Red Line 75W85 Differential Gear Oil...Who's using it?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by 1999cutiger, Jan 11, 2020.
  1. Jan 11, 2020 at 1:11 PM
    1999cutiger
    1999cutiger [OP] Top Flow Lifestyle
    2017 Toyota Tundra SR5 4x4
    RBP 67R AK-8 20x9 wheels General Grabber ATX 275/60/20
    I'm just past 30K on the odometer and I am about to pull the plug on the rear differential. I usually like to use the exact fluid that Toyota specs, but it's really expensive. Red Line advertises a 75W85 fluid that meets the Toyota spec.
    I have read numerous stories from owners stating the great importance of sticking with the correct spec oil for our differentials...so I am not at all comfortable with putting in a standard 75W90 off the shelf.
    Any users of the Red Line fluid on the Gen 3? If so, how is it working for you?
    Thanks in advance for your feedback.
  2. Jan 11, 2020 at 1:25 PM
    Luckydog
    Luckydog New Member
    Dominic
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    So far so good. I think that is what I am running. Found it in a thread here and ordered off Amazon.
  3. Jan 12, 2020 at 10:00 AM
    1999cutiger
    Thanks.
    Anybody else?
  4. Jan 13, 2020 at 1:46 PM
    rj1022
    rj1022 New Member
    RJ
    2016 Tundra TRD Pro Crewmax MGM
    I used it in my 16 Pro.
  5. Jan 14, 2020 at 7:16 AM
    1999cutiger
    Does it seem to perform as well as with the factory fluid?
  6. Jan 14, 2020 at 7:18 AM
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    Is it better than Mobil 1 75W90 LS?
  7. Jan 14, 2020 at 10:25 AM
    rockfordhx
    rockfordhx New Member
    sub'ed. I have 34K and need to replace rear diff fluid and was wondering the same question as the OP.
  8. Jan 17, 2020 at 12:34 PM
    rj1022
    rj1022 New Member
    RJ
    To be honest, i have no idea if it made a diff or not. I did it for long term protection of the diff.
  9. Mar 9, 2020 at 2:15 AM
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
    I hit 60k and swapped out diff fluid. Oem fluid was almost new looking. I used 75/90 amsoil severe gear.so far the trucks feels like it has less rolling resistance.
    GNTundra, Brownsfanhere and WFD473 like this.
  10. Mar 9, 2020 at 3:53 AM
    Brownsfanhere
    Brownsfanhere New Member
    2015 Crew Max
    I’m about to tackle this as well. Diffs from what I have read here 75 w90 is fine. Dealer uses it from my quote from them. The transfer case is the one you have to stick to spec. This site is great for us best truck in the market owners. That redline isn’t cheap. So must be good
  11. Apr 18, 2020 at 7:44 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    I'm using the Redline 75w90 in my 4runner. Works great.
    I'm using Royal Purple Synchromax trans oil in my transfer case - it's a direct replacement for Toyota OEM.
  12. Apr 18, 2020 at 8:34 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    you don’t need the LS unless you have a limited slip. Tundras do not come with those from the factory.
  13. Apr 18, 2020 at 11:18 PM
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    Casper3 and Sumo91 like this.
  14. Apr 19, 2020 at 12:07 AM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
  15. Apr 19, 2020 at 1:04 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Wally world Full Synth 75-140 has worked for me for 323,987 Zero trouble miles so far in both diffs and TC.
    Go Wally!
    Black Wolf, texasrho83 and Bravohook like this.
  16. Apr 19, 2020 at 5:26 AM
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
    I was a bit proactive with changing both diffs and the transfer case fluids at 25,000 miles last summer in my 2015 SR5.
    Stuck to the factory specs for weights.
    Used Ravenol for the transfer case and Red Line for the front and rear diff
    Handy chart for anyone who needs it.
  17. Apr 19, 2020 at 5:37 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  18. Apr 19, 2020 at 5:43 AM
    ninjajay
    Spoolston, TX
  19. Apr 19, 2020 at 8:45 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  20. May 1, 2022 at 7:19 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Sumo91[QUOTED] likes this.
  21. May 1, 2022 at 7:48 AM
    Sumo91
    TN
    It was great! I changed it out a month or so ago, I have the sample ready to send to Blackstone. Just gotta find it and send it off. We just moved so everything is packed. I switched to HPL diff fluid, it has a better add pack, etc. But the Schaeffers did great! I'd definitely run it again
    Here is a thread I started when I changed the fluid out
    https://www.tundras.com/threads/rear-diff-fluid-after-58k-miles-w-pics.101969/
  22. May 1, 2022 at 7:56 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Thanks, read it.
    I like the idea of using Schaeffer's products since they're family owned and American made. They have a ton of history behind them. Hard not to support that. I may check out HPL since Schaeffer is out of diff gear oil... I have about 400 miles before I change it so maybe between now and then they get some more
  23. May 1, 2022 at 8:01 AM
    Sumo91
    TN
    HPL is great. They're American owed and have a great reputation, they'll make you some 75w for your transfer case too! I ordered 8qts of 75w90 and 4qts of 75w so I could get my case of 12qts. The 75w isn't on their website, but if you call them they'll make you a batch.
  24. May 1, 2022 at 8:04 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Good to know! I ain't ready to do my T case yet but I def need some gear oil. Does HPL have the "moly effect" that Shaeffer's does? I read that it clings to the gears to prevent wear from cold friction (1st start of the day, etc)
  25. May 1, 2022 at 8:10 AM
    Sumo91
    TN
    They have tons of moly, and they use an extremely high grade of sulphur in the gear oil, so it doesn't have a strong gear oil smell to it.
  26. May 1, 2022 at 8:13 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    That's the best part :monocle:
  27. May 1, 2022 at 8:15 AM
    Sumo91
    TN
  28. May 1, 2022 at 8:21 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Reading HPL's About Us section and laughed:
    "You will never hear “press 2 for English” when you call us""
    Sumo91 and Oey12 like this.
  29. May 1, 2022 at 8:26 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    After having new gears installed I ran Red Line for the 500 mi break-in. Then I switched to Amsoil 75w-140
    pvn.beluga and texasrho83 like this.
  30. May 1, 2022 at 9:22 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    I'm amazed that your fluid looks "almost new" at 60k? How is that possible?
