Recs for Replacing Stock non-JBL speakers in 2017 Limited Crew
Discussion in 'Audio & Video' started by Borgs, Apr 13, 2017.
  1. Apr 13, 2017 at 5:28 AM
    Borgs
    Borgs [OP] New Member
    PA
    I want to replace the stock speakers in my non-JBL 2017 Crew Limited. Recommendations? I used to be an audiohead in a prior life (12" and 15" subs, crossovers, components, amps, etc.), but am no longer into the thump, expense, and time and effort to rip the interior of a new truck apart. I just want a clear, full, sound - and don't want to rip my new truck apart much to install, and want to keep the interior looking as stock as possible. I've been on the *********.com website - plug and play is the way I am leaning, but not sure I want to spend tactotunes- caliber coin. Thanks!
  2. Apr 13, 2017 at 1:14 PM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    Are you keeping the factory head unit?
    I just replaced the none entune none jbl hu and that made a big change..
  3. Apr 13, 2017 at 1:26 PM
    Borgs
    PA
    I think I'd like to keep the stock HU.
  4. Apr 13, 2017 at 4:14 PM
    Help New Member
    Ryan
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
    adding a small amp might be your best bet. get a small 4 channel amp that'll fit in or under the glove box and punch a small hole in the side of the glove box to run wiring back to the stock hu. a bit more power can make garbage speakers sound better and the stock hu probably isn't worth trying to run expensive door speakers off of without a secondary power source.
    speaker-wise: I'm a fan of Polk, JBL, or Infinity for decent quality. Sound-wise is entirely what sounds good to your ears. I like deeper sound rather than crystal clear which is why I tend to lean toward Polks.
  5. Apr 13, 2017 at 4:33 PM
    Borgs
    PA
    Thanks Help. Good thoughts. I was hoping to get away without running power off the battery to an amp (drill hole through fire wall, etc) like we used to in the early mid 90's (maybe there is an easier way now? - I am dating myself). Have you seen the component speakers on *********.com? Those kits seem like the real deal.
    Eclipsed & Floating likes this.
  6. Apr 13, 2017 at 4:39 PM
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    I've got my stuff ordered and just waiting for it to come in. Everything I've read is that you need more power. The stock amp just doesn't have any juice to it at all. You can get the power wire into the cab through the rubber grommet on the driver's side so you don't have to drill any holes. You can also get a harness that will make an amp plug and play with the wires that are already under the passenger seat.
    GNTundra likes this.
  7. Apr 13, 2017 at 4:44 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
  8. Apr 13, 2017 at 4:48 PM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    I was never able to really find out what kind of quality are those ********* amps? If you don't want to go with the ********* amps, you can get a different amp and just use the harness to make it plug and play as well.
  9. Apr 13, 2017 at 4:51 PM
    1UPPER
    TEXAS
    Flux capacitor!
    I've know several people with the taco Tunes set up and there very decent. I'm still running JL audio amps for my stuff.
  10. Apr 13, 2017 at 4:52 PM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    I ended up going with a JL Audio amp as well because I didn't know what the Taco tunes stuff was like.
  11. Apr 13, 2017 at 4:59 PM
    1UPPER
    TEXAS
    Flux capacitor!
    I know the owner of Taco Tunes personally and he is a very knowledgeable and a helpful guy for Toyota stereos. I've listened to several Tundras running his amps and they still sound great for a lot less money.
  12. Apr 13, 2017 at 5:08 PM
    Borgs
    PA
    Good information b-ball. I know there are several good install videos out there on the web, some of which are on *********.com. I admit I have not spent a lot of time researching and figuring yet. This page has been very helpful.
  13. Apr 13, 2017 at 5:09 PM
    Borgs
    PA
    I've heard the same. Too bad I am more than a couple hundred miles away in PA and can't pay him a visit. I'd have him do the whole install and not worry.
  14. Apr 13, 2017 at 5:11 PM
    Borgs
    PA
  15. Apr 13, 2017 at 5:11 PM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    Front speakers are Helix E62c
    Rear speakers are JBL GT7-6C
    Amp JL Audio xd700/5vr2
    Subwoofer JL Audio 10in tw3
  16. Apr 13, 2017 at 5:13 PM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    Yes, it is under your passenger seat, under a black plastic cover. I think I've heard it only puts out like 17 watts.
  17. Apr 13, 2017 at 5:16 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    I replaced all my speakers with Focal Integration series speakers. Sound is awesome.
    1UPPER likes this.
  18. Apr 13, 2017 at 5:24 PM
    Fishin1981
    Fishin1981 New Member
    2015 tundra limited crewmax
    Pop and lock, esp storage, access lorado, front tints
    If I replace the stock amp I will get more out of my speakers? Also, is it as easy as unplugging old one and replace with new one?
  19. Apr 13, 2017 at 5:27 PM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    Some people have done nothing but replace the amp and have said it was much better. I'm going to change out the speakers as well. You will need to get one of the harnesses from ********* or one of the other sources and you will need to run a power wire from your battery as well.
  20. Apr 13, 2017 at 5:39 PM
    1UPPER
    TEXAS
    Flux capacitor!
    Believe it or not Taco Tunes has people who have ship their Toyota vehicles to him from out of state. The plug and play amps are very easy to do.
  21. Apr 13, 2017 at 5:48 PM
    Borgs
    PA
    I believe it. I am a little too proud and am willing and do rip things apart (sometimes I can get it back together) on my own not to go through that trouble.
  22. Apr 13, 2017 at 5:49 PM
    Borgs
    PA
    nonJBL I assume? If so, did you mess with the amp?
  23. Apr 13, 2017 at 5:50 PM
    Borgs
    PA
    Imma go out and take a look.
    20manny1996 likes this.
  24. Apr 13, 2017 at 5:51 PM
    dandailey
    Dan D
    Newport News Va.
    Non JBL. I also replaced the HU ,and added a JL RD400/4.
  25. Apr 13, 2017 at 5:56 PM
    xj2202009
    x
    Lutz, Fl
    I run a pbr300 70watts rms x4 and it fits in the palm of your hand..
    Kept factory speakers..
  26. Apr 13, 2017 at 6:03 PM
    Fishin1981
    There have seen numerous posts about how the stock radio is sub-par with the rest of the truck. I have a '15 limited and my jbl in my Tacoma was so much better.
  27. Apr 13, 2017 at 6:04 PM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    It's amazing how much smaller they are making them now.
  28. Apr 13, 2017 at 6:06 PM
    xj2202009
    x
    Lutz, Fl
    Actually is design for a motorcycle and the whole thing is water seal
  29. Apr 13, 2017 at 6:50 PM
    Borgs
    PA
  30. Apr 13, 2017 at 6:51 PM
    Borgs
    PA
