Regear Options for Tundra
Discussion in 'Performance and Tuning' started by tundrabubba, Aug 25, 2023.
  1. Aug 25, 2023 at 4:17 PM
    tundrabubba
    tundrabubba [OP] New Member
    Andrew
    Im about to lift my tundra 6ins (ReadyLift), and currently have 34s on my truck. I am debating on going to 35s.
    Ive heard some mixed reviews about regearing the truck (4.88 or 5.29).
    Is it worth doing it? Will it make the truck last longer?
    TIA!
  2. Aug 25, 2023 at 4:37 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Lot of information came across in this thread; spend some time looking through it and you'll find charts and other data that talk about RPMs for specific ratios vs tire size, etc..
    It should be a good place to start your research.
    Depending where you are, I believe another group buy was started. So, if you're looking to save a few $$$ it might be a way to go.
    Good luck on your decision :thumbsup:
    SAGE63 likes this.
  3. Aug 25, 2023 at 4:44 PM
    2mchfun
    5.29s and powertrax grip pro LSD in the rear is about the best option. Front e locker if you seriously off road.
  4. Aug 25, 2023 at 4:52 PM
    centex
    centex New Member
    Just got 5.29’s today. Stock 4.30’s. Running 34” tires. Well worth the money. So much better to drive.
  5. Aug 25, 2023 at 4:54 PM
    tundrabubba
    Andrew
    What brand did you get?
  6. Aug 25, 2023 at 5:03 PM
    centex
    centex New Member
    2mchfun likes this.
  7. Aug 25, 2023 at 6:23 PM
    tundrabubba
    Andrew
    I just talked to Keith today, I will be ordering mine next week!
    2mchfun and 1UP like this.
  8. Aug 26, 2023 at 12:30 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    5.29, without a doubt for 34” and larger tires.
    No. Question.
    The Powertrax Grip Pro LSD is well worth the price of admission while you’re having the gears set.
    Remember, that “auto” limited slip that Toyota gives us in our Tundras is nothing more than an open differential. Other than the traction control via braking, there is zero traction adder. With a real LSD, you’ll see the traction control light a lot less because you’re not a one tire fire anymore…
    2mchfun likes this.
  9. Aug 26, 2023 at 2:12 PM
    tundrabubba
    Andrew
    5.29 Sierra and Powertrax Grip Pro LSD (do you have a link to this?)
  10. Aug 26, 2023 at 2:21 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    Nope. I bought my gears (Nitro) through a friend that owns a shop. Always good to pay wholesale! Amazon, of all places, had my Grip Pro listed for less than wholesale by a fair amount, so I bought it there.
    Shop around for a decent price.
  11. Aug 26, 2023 at 3:28 PM
    tundrabubba
    Andrew
    Where was the group buy ?
  12. Aug 26, 2023 at 4:58 PM
    Tripleconpanna
    That one in particular was in Riverside area of CA; but there should be another one floating around right now (not sure where that one is at)...
    2mchfun likes this.
  13. Aug 26, 2023 at 4:59 PM
    Tripleconpanna
    but... I think you said you're dealing w/Keith at DD, right?? If so, he'll take care of you and get you set up w/exactly what you need for your application and use :thumbsup:
    ATV25 and 2mchfun like this.
  14. Aug 26, 2023 at 5:00 PM
    centex
    centex New Member
    That’s what I did. Gears and install kits.
  15. Aug 26, 2023 at 5:12 PM
    Tripleconpanna
    Ok, my bad; thanks!!! :hattip:
  16. Aug 26, 2023 at 5:18 PM
    What thread? :confused:
    2mchfun likes this.
  17. Aug 26, 2023 at 5:26 PM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Where do you live ?
    What size tire are you going to run ?
    Its flat down here, the stock 4:30's with 37's were fine and would be for most people.
    I did e-lockers F/R so I did 5:29's while I was there. Happy that I did.
  18. Aug 26, 2023 at 6:08 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    Unless it’s all downhill everywhere you drive, 37” tires and stock gearing will be less than ideal.
    Acceleration will be much more sluggish than stock, fuel economy will be worse than after regearing appropriately, and your transmission will hate you if you use 6th gear.
    Gears are, in my opinion, the best performance mod that we can do to our trucks. Yes, I put them above a supercharger, which is second…. Well, third. Good suspension is second.
  19. Aug 26, 2023 at 6:58 PM
    Tripleconpanna
    GODZILLA[QUOTED] likes this.
  20. Aug 26, 2023 at 7:03 PM
  21. Sep 1, 2023 at 5:08 AM
    Gfgneo
    Gfgneo New Member
    California
    2021 tundra platinum
    I have 4.88 on mine but im thinking i probably should have went 5.29. Definitely felt a difference from stock though
  22. Sep 1, 2023 at 5:17 AM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    I run 37s on stock gears in the PNW and have no issues haha.
    If you’re sticking with 34/35s I wouldn’t even consider gears.
  23. Sep 1, 2023 at 8:33 AM
    centex
    centex New Member
    After a week with the 5.29’s on my 34’s, no way I’d ever consider leaving it stock. Now to hook up the trailer and rzr and see how she pulls.
    Chad D. likes this.
  24. Sep 1, 2023 at 8:57 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    After 18 months with 5.29’s and 34’s, I’m still all smiles. 0.0% chance I’d do this with stock gears after recognizing the difference.
    Get the preliminary heat cycles and break in done, then swap oil before you do any hard pulls or towing if you can!
    You’ll love towing your trailer with those lower gears…
  25. Sep 1, 2023 at 12:07 PM
    centex
    centex New Member
    I made it to 300 miles before I had to tow. Changed the oil this morning. And WOW. Huge difference. 70 in 6th is no issue now. I’d love to crank it up to 80 (which is the speed limit) and see how it does but I’m still being a bit sensitive on the gears. Varying speed from 60-70 and stopping every 30mins for a few mins to let them cool.
  26. Sep 1, 2023 at 2:03 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    Cant remember... Do you have a tune? If not, you're going to be limited at ~93 MPH...
  27. Sep 1, 2023 at 3:48 PM
    centex
    centex New Member
    I’ve got a small tune I built for it.
  28. Sep 1, 2023 at 4:57 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    Nice. Well, if you haven’t already, adjust the tune for gears and crank that speed limiter to 11.
  29. Sep 1, 2023 at 6:12 PM
    centex
    centex New Member
    Already done. Loaded it the moment I got it home.
    I’m still amazed at how much better it pulls. I’m going to drain the fluid one more time after this trip and then I’m going to let her eat.
  30. Sep 1, 2023 at 6:21 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    It might not have issues, but your truck is absolutely gutless without gears :rofl:
