Recovery strap points
Discussion in 'Recovery & Gear' started by T-Rex266, Dec 15, 2015.
  1. Dec 15, 2015 at 10:47 AM
    T-Rex266 [OP] Fuck Cancer Staff Member
    Anybody ever use the rear bumper bar (the bar under the bumper on the truck) to pull someone out? I have a D-ring receiver too, and need to get that on, but I've heard of this location too.
  2. Dec 15, 2015 at 11:18 AM
    JC303
    JC303 Same same but different
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    I have a d ring receiver. Smitty built I think. I have only used the bar under the bumper to pull snow tubes around the neighborhood and field by my house.
    zcarpenter92 and OR18TRD like this.
  3. Dec 15, 2015 at 11:19 AM
    JC303
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    @Sean266 is this how the top plastic part if ur bumper popped out?
  4. Dec 15, 2015 at 11:28 AM
    The recovery strapped pushed up on the bumper causing the black trim to push out...I popped it back in.
    JC303 likes this.
  5. Dec 15, 2015 at 12:29 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Probably not ideal but you could use the holes next to the hitch to pull out a light car. They should be strong enough as they are really used for the safety chains on a trailer if it so happens to fall of the ball.
    NewImprovedRon likes this.
  6. Dec 15, 2015 at 12:33 PM
    csuviper
    Broomfield, CO
    By rear bar are you talking about the hitch supports to the frame?
  7. Dec 15, 2015 at 12:34 PM
    Thanks for the pic dude. Ya, the black bar like this
  8. Dec 15, 2015 at 12:34 PM
    Wiscdave likes this.
  9. Dec 15, 2015 at 12:36 PM
    csuviper
    Broomfield, CO
    Yes it will take the load but use d-rings to clamp around the bar.
  10. Dec 15, 2015 at 12:43 PM
    csuviper
    Broomfield, CO
    You can do this too:
  11. Dec 15, 2015 at 12:44 PM
    csuviper
    Broomfield, CO
    Never over the ball:
    mlucas555, Smiley, 831Tun and 2 others like this.
  12. Dec 15, 2015 at 12:48 PM
    Ill just use my D-ring receiver =)
  13. Dec 15, 2015 at 12:50 PM
    csuviper
    Broomfield, CO
  14. Dec 15, 2015 at 1:01 PM
    csuviper
    Broomfield, CO
    That would be the best.
  15. Dec 15, 2015 at 1:01 PM
    csuviper
    Broomfield, CO
    f86sabjf likes this.
  16. Dec 15, 2015 at 1:08 PM
    I use a D-ring receiver. My factory hitch is massive. Not sure if you get a different one with the tow package but mine has several points that are fastened to the frame. I'd take a pic but I don't want to get cold.
  17. Dec 15, 2015 at 1:50 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    now that's clever!
  18. Nov 14, 2018 at 11:51 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    BUMP
    Since it's that time of year people get stuck in the snow.
    So question, if you are being pulled out (I know, a Tundra doesn't get stuck :muscleflexing:), what's the recovery point in the front? Is it these tow hooks, and if so, do you attach a D ring to this?
    539522d1439611744-need-rear-tow-hook-exp_508802581743e875c034db26becd5ebd7448ade3.jpg
  19. Nov 14, 2018 at 1:50 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Yes, that’s a good recovery point. Either use a shackle or choke your strap around the hoop by passing one end of the strap through the eye at the other end.
  20. Nov 14, 2018 at 3:29 PM
    TXMiamiFan
    Jose
    Thought about that too; wasn't sure if the strap could handle it. Also, good practice to stick something in the loop so after the pull the strap doesn't become so tight you can't un-loop it?
    rodm1, 831Tun and OR18TRD like this.
  21. Nov 14, 2018 at 3:34 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    I would not use the two holes next to your hitch where your supposed to put chains. I only had a chain that could fit in there and tried pulling out a small bush. And bent it and flaked paint off. I didn’t continue trying. I’m sure if it were life and death go for it. But just carry around a few d rings and a strap. I picked up a hitch with d ring assembly and it’s only about 6” and fits under seat really easy.
    kparrow, OR18TRD and TXMiamiFan like this.
  22. Nov 14, 2018 at 3:44 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    The choke works well but reduces the breaking strength of the strap/rope, not sure by how much but I'd guess 10-20%.
    joonbug likes this.
  23. Nov 14, 2018 at 3:52 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    joonbug likes this.
  24. Nov 14, 2018 at 3:59 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    It’s standard rigging practice. Called “choking”. Never binds up. Tightens when under load.
    Incidentally, those points on our vehicles are used for anchor points when transporting.
    TXMiamiFan[QUOTED] likes this.
  25. Nov 14, 2018 at 4:09 PM
    TXMiamiFan
    Jose
    ESP storage. Worth the money.
    fisherman951 and OR18TRD[QUOTED] like this.
  26. Nov 14, 2018 at 4:15 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    I've used the holes next to the hitch to pull my truck up hill rutted mud road about 80 yards with a come along. Flaked the paint but no bends.
    OR18TRD likes this.
  27. Nov 14, 2018 at 4:18 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Unfortunately doesn’t work when u have 3 car seats lol can’t move the seat as the car seats are anchored down
    Navi, rebs2 and OR18TRD like this.
  28. Nov 14, 2018 at 4:35 PM
    TXMiamiFan
    Jose
    True. But kids will grow out of the seats eventually :bananadance:
    OR18TRD likes this.
  29. Nov 14, 2018 at 4:37 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Then you get your grandkids!
    TXMiamiFan[QUOTED] and OR18TRD like this.
  30. Nov 14, 2018 at 4:37 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    Don’t forget rear facing
    OR18TRD[QUOTED] likes this.
