Recycled LED fogs to back-up light?
Discussion in '3rd Gen Tundras (2022+)' started by jctmundra, Dec 5, 2023.
  1. Dec 5, 2023 at 10:55 AM
    jctmundra
    jctmundra [OP] New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    I have DD fogs to replace the OEM led fogs, hate to put them on a shelf. Looking to cut slot in the rear bumper plastic fillers and mount the fogs. Power from the backup wire (beige) in the 7 pin connector.
    Been done yet?
  2. Dec 5, 2023 at 11:01 AM
    NickBrewer
    NickBrewer New Member
    2023 Toyota Tundra 1794 Edition Magnetic Gray Metallic
    I had a pair of Rigid SRQ flush mounts installed in the rear bumper panels powered from the 7-pin connector, one issue you may run into is that there is not a lot of space/depth behind those panels.
  3. Dec 29, 2024 at 12:37 PM
    jctmundra
    Northern VT
    Update - OEM fogs as back-up is a fail. They had had considerable condensation. Tried flipping over as they are vented, made no difference. Went with DD mounted in the endcaps. all good now.
    Raven67 likes this.
