Recommended Tire Pressure?
Discussion in '1st Gen Tundras (2000-2006)' started by Beefnbread, Jul 13, 2022.
  1. Jul 13, 2022 at 7:28 PM
    Beefnbread
    Beefnbread [OP] Electric Soup
    Oregon
    2000 SR5 Tundra 4x4
    Running 285 75r16s and just aired down to 35. Tire shop put them at 50.
    What are yall doing?
  2. Jul 13, 2022 at 8:04 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    I’m at 34psi front and 32psi rear. On 285x75r17 Toyo Open Country’s.
    I have 65k on my tires and plenty of tread left.
    I get better fuel mileage at 36/36 but it rides rough and doesn’t wear even.
  3. Jul 13, 2022 at 8:10 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    38psi same tire 285/70/17 D load maybe?
    des2mtn likes this.
  4. Jul 13, 2022 at 8:13 PM
    Casper421
    In the woods
    06 DC
    38-40
    des2mtn and FrenchToasty like this.
  5. Jul 13, 2022 at 8:39 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    Mine are E-Rated
  6. Jul 13, 2022 at 9:00 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    34 in front to compensate the weight in front, right? Mine bubble there at the bottom ever so slightly.
    Diablo169[QUOTED] likes this.
  7. Jul 13, 2022 at 9:06 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I'm on the same and about to drop them from 35psi. I'll try your numbers.
  8. Jul 14, 2022 at 9:33 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    This is a great tool for getting air pressure right when moving to a different size or load rating tire.
    Siebler likes this.
  9. Jul 14, 2022 at 10:38 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    I'm running the same size tire as you and I'm running 35 front and 34 rear. The only weight I have in the back is the topper. Seems to be the best balance of smooth ride and tread engagement.
    I have E-rated tires, and thought about airing them up to 45 for a lot of highway, but haven't bothered.
    The tire pressure calculator above mentioned by @frichco228 is a great resource.
  10. Jul 14, 2022 at 2:49 PM
    gascap
    gascap New Member
    2002 Tundra
    Unless tire manufactures stopped putting their recommended air Pressure on their tires...go by what's marked on their tires for normal use.
    dbittle likes this.
  11. Jul 14, 2022 at 2:53 PM
    Jim the Jarhead
    Jim the Jarhead New Member
    2017 SR5 4X4
    44psi back 40 psi front tire recom at 45psi.... fwiw...
  12. Jul 14, 2022 at 2:59 PM
    nickrick78
    nickrick78 New Member
    Nick
    Pittsburgh PA
    2004 DC
    Start at 40 and do a chalk test, air up/down a little at a time and retest until the chalk wears off the tread evenly
    FrenchToasty likes this.
  13. Jul 14, 2022 at 4:42 PM
    The pressures listed on the side of the tire are max inflation pressures when cold. Not necessarily the recommended inflation pressures. More air in the tire adds more weight carrying capacity. If your not hauling, then less air can smooth the ride out a bit and give a better tread contact patch.
    Kimosabe, des2mtn and gascap[QUOTED] like this.
  14. Jul 14, 2022 at 5:17 PM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    My E rated 285 75 16's paired with the stuff lift and all gets pretty squirrely over bumps/ dips on these AMAZING western OR freeways when im over 40psi on the front.
    Ran 600ish miles at 38lbs and it is much better but believe may continue to drop before the next trek East this week and willl report back.
  15. Jul 14, 2022 at 7:19 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    I’m liking how it rides both highway and in city at 35. While I was at 50, it seemed my truck had a wandering problem on the highway... Like it had a mind of it’s own haha. Alignment is near perfect. Maybe 45 might be a smidge too much.
    Anybody get highway vibrations running this size of tire?
  16. Jul 14, 2022 at 8:20 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    That literally makes no sense.
    My 99’ Tacoma had E rated KO2’s on it. Truck rode so damn harsh it was ridiculous.
    Check tire pressure, Costco set them to 80psi cause that is what was on the side wall. :frusty:
    They are now set to 26psi.
  17. Jul 15, 2022 at 8:36 AM
    gascap
    gascap New Member
    2002 Tundra
    ^^^Here's what KNABORS stated to my comment, and it shook my cob webbed memory right. Personally, I don't worry about tire psi as long as they're around 35. Have always put 35 in tires unless I was told that tires run at a specific psi. For example, had a Titan XD Cummins 5.0 with 20" rims that needed more than my accustomed 35 psi.
    "The pressures listed on the side of the tire are max inflation pressures when cold. Not necessarily the recommended inflation pressures. More air in the tire adds more weight carrying capacity. If your not hauling, then less air can smooth the ride out a bit and give a better tread contact patch."
    His statement is correct, and should make sense to you.
  18. Jul 15, 2022 at 10:35 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    Sounds like you've found a good number.
    I calculated mine based on the tire manufacturer's tire pressure charts. You should have a tire pressure chart where you can get the pounds/psi and calculate based on the weight of the truck. There's a sticker on the door frame with front and rear weight and you can factor in any extra weight you're carrying.
  19. Jul 15, 2022 at 10:42 AM
    Siebler
    CJ
    Eastern Oregon
    Exactly what I was describing happens to my rig at over 40psi or so. Dropping to 38 vastely improved handling for me and I imagine 36 will feel even better.
  20. Jul 15, 2022 at 1:36 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    My truck was shipped from the factory with 265/70R16 (the same I run today). The door sticker specifies 26 PSI front, and 29 PSI rear. I run 32 PSI all around. The "chalk test" seems to support that.
