Refueling problem- solution
Discussion in '2.5 Gen Tundras (2014-2021)' started by KiltedWolf1, Jan 28, 2019.
  1. Jan 28, 2019 at 10:19 AM
    KiltedWolf1
    KiltedWolf1 [OP] New Member
    ‘16 Platinum Crewmax White
    Hello, I wanted to post the solution to the below problem (could not add fuel, pump would shut off). As I suspected after reading different posts here and elsewhere, I figured there was an issue with the charcoal canister, a $945+ part ($1800+ at Autozone). Covered under my extended warranty but to let you know. It was saturated and not working, per the dealer. I don’t do this but DO NOT TOP OFF when refueling. This can be a cause, the vent tube being plugged can be a cause as well. Hope this helps someone. Thanks.
    (Original post “Gas filling problem”)
    Good morning all,
    I have this problem, started yesterday. Whiletrying to fill up before I drive 225 home. Can’t fill up, and went to 3 different stations. I finally jammed it in and held it tight and itworked for a few seconds and then gas poured back out. Can’t see any blockage. I saw another post but it was May 2018 and not sure I’ll get a response. Have a 2016Platinum, scheduled service tomorrow since no appointments open today and missing 2 days of work. But since I see others have hadthis happen, looking for an answer or whatyour outcome was. Thanks for any help.
    15whtrd likes this.
  2. Jan 29, 2019 at 8:32 AM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    Friend had a similar issue, albeit with a Lexus, because the canister was filled by “topping” the tank during refills. It was his habit. Mine as well from the old days. Since then I let the pump decide on all my vehicles. It’s a pricy fix!
    NewImprovedRon likes this.
  3. Jan 29, 2019 at 9:28 AM
    KiltedWolf1
    Yes it is! The bill was over $1,000, so after 6 months my extended warranty is already paying off.
  4. Jan 29, 2019 at 10:32 AM
    marlin39a
    marlin39a I’m a dumbass.
    Thanks OP on top off tip. I've always done it, but no more.
  5. Feb 2, 2019 at 3:06 PM
    Phishindude
    Phishindude New Member
    I had the same OCD problem. Dropped the habit when I bought my Tundra in October.
