUOTED][OP] likes this.
  14. Jun 7, 2020 at 1:07 PM
    009m
    Phone Remote would be nice, as well as just an added layer of redundancy that doesn't add to your edc.
  15. Jun 7, 2020 at 1:44 PM
    SoCalTecHead
    SoCalTecHead New Member
    Tony
    Orange County California
    2020 Cement CM Limited
    I had a Tacoma that I installed a remote start on. All was great until my battery died (covered by warranty after a brief fight with Toyota). They told me that there was a parasitic draw that was causing me issues and they wanted several hundred dollars to troubleshoot, I declined. After getting the truck home, I did some load testing and pulled fuses and was able to narrow it down to the remote start module. After some reading, it turns out that as it is always listening for a start or lock command that there is a slight draw on the system. I work from home and only ran the truck once every week or two and if I had driven it more frequently I am sure it would not have been an issue as the alternator would keep the battery charged.
    With that said, my new Tudra has factory remote start, but I will ensure I run it once a week to be safe.
  16. Jun 7, 2020 at 2:17 PM
    11SilverPlatinum
    11SilverPlatinum New Member
    Dave
    2011 Platinum Tundra
    Plastidip emblems, Pace Edward bed cover w/lumber rack, remote start, TRD intake and exhaust, TRD front and rear sway bars, color match grill surround, LED headlight upgrade.
    I have a Compustar. This is my 2nd remote start. I recommend getting one that shows the vehicle started. My first one didn’t and it was a pain to go look to make sure it was running. I love mine, used it every day when I commuted to work. Now working from home, don’t use it as much, but as stated earlier, it is fun to hear the exhaust (TRD for me) as you walk up to the truck.
  17. Jun 7, 2020 at 2:30 PM
    PJR202
    PJR202 New Member
    I had a compustar with my tacoma that was 100% flawless unless the windshield had a lot of snow on it. I had a long range fob.
    I have the tech12volts kit, which is a preprogrammed Fortin Evo-1. The starter itself works great. I use my factory fob (limited range) and it's solid. There is a long range fob as well but I opted to go with the Mycar cellular module so I could control it with my phone. When it works, it's great but, it's glitch and they are regularly fixing bugs in the software. Right now I'm dealing with it not communicating with my phone if I'm using My ATT 5GE service. If I'm in 4G territory it's fine. Unfortunately I have 5GE at home. I'm emailing the mycar people about it now.
  18. Jun 7, 2020 at 2:44 PM
    41bigdawg
    41bigdawg Let the BIG DAWG Eat
    Robert
    Tennessee
    2013 Tundra DC 5.7
    Magnum front, Iron Cross rear bumpers, SB Cold air intake and Gibson Metal Mulisha exhaust, Fender flares, Tow mirrors, 18" Outlaw wheels, 12k Smitty X2O winch, Tech 12v auto start, Firestone Air Bags, Pedal Commander, Devil Horns, etc...
    Tundra3k likes this.
  19. Feb 26, 2022 at 5:35 PM
    amajack
    amajack New Member
    Couple questions: does any splicing void warrenty on anything ?
    Do your headlights stay on if you turn off the truck?
    thanks
  20. Feb 28, 2022 at 6:34 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    I installed a Compustar in my '07. First vehicle I've owned to ever have remote start. I LOVE IT! 3000' range with the 2-way remote. Having a remote that lets you know you're truck has started is a BIG bonus. I can start my truck before I even pull up to the dock to recover my boat. I was in Ole Red Gatlinburg having dinner. After my meal I started the truck, with the remote, parked 3 blocks away.
  21. Feb 28, 2022 at 2:43 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    X2 on the Start-X
    Wallygator likes this.
  22. Mar 2, 2022 at 4:51 AM
    Redman333
    Redman333 New Member
    Jared
    Tundra
    Yes
    I literally just picked up my truck from a shop that installed my T13 compustar and drone mobile. Absolutely love it so far. The proximity unlock is a really nice feature too.
    BlueCrushSC16 likes this.
  23. Mar 2, 2022 at 8:30 AM
    MonteSTL
    MonteSTL New Member
    Monte
    2007 Tundra SR5 black
    stock
  24. Mar 2, 2022 at 9:17 AM
    Rustedfenders
    Rustedfenders If it ain't broke, don't fix it.
    Wally
    Rosedale Md.
    2016 Blazing Blue Pearl TRD Tundra Crew Max
    Aries 4" Bull Bar, 3-2 Level Lift Havoc Stainless hoop steps.
    I have the Viper and i had the time extended to 30 mins. It can only be done by the installer from a computer. And dont leave your lights on AUTO.
  25. Mar 2, 2022 at 9:21 AM
    Rustedfenders
    Wally
    Rosedale Md.
    Love my Viper! Can start it from up to a 1/4 mile away with the remote and start it from the other side of the country with the app.:oldglory:
  26. Mar 2, 2022 at 9:21 AM
    BlueLighting
    BlueLighting New Member
    Rick
    California
    2015 Platinum
    4.5 RC Lift, fuel wheels, RC front bumper & front struts
    Start X easy install
  27. Mar 2, 2022 at 9:22 AM
    coolbeans
    coolbeans New Member
    I have a Toyota remote start on my 4runner after having other aftermarket starters on other vehicles that don't last (or the fobs). The annoying part of the Toyota starter is it shuts off the vehicle when you go to unlock it, not sure if it can be programmed not to do that.
  28. Mar 2, 2022 at 9:22 AM
    poop_bubbles
    poop_bubbles New Member
    Personally I would not install one. Already get bad enough MPG and don’t see the need for unnecessary idling.
    If anything I would do heated seats. Way better. My Lexus seats warm up in 60 seconds in single digit weather.
  29. Mar 2, 2022 at 9:23 AM
    Rustedfenders
    Wally
    Rosedale Md.
    :sadviolin:
  30. Mar 2, 2022 at 9:24 AM
    CavBluTundra
    CavBluTundra CavBluisdabomb
    Howard
    2018 TRD Off Road Limited
    ^^This one right here. I have a 2018, but press my key remote 4 times and it has never failed me. Install was about 45 minutes because I kept going back and forth from a video link from James. As long as you don't press the brake pedal before you insert and turn the key to run, the engine stays running. Love mine
    TheBeast[QUOTED] likes this.
