Recommended rotation with KO2s?
Discussion in 'Wheels & Tires' started by rocsteady, May 12, 2022.
  1. May 12, 2022 at 6:50 AM
    rocsteady
    rocsteady [OP] New Member
    Dave
    New Jersey
    2021 Super White SR7 Double Cab SX
    I attempted to engage my search-fu and wasn't successful. First time I've had new AT tires, BFG KO2s and want to know how often they should be rotated. I'm pretty sure I'd seen something about doing it every 3-5K, with every oil change but I'd like to see what you all think and have experienced.
    Reading other threads, appears that front to back is preferred, but how often and do these big, heavy things need to be balanced at the same time or do you just rotate them if you're not experiencing any vibration or other issues?
    Thanks very much for any input or direction to existing thread if I've missed it.
  2. May 12, 2022 at 6:54 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    I rotate my Wildpeak AT3s every 5k miles. 4x4 I use #3 (rearward cross).
    Taco-Spike likes this.
  3. May 12, 2022 at 6:55 AM
    Taco-Spike
    Two Trucks
    5k should be fine. I always do front to rear and it's been fine.
    I've never had to redo a balance BUT alignments seems to come up every few years.
    rocsteady[OP] likes this.
  4. May 12, 2022 at 10:00 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    5k miles, always! Not just rotation, but rotation and balance.
  5. May 12, 2022 at 10:43 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    You balance every 5k? How often is it out?
  6. May 12, 2022 at 10:59 AM
    frichco228
    There are balance corrections every time I have them rotated, without fail, with any brand AT tire that I have ever run. Balance and rotation every 5k miles is the single most effective thing you can do to get the most out of your tires, aside from running correct air pressure.
  7. May 12, 2022 at 1:11 PM
    sbxx312
    sbxx312 New Member
    2018 Tundra, 2012 s/c Tacoma
    I rotate mine every 3-4k at my oil change. I would go much over 5k with the KO2s or the shudder might come.
