Remote start or not?
Discussion in '2.5 Gen Tundras (2014-2021)' started by usmealgle, Jun 23, 2020.
  1. Jun 23, 2020 at 8:24 PM
    usmealgle
    usmealgle [OP] New Member
    orjan
    White 2017 Tundra Limited CrewMaxx
    folks i'm new to the Toyota world and just purchased a 2017 Tundra CrewMax Limited, how can i tell if it has remote start? i've read several things but not anything conclusive. My keyfob has lock, unlock and panic button and thats it.
    Thank you
  2. Jun 23, 2020 at 8:28 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Lock-lock-lock with a half second between each. If that doesn’t work try lock-unlock-lock. If that doesn’t work, you probably don’t have remote start. Those are the two primary remote start combos
    Zebruaj and usmealgle[OP] like this.
  3. Jun 23, 2020 at 8:51 PM
    AZBoatHauler
    So.Arizona
  4. Jun 23, 2020 at 8:56 PM
    RobertD
    Robert
    DFW, Texas
    For me its lock-lock-lock but hold the third one for about 2 seconds. There is probably an easy way to look somewhere but I'm not sure where it gets installed :rofl:
  5. Jun 23, 2020 at 9:13 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    ToyoMafia likes this.
  6. Jun 23, 2020 at 9:35 PM
    AZBoatHauler
    So.Arizona
    A watched a couple YouTube videos before I started and it ended up being a straightforward problem free install. Took less than 90 minutes start to finish. If you have the Toyota glass breakage sensor under the AC controls (looks like a tiny speaker near the USB port) you have a wire to splice but still easy.
    Ely010606[QUOTED] and 1lowlife like this.
  7. Jun 23, 2020 at 9:38 PM
    Ely010606
    SPARKS, NV
    Thanks for the reply, i will definitely do that. No glass sensor on mine
  8. Jun 23, 2020 at 9:39 PM
    AZBoatHauler
    So.Arizona
    I looked back at the instructions and edited my post. Since you’re pre 2018 without the glass breakage sensor you shouldn’t need to splice any wires.
    Ely010606[QUOTED] likes this.
  9. Jun 23, 2020 at 9:46 PM
    41bigdawg
    41bigdawg Let the BIG DAWG Eat
    Robert
    Tennessee
    2013 Tundra DC 5.7
    Magnum front, Iron Cross rear bumpers, SB Cold air intake and Gibson Metal Mulisha exhaust, Fender flares, Tow mirrors, 18" Outlaw wheels, 12k Smitty X2O winch, Tech 12v auto start, Firestone Air Bags, Pedal Commander, Devil Horns, etc...
    Its an easy install, if you have problems just call James he will get you going in about 2 minutes :)
    Ely010606 and 1lowlife like this.
  10. Jun 23, 2020 at 9:51 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Even if you had the Toyota remote start, you'd want an aftermarket one.
    I can't imagine how pissed I'd be remote starting my truck and having it shut off when you opened the door....:mad:
    Very happy with my Compustar and Drone mobile module/app..
    I use the app a lot more than I thought I would.
    Use it more to check voltage than anything...
    But if I had a new truck, I'd probably use tech12volts remote start and his phone app module.
    Seafury likes this.
  11. Jun 23, 2020 at 10:39 PM
    Ely010606
    SPARKS, NV
    Sweet, getting ready to pull the trigger. Thanks again
    Seafury likes this.
  12. Jun 24, 2020 at 7:18 AM
    Welcome from NY.
  13. Jun 24, 2020 at 12:22 PM
    Ely010606
    SPARKS, NV
    Just ordered it, now the waiting start.
  14. Jun 24, 2020 at 6:01 PM
    KingsAustin
    KingsAustin Grey Goose II
    Morgan County, AL
    2021 Limited Night Shade
    BakFlip MX4, Gator All Weather mats, Console Safe, Ceramic Tint, Roadmaster Active Suspension, Interior/exterior LED conversion, Wireless console charger, AJT designs.
    I have a 12volt system, best mod to date for my truck especially in Texas.
    usmealgle[OP] likes this.
  15. Jun 24, 2020 at 8:51 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
  16. Jun 25, 2020 at 9:03 AM
    Penberrf
    Penberrf New Member
    2020 Tundra
    WILLINH likes this.
  17. Jun 26, 2020 at 12:49 PM
    E_Shaw88
    E_Shaw88 New Member
    Evan
    Tulsa, OK
    2020 Black Tundra TSS Off-Road
    I had the dealership include the aftermarket Viper remote start. So far I like it; however, I would have liked the model that allows you to use your phone. I do have a 1,000 ft range, which is way better than my wife's stock honda remote start with maybe 50-75 ft.
  18. Jun 26, 2020 at 2:15 PM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Just installed mine today, had it since November, super simple to install
  19. Jun 26, 2020 at 2:53 PM
    pmfr67
    pmfr67 New Member
    So Fl
    2007 CrewMax SR5
    07 tundra CM (oldie but goodie) installed the tech12volt system last week simple install, dropped the truck off to have all new katzskins and AC cool seats installed and I will use that mod EVERYDAY here in So.Fla.
    AZBoatHauler likes this.
  20. Jun 28, 2020 at 7:55 AM
    Pern
    Pern New Member
    Tundra 2017
  21. Jun 28, 2020 at 8:08 AM
    pmfr67
    pmfr67 New Member
    So Fl
    2007 CrewMax SR5
    Pern, mine works 100% reason it was not a just PNP is bc I have an 07 Tundra so I had to tap 7 wires and program the remote it was very easy as per their instructions, I did check with them prior to buying so I knew I had to do that and the other plus is I use my own remote.
  22. Jun 28, 2020 at 8:21 AM
    bj46-taco-tundra
    bj46-taco-tundra New Member
    Mark
    Bj46 taco and now a tundra
    One of the easiest, and straightforward installs mods of done to the truck. Love everything about the functionality of the remote start. Paid a little more of the phone app so I can start it from the moon. Only issue was the 15 min timer before it goes into panic alarm mode. Pissed when I first discovered that while it was running in the winter while parked 100 yards away at my mom’s graveside funeral, but then supper excited when it when off after running in our closed garage after my 2 year old daughter found the keys in the house. That little alarm allowed me to ventilate things after that little oops.
    https://youtu.be/nBwgL4dZJwE
    Pern and AZBoatHauler[QUOTED] like this.
  23. Jun 28, 2020 at 9:40 AM
    AZBoatHauler
    So.Arizona
    You can tap into the white and black “key sense” wire to make it so the alarm won’t go off after it times out. I can find more info on that if you care about it.
  24. Jun 28, 2020 at 11:50 AM
    Pern
    Pern New Member
    Tundra 2017
  25. Jun 28, 2020 at 2:12 PM
    AZBoatHauler
    So.Arizona
  26. Jun 28, 2020 at 3:23 PM
    Pern
    Pern New Member
    Tundra 2017
    Thx
  27. Jun 28, 2020 at 4:33 PM
    blueshound
    blueshound New Member
    2015 Red Tundra Platinum
    My key ring came with a plastic instructions but since it was used the instructions are half rubbed of and missing. Luckily I figured it out. It does turn off when you unlock the door. It is lock, lock and hold lock for 3 seconds. I never remember to do it but it hasn’t been 110 degrees here yet so that will make me remember eventually.
  28. Jun 30, 2020 at 1:48 PM
    Vic4x4
    Vic4x4 New Member
    Vic
    2019 Super White Tundra Crewmax SR5 4x4
    just installed mine from 12volt solutions. Surprised how easy it was to install. Very clear video and pdf instructions. And they are only a phone call away if u need anything. I got the 3x lock kit.
