Recommended Service on ‘13 CrewMax with 110k+
Discussion in '2nd Gen Tundras (2007-2013)' started by NewTundraAdmirer, Jul 28, 2021.
  1. Jul 28, 2021 at 9:20 PM
    NewTundraAdmirer
    NewTundraAdmirer [OP] New Member
    Central Florida
    2013 Toyota Tundra SR5 CrewMax
    Hi Gents,
    I have been busy with work so I haven’t had the time to get the pics of my new Tundra (Coming Soon) - Aside from the GAS expenses, I LOVE the truck and the ride.
    I was wondering given that I recent bought the truck with 108k+ miles - are there more services and or maintenance items (aside from Oil/Filter) I need to address?
    According to the CarFax - there were no mention of the Serpentine belt being changed and I know that 2nd Gen Tundras can have the “Secondary Air Inject Pump ” fails “ - around 75 - 111k miles according to other past forums. I won’t be going on a long trip (500+ Miles) as of yet, but would like to get some good maintenance done.
    I have seen on YouTube & read some forums of the Engine blowing up - and I would rather be safe than in tears.
    Any Suggestions are happily welcomed!
    ~NewTundraAdmirer
  2. Jul 29, 2021 at 7:01 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    at that age, miles- engine and cabin air filters, spark plugs, check belts condition, if you have the small v8 change timing belt, drain and fill differentials, coolant, trans, xfercase, grease all driveline or suspension zerk fittings. Check or change brake fluid. That would bring everything up to where it needs to be and while you are doing the work you can check out the rest of the truck and see if there are any leaks or other items than may need replacing.
  3. Jul 29, 2021 at 7:07 AM
    timsp8
    NY
    NewTundraAdmirer[OP] likes this.
