Remote Start questions/reviews
Discussion in '2.5 Gen Tundras (2014-2021)' started by treetreego, Oct 5, 2021.
  1. Oct 5, 2021 at 12:13 PM
    treetreego
    treetreego [OP] New Member
    MS
    2020 Tundra Crewmax TSS 4x4
    295/65/20 Nitto Trail Grappler MT on Fuel Mavericks, Leveled
    Start-X Remote Starter for Tundra 2020+ || Plug N Play || Lock 3 Times to Remote Start || Push-to-Start only || Zero Wire Splicing, 5 Minute Install! https://www.amazon.com/dp/B094Q5W683
    Has anyone installed this exact one?
    does it turn off when you unlock or open the door?
    how long will it run after starting?
    is it truly plug and play, no cutting or splicing?
    anything else I should know before buying?
    truck is a 2020 SR5.
    thanks
  2. Oct 5, 2021 at 12:31 PM
    jhardy1979
    jhardy1979 New Member
    Justin
    MGM 2015 Tundra Crewmax Limited 4x4
    From what I am reading it will stay running even when you open the door.
  3. Oct 5, 2021 at 12:56 PM
    treetreego
    MS
    jhardy1979 likes this.
  4. Oct 5, 2021 at 1:06 PM
    jhardy1979
    Justin
  5. Oct 5, 2021 at 1:14 PM
    treetreego
    MS
  6. Oct 5, 2021 at 1:15 PM
    jhardy1979
    Justin
    No its a module you can add to the other one
  7. Oct 5, 2021 at 1:17 PM
    treetreego
    MS
    oh I see. Cool thanks
  8. Oct 5, 2021 at 2:05 PM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    Tech12volts and 12voltsolutions also sell a similar setup. Not sure of the difference but many on here have used them.
  9. Oct 5, 2021 at 2:52 PM
    treetreego
    MS
    I looked at the tech12volt site but didn’t see one for the 2020
  10. Oct 8, 2021 at 9:59 PM
    Silver1794
    Silver1794 New Member
    I just returned this exact unit to Amazon. I installed in my 2018 last weekend later this week and after a 30 mile drive and return to my truck it wouldn't start even with the key. I followed the directions to the letter and it worked fine for a couple days. Ended up having to get AAA to tow me home. I removed everything and returned it to stock. Once I got it home and was able to troubleshoot two 5 amps ignition related fuses had blown. I would try another kit versus the starterX model.
    batman900 likes this.
