Red and black wires behind headlights
Discussion in 'Lighting' started by Doodle66, Jul 29, 2017.
  1. Jul 29, 2017 at 3:22 PM
    Doodle66
    Doodle66 [OP] New Member
    Robert
    2014 white limited
    Found open ended red and black wires behind both headlights heat shrinked into original loom ??? Good gawd how do you post pics on here damn.
  2. Jul 29, 2017 at 3:24 PM
    Doodle66
    Robert
    2014 white limited
  3. Jul 29, 2017 at 3:48 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    Doesn't look like stock wiring, the bullet connector for sure aren't stock.
  4. Jul 29, 2017 at 4:27 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    Definitely not stock. Looks like a power and ground for an auxiliary something or other.
    NewImprovedRon likes this.
  5. Jul 29, 2017 at 10:19 PM
    Doodle66
    Robert
    2014 white limited
    I think the same, but why on both sides. The wires on the stock connector are so small they couldnt hold enough amps to run mutch more than the headlights
  6. Jul 30, 2017 at 9:17 AM
    duece292
    Greg
    Green Bay, WI
    I've run into this a few times where someone has spliced in a cheap set of "I got these off of eBay for $20" HID headlights because the plug end was incorrect.
  7. Jul 30, 2017 at 11:27 AM
    Doodle66
    Robert
    2014 white limited
    Maybe thats the case. I hate the unkown with a preowned truck
  8. Jul 30, 2017 at 12:41 PM
    duece292
    Greg
    Green Bay, WI
    It may also have been connections for resistors if the p.o. had l.e.d. turn signal bulbs. I would check the taillight harnesses as well. In any case, if your lights are all functioning properly I would remove the wires at the splice, reseal, tape, put back in the loom and forget they were ever there. If you decide to leave them I would fill the ends of the connectors with dielectric grease and tape them up good to prevent corrosion problems.
  9. Jul 30, 2017 at 1:45 PM
    Doodle66
    Robert
    2014 white limited
    Yep, im gonna put different terminal ends on the leads and keep them. They appear to be sealed properly except the ends. Maybe i will use them in the future.
