Reinstall front skid plate
Discussion in '2.5 Gen Tundras (2014-2021)' started by Michael8395, Aug 24, 2023.
  1. Aug 24, 2023 at 6:50 AM
    Michael8395
    Michael8395 [OP] New Member
    2016 Tundra
    Doing my first oil change on a 2016 Tundra. How difficult is it to reattach the front skid plate?
  2. Aug 24, 2023 at 6:51 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Not difficult at all.
  3. Aug 24, 2023 at 6:52 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    It can be a little bit of a pain to get the hooks on the front of the skid plate to line up.
    1UP likes this.
  4. Aug 24, 2023 at 6:53 AM
    Michael8395
    2016 Tundra
    Is there any tricks to it some people say it is a pain to reinstall it.
  5. Aug 24, 2023 at 7:05 AM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    I mean for me it certainly is. Some others here clearly don’t seem to have the problem.
    just make sure to get the 2 little hooks lined up with their respective holes. when you push the skid plate up, slide it just a bit to the side and those hooks should hold it up for you.
    My problem is that I always line it up with the bolt holes first then the hooks get in the way as opposed to help me.
  6. Aug 24, 2023 at 7:11 AM
    Michael8395
    2016 Tundra
    Is the plate heavy? Obviously you can’t jack the front of the truck up.Not much room to work on it.
  7. Aug 24, 2023 at 7:12 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    It's not really difficult as long as you have good upper body strength. The skid plate does have some weight to it. As Zapp mentioned, lining up the hooks on the front of the plate is the "hard part" while holding said metal plate up.
  8. Aug 24, 2023 at 9:51 AM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    If you don't have ramps to drive up on, I would recomend investing in a pair. Will make your life much easier.
  9. Aug 24, 2023 at 10:13 AM
    BeauDacious
    BeauDacious 040 > all other colors
    Beau
    14 DC 4x
    Not at all. Once you do it once, as long as you remember to put the hooks in first, it will never be an issue.
    Its like a 25# item, you need to bench press and slide it to the drivers side of the truck like 2 inches after removing the bolts.
    Install is reverse.
  10. Aug 24, 2023 at 11:34 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Fun fact, you can actually just take all the bolts out of the plate and let it drop while leaving the hooks attached and just let it hang, then it's a breeze to reinstall. I have done it both ways, obviously completely removing it gives you more room to work with but lining the hooks up and sliding it over can take a few tries, its not super difficult, just trial and error but just dropping it and leaving the hooks attached makes it super easy to reinstall.
    joe_from_iowa likes this.
  11. Aug 25, 2023 at 4:37 PM
    72GTS
    72GTS New Member
    Ontario, Canada
    2021 MGM Tundra DC TRD Sport Premium
    Like other's said, as long as you do the hooks first, it's easy. After it's hooked it place, I find it easiest to install the bolt in the center rear first (this is also the last one I remove during removal). Don't tighten all the bolts until they are all in in place. My old Tundra's skid plate hooks were bent and rusted and hadn't worked for years. So I got used to just balancing it with one hand while I bolted it up, so with the hooks my new truck is much easier.
  12. Aug 25, 2023 at 5:43 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    You could just leave it off. Weight savings = improved mpg.
    Mine has been off a fee months.
  13. Aug 27, 2023 at 7:05 AM
    DoublePro
    DoublePro New Member
    In my 2008 tundra, first thing I did was cut out those dam hooks and just spray paint the exposed metal.
