Recommendations on forklift and airbags
Discussion in '1st Gen Tundras (2000-2006)' started by Unmbra_SCI, Dec 9, 2023.
  1. Dec 9, 2023 at 5:48 PM
    Unmbra_SCI
    Unmbra_SCI [OP] New Member
    Joe
    First gen Tundra
    I’m putting a 1500lbs camper in my bed and I need a torklift tie downs and an airbag or helper leaf. Anyone done this? Recommendations?
  2. Dec 9, 2023 at 7:18 PM
    Several have done helper bags. There's quite a few posts on that. What'd you want to know? Big thing on bags is never to plumb them in a way that they share air.
    Aerindel and whodatschrome like this.
  3. Dec 9, 2023 at 8:51 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    My donor project 2004 2wd tundra had airbags and the front Torklift brackets, but when i purchased the truck, someone had previously removed the airbags. They left the airlines, schrader valves, and Torklift brackets though. I would have REALLY loved to have those airbags!
  4. Dec 9, 2023 at 11:05 PM
    Aerindel
    Aerindel New Member
    Montana
    Sure. I used Air Lift brand. They work.
  5. Dec 10, 2023 at 8:01 PM
    Unmbra_SCI
    Joe
    First gen Tundra
    Im looking at these airbags but it says 2001-2006. Mine is 2000 am I correct in assuming they will work on a 2000?
    Also it says that I can only use this with stock tires but I think I have plenty of room with my 265/70 R17. What do you guys think?
    https://pacbrake.com/hp10126-alpha-hd-rear-air-suspension-kit-for-2001-2006-toyota-tundra.html
    I got these Torklift tie downs. 887$ after tax! Yicks!
    https://www.amazon.com/gp/product/B073X48V36?ie=UTF8
  6. Dec 10, 2023 at 9:27 PM
    whodatschrome
    lots of dents
    Ouch! That really stings. I don't have any experience with the Pacbrake brand. I've had the Firestone double convoluted airbags in my 95 Cummins, 98 Cummins, 71 F250 flatbed, 77 F250 lowboy. I have had zero issues with any of them.
    As for tire size, 245/70-16 was a stock size option on the 2000 model (including the 4wd trucks). The other optional size is a 265/70-16. I think that your 265/70-17 will be narrow enough to have clearance for all of the airbag brackets. But with that tall tire size of yours, the 3.90 gear ratio is going to suck big time hauling around that much weight. I'd be tempted to install a tire that's the same height at a LT 245/70-16 (or whatever that equals to in a 17" rim). A smaller tire will also lower your center of gravity a little bit for that tall heavy load. Plus if you have a v8, then i'd also lower the ring and pinion to a 4.10 at a bare minimum! Your engine, transmission, and fuel economy will thank you.
  7. Dec 10, 2023 at 9:32 PM
    Unmbra_SCI
    Joe
    First gen Tundra
    Great advice. I’ll talk it over with my mechanic and see what he says. Thanks! I do have stock wheels with snows on them right now. I really like my more aggressive off-road wheels though. She looks so small with stock tires on her. Probably best to not go on too rough of trails with that much weight anyway.
  8. Dec 10, 2023 at 9:54 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    I can’t imagine how miserable driving a 1st Gen would be with a 1,500lb camper.
    My mom has one in her F250, and it handles horrible.
    I have Firestone bags on my Tundra, and it’s a nice kit.
    shifty` and whodatschrome like this.
  9. Dec 10, 2023 at 10:04 PM
    Unmbra_SCI
    Joe
    First gen Tundra
    I’m definitely considering Firestone but I like that the ones I posted don’t require putting holes in the frame. Maybe it’s not a big deal?
  10. Dec 10, 2023 at 10:35 PM
    whodatschrome
    lots of dents
    It’s not a big deal whatsoever to drill holes.
    And taking a much closer look at the Pacbrake bags again, to me it looks like the single convoluted airbag doesn’t have the same about of travel that a double convoluted bag would have? Perhaps it’s just the angles of the Pacbrake’s stock photos? But it seems like it would greatly limit suspension travel? Not that you’re looking to gain suspension travel when hauling heavy loads, but i wouldn’t want to limit the current stock suspension travel.
  11. Dec 11, 2023 at 6:28 AM
    Unmbra_SCI
    Joe
    First gen Tundra
    Wouldn't this vary depending on PSI? It says you can run them from 10-100psi I assume you can air them down and not have such a stiff ride?
  12. Dec 11, 2023 at 7:39 AM
    whodatschrome
    lots of dents
    Yes, it would also vary with PSI. I’d look into the specs and dimensions of the PB’s airbags. Firestone has all of their’s listed online (you’ll have to do some searching to find them). I suppose if you always have 2000lbs in the bed of the truck (1500lbs camper, plus another 500lbs of water, food, blankets, pillows, cookware, propane, maybe a couple tools, ect) and never have less than 80~100psi in the bags, then you can afford to loose “x” amount of suspension travel. Who knows, perhaps i’m over thinking it, but way back when i first installed airbags in my trucks, i researched what their compression and extension heights were in order to make sure i wasn’t hampering my suspension.
  13. Dec 11, 2023 at 8:51 AM
    Unmbra_SCI
    Joe
    First gen Tundra
    1500 is wet weight. It’s like 1200 dry.
    Pics for fun.
    whodatschrome[QUOTED] likes this.
  14. Dec 11, 2023 at 12:19 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    My camper setup is similar to the one above. About 1250 lbs empty and 1500 fully loaded.
    I went with Firestone airbags and they have been great. I got the dishes for the bottom instead of bolting the bottom of the bags to the bottom brackets. I have a lift and didn't want to lose travel because of the airbags. I've read about people buying the Amazon version of the firestone knockoff and having good luck with durability and longevity. But it's hard to want to risk an airbag blowout without knowing how they actually hold up. I also have e-rated tires (285/75/16) which are more confidence inspiring when taking the truck and camper offroad to get wherever it is we are going.
    whodatschrome and Unmbra_SCI[OP] like this.
  15. Dec 11, 2023 at 12:22 PM
    Yeah yeah, nice camper. Tell us about this fog light mod!!
  16. Dec 11, 2023 at 12:24 PM
    Unmbra_SCI
    Joe
    First gen Tundra
    How’s the truck performance? MPG? How sluggish does it feel? I have on board air for off-road applications. Would having that much weight make airing down for rough roads a bad idea? I’d hate to de-bead from all that weight.
  17. Dec 11, 2023 at 12:28 PM
    Unmbra_SCI
    Joe
    First gen Tundra
    XLux! I love them! It’s a new company but the guy who started it is the light engineer who designed a bunch of the rigid lights. I have fog and amber drive lights from them in the factory fog cavities. Can’t recommend them enough! The Amber Drive lights are my favorite lights on the truck for sure.
    KNABORES[QUOTED] likes this.
  18. Dec 11, 2023 at 12:46 PM
    Illegal in some states though. There are quite a few states that forbid more than four forward-facing lights, and/or more than two forward-facing fog lights. I can't remember if California is one - it may be they let you have 4 forward-facing lights and 2 fog lights. Other states, it's 4 lights total.
    That picture reminds me of a damn UFO abduction, like something you'd have seen in that River Phoenix etc. movie "The Explorers" from the '80s.
  19. Dec 11, 2023 at 1:11 PM
    Unmbra_SCI
    Joe
    First gen Tundra
    I thought you just couldn’t have them lit on streets? I never run more than 4 on at once on streets. The fogs and amber drive lights are on separate switches. I only run everything on at once on dark forest roads where the risk of blinding people is really low.
    I think Cali requires them to be covered in streets which is fucking dumb. Colorado is kinda just don’t be an ass hole from what I can tell
  20. Dec 11, 2023 at 1:16 PM
    I dunno, even in GA it's a max count of four headlights, I didnt' see mention of "on", "off", or "covered" when I clicked through on the result that had this text:
  21. Dec 11, 2023 at 1:20 PM
    Unmbra_SCI
    Joe
    First gen Tundra
    Yeah no one in Colorado is getting ticketed. Every third truck on the roads in Denver is breaking that law. Again it’s kinda be respectful and don’t have your fucking light bar on when on the street. I would encourage cops to pull people over for breaking that law but if they are off when they should be off it doesn’t seem to be a problem out here. I’ll definitely be worried when I drive this baby to Alaska this summer though.
    shifty`[QUOTED] likes this.
  22. Dec 12, 2023 at 9:48 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    It's certainly sluggish. I live in the mountains so the mountain passes are slow going, but on flat interstate I can maintain the speed limit (80mph in Idaho). Gas mileage depends on either interstate or mountains and I just accept it and keep an extra 5 gallon can in the back just in case cuz gas stations can become sparse at times here.
    I don't air down so I can't offer any advise there. Mostly, I'm driving to rock climbing destinations and just need high clearance or sometimes 4WD and I can get everywhere I need to. I like the e-rated tires to lower risk of a flat tire since our dirt roads have lots of rocks.
    Aerindel likes this.
  23. Dec 17, 2023 at 11:58 AM
    Unmbra_SCI
    Joe
    First gen Tundra
    Ok so I got the Tork lift system installed but I’m stuck on the bags. Seems the inside upper bracket of the air bag is too short. The kit says 2001-2006 but I have a 2000. Is the leaf system different on the 2000 for since reason?
  24. Dec 17, 2023 at 10:54 PM
    whodatschrome
    lots of dents
    It looks like there's two different kits for the 2001-2006 tundras. According to Pacbrake, the difference between the kits are the brackets.
    -2001-2006 TOYOTA TUNDRA (2WD/4WD.) P/N HP10126
    -2001-2006 TOYOTA TUNDRA (2WD/4WD) Trucks in which the upper jounce bumper pad protrudes 1" below the frame. P/N HP10158
    Look at page 7 and 8 in the instructions and you can see the two different styles of brackets... https://pacbrake.com/mm5/pdfs/L6010.pdf
  25. Dec 18, 2023 at 12:14 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    Ya I think you got sent the wrong part or something. I have the firestone setup and the brackets were drilled into the frame.
  26. Dec 18, 2023 at 6:21 PM
    Unmbra_SCI
    Joe
    First gen Tundra
    They are going to send me the correct bracket. Talked to them today :(
    Its my own fault, I didnt see that part. I thought 2000-2006 was all the same. Why would there be 2 jounce set ups?
