Recommendations, rubber/vibration coating for plastic parts?
Discussion in '2.5 Gen Tundras (2014-2021)' started by TonyNCo, Oct 10, 2020.
  1. Oct 10, 2020 at 7:49 PM
    TonyNCo
    TonyNCo [OP] New Member
    Tony
    2019 VooDoo Blue TRD Pro
    Audio, 11 channels Kenwood HU, Mini DSP Digital Sound Processor 2 Alpine 4 Channel Amps, 3 Alpine Sub Amps approx 4K watts 3 way Focal in dash, front doors. 6 1/2" in door swapped for 8" 10" Focal Sub, front passenger floor, custom sealed box 2 way Focal rear doors 2 JL Audio 12W6 Subs, behind backseat Aux lights, all but ditch on modified bumper light bar (3 Hella Rally 4000) Spot, Fog, and Euro beam. Euro beam has yellow bulb. 4 White Spot beam LED Ditch 4 Yellow Spot beam LED 42" Curved, Yellow/Fog LED light bar 50" Curved, White LED light bar 295/70/18 Falken Wildpeak, Revolver Bed Cover
    I would like to paint a rubber or similar coating on some door and other interior pieces that are rattling with the new stereo install. Hard part seems to be adhering to plastic.
  2. Oct 10, 2020 at 8:00 PM
    buckrub71
    buckrub71 Like Father, Like Son--Semper Fi
    2016 Bronze 1794 CM
    Check out butyl sealant tape, sound deadner and closed cell foam. I'm not sure to the areas you are referring but the above items as well as mass loaded vinyl is what I used for my audio overhaul. There are many installs on this forum which tipped me in that direction. You can get as thorough (crazy) as you want. It's time consuming but well worth it. For me, nothing vibrating.
    Black Wolf likes this.
  3. Oct 10, 2020 at 8:30 PM
    TonyNCo
    Tony
    I have been using Kilmat. My noise source is the door panel inset where the plastic piece the holds the window switch mates up. The edge of the window switch plate vibrates against the door panel. I am going to pop off tomorrow, and try to add a little Kilmat. I noticed the issue out driving. Thought about some type of rubber coat, spray on, that would be thin, yet dampen.
