Regular cab rear speaker enclosures
Discussion in 'Audio & Video' started by sctomfar, Mar 19, 2023.
  1. Mar 19, 2023 at 12:11 PM
    sctomfar
    sctomfar [OP] Chasing 700RWHP
    Tom
    Bluffton, SC
    Supercharged Reg cab
    Harrop 2650 supercharger TRD suspension TRD intake Custom exhaust Dirtydeeds cross pipe Fully built bottom end motor Manly Rods Crowder Pistons ARB Stud Kit National Speed Tuned Redesigned fuel system XAT Fuel Rails Twin Demon Fuel Pumps 83cc Injectors Morimoto Headlights
    I’m looking for ideas for rear speakers / amp set up. I’m not looking to go crazy or competitive. I do want very good highs and base. Looking to see what ideas are out there.
  2. Mar 23, 2023 at 3:35 AM
    PSYCHO WHITE TUNDRA
    PSYCHO WHITE TUNDRA Still Gonna Send It...
    Jake
    New Mexico
    White 2011 Tundra SR5 TRD (Psycho White)
    Chopped and dumped dual exhaust; 6" fully adjustable ProComp lift w/ FabTech rear shocks, 12.5x20 Pro Comp rims on 37x12.50x20 tread wright mud tires, pedal commander throttle programmer and sound system from hell which consist of Sony double din headunit, 4 Morel Maximo Ultra 603 component door speakers w/ 4 tweeters ran on a Rockford fosgate P500-4 punch amp under drivers seat then the bass comes from a custom 15” 4000rms sub made from a Skar 15” Skar basket and motor with sundown x series components made by Patrick @ Robot Underground in Mesa AZ which is powered by 2 C.A.B. Audio 2000.1D amps strapped together at .08ohm which produces just under 5000rms. Also installed 100sq.ft. 10mil dynamat sound deadening on all 4doors (both exterior and interior chambers) double layer on roof and back wall as well as inside side mirror covers and behind side mirrors
    what year is your truck
  3. Mar 23, 2023 at 3:46 AM
    sctomfar
    Tom
    Bluffton, SC
  4. Mar 23, 2023 at 4:23 AM
    PSYCHO WHITE TUNDRA
    Jake
    New Mexico
    Taco tunes has quite a few options and all their equipment is plug and play for tacomas and tundras. There are many sites that have wedge style enclosures for single or dual 10” and 12” subs. Here’s one for a dual setup.
    https://*********.com/shop/toyota-t...x-ported-subwoofer-box-dual-10-12-subwoofers/
    As far as subwoofers go the DD Audio SL610 series sounds amazing. If your wanting 12” then it’s going to be the SL612 subs
    https://ddaudio.com/sl600-series/hi-def-tuned/sl610/
    Power them with this compact DD Audio D1100 compact amp and you’re set for perfect sound
    https://ddaudio.com/d-series/monoblocks/d1100/
