Recommended wheel torque
Discussion in 'Wheels & Tires' started by 2017tundraowner, Oct 3, 2018.
  1. Oct 3, 2018 at 6:41 PM
    2017tundraowner
    2017tundraowner [OP] New Member
    Hello im planning on installing new wheels they are 305/40r22
    And I believe the wheels are aluminum. This is going on a 2017 tundra double cab stock height. Thank you
  2. Oct 3, 2018 at 6:49 PM
    15whtrd
    15whtrd Mr. Blonde
    Most aluminum wheels I’ve delt with seem to be between 90 and 100 ft lbs. My stock aluminum wheels are 97 I think. Call the manufacturer?
    Rica25 and ColoradoTJ like this.
  3. Oct 3, 2018 at 6:52 PM
    2017tundraowner
    Thank you sir
    15whtrd likes this.
  4. Oct 3, 2018 at 7:45 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Replying here since your other post is a duplicate. It's 97ft·lbf for aluminum wheels and 154ft·lbf for steel for the front and rears.
  5. Oct 3, 2018 at 10:34 PM
    LEKS
    LEKS Truck name “Sancha”
    Makaha
    2013 Rockwarrior Supercharged
    I do 110ft lbs
  6. Oct 3, 2018 at 10:38 PM
    TunderStorm
    TunderStorm New Member
    Michael
    2018 TRD SR5 CM MGM +
    - Toytec/Eibach 3/1.5 + TC UCAs - Fuel Vapor 18x9+20 w/BFG KO2 35’s - TRD sway bar - Go Rhino nerf bars - badge delete - Bakflip MX4 - ESP storage - Rockford Fosgate 10’s +++ - TRD shift knob - Weathertech front mats - Escort 360 hardwired - Window tint Future mods: N-Fab M-RDS front bumper w/40” Black Series RC Lightbar
    We did 145 on my buddies stock lugs stock wheels and actually stripped a few of the lugs. Seemed extremely tight. So we backed off and did the rest at 110 ft lb
  7. Oct 3, 2018 at 11:09 PM
    2017tundraowner
    I just now finished putting it on. Couldn’t tell if it was steel or aluminum so went with 154
    Here’s the link to it lemme know if I should redo them if they are alloy instead.
  8. Oct 4, 2018 at 8:27 AM
    LEKS
    Makaha
    Those are aluminum for sure
    15whtrd likes this.
  9. Oct 11, 2018 at 11:31 AM
    SCSPerformance
    SCSPerformance #teamstealth Vendor
    Vin
    Bay Area, CA
    97ft lb is what Toyota recommends on their studs.
  10. Oct 11, 2018 at 12:16 PM
    bovavet
    bovavet New Member
    2010 SR5 crewmax, 2012 SR5 double cab ,2014 limited double cab, 2016 TRD PRO,2008 FJ, 2010 FJ
    I torque mine to 95#, on stock rims, I always go back and put the torque wrench on them again after 100 miles, I've had trouble with them loosening up a bit for some reason
  11. Oct 11, 2018 at 12:27 PM
    15whtrd
    15whtrd Mr. Blonde
    Most likely aluminum. Stick a magnet on to confirm. Steel would be much heavier as well.
  12. Oct 11, 2018 at 1:46 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Per Toyota:
    97 ft-lbs for aluminum
    154 ft-lbs for steel
    SCSPerformance likes this.
  13. Oct 11, 2018 at 3:08 PM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    I'm 110ft-lbs
  14. Jul 17, 2019 at 2:37 PM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    I have SCS Ray 10, what is recommend? Looks like 97 ft lbs.
  15. Jul 17, 2019 at 2:46 PM
    matictundra
    Franco
    AZ
    Yup
    georgiey22[QUOTED] likes this.
  16. Jul 17, 2019 at 2:50 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    154 is way too tight for aluminum. I would be worried about cracking them
  17. Jul 17, 2019 at 2:58 PM
    matictundra
    Franco
    AZ
    154 ft-lbs is for steel. 97 ft-lbs is for al.
  18. Jul 17, 2019 at 3:02 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Yes. OP said he set his at 154. I would removed, inspect lugs then re do if i were him
  19. Jul 17, 2019 at 5:20 PM
    georgiey22
    To keep it simple I torque to 100.
