Recommendations on a cheaper end 1911
Discussion in 'Guns & Hunting' started by IowaGuy, May 9, 2023.
  1. May 9, 2023 at 9:40 AM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    I am starting to look for a cheaper end 1911 that is accurate, reliable and has standardized parts. I have already own a Dan Wesson that I have had customized and tuned. I haven't kept up on guns or brands so I thought I would ask here to see what the latest going flavor is. I thought about a RIA as I have looked at them in the past.
  2. May 9, 2023 at 9:54 AM
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    My SA Milspec was 530 a few years ago. Main shortcoming I heard was it is not as easy to change the grip safety as other models. So not one I'd get if you want or might eventually want a beaver tail.
    MrNice2U likes this.
  3. May 9, 2023 at 10:05 AM
    SD Surfer
    Bruce
    So Cal
    I've not shot a RIA but have heard mostly good things, and the price is good.
    Not sure where your "cheaper end" range stops, but I'm real happy with my SA Loaded's. Kinda' mid-range money.
    FYI, I know some 1911 purists consider it blasphemy, but my 9mm Loaded is a super fun tack driver, and a little cheaper to feed.
  4. May 9, 2023 at 10:08 AM
    blenton
    blenton New Member
    SA Ronin. In 10mm :D
  5. May 9, 2023 at 10:21 AM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    I may get flamed here but I’ve had a Taurus pt 24/7 for a while and it has never given me a single problem. If your just looking to send some rounds down range I would recommend looking at Taurus
  6. May 9, 2023 at 10:23 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I had an RIA tactical in 9mm back in my 1911 obsession a few years ago.
    It didn't like cheap reman ammo, but none of my 9mm 1911s did either.
    Not a bad firearm for the price..
    Sold it after buying the Dan Wesson, which I ultimately sold as well..
    Although the DW was probably one of the most accurate firearms I ever owned.
    48e2df32-3f8c-4e66-a291-b447352c832f_zps_5c0962d3de1ae151c97b9fee89a1fee22932b858.jpg
  7. May 9, 2023 at 11:26 AM
    JimBeam
    JimBeam Moderator Staff Member
    South Carolina
    2015 Limited
    Tisas is importing some very above decent, reasonably priced 1911s right now
  8. May 9, 2023 at 8:07 PM
    kevine0001
    kevine0001 New Member
    Kevin
    I have an RIA Citadel model. Slide has more serrations, better trigger and hammer, and I believe other internals upgraded from stock RIA 1911. Came with 3 mags for about $500 used, several years ago. Swapped out the wood grips for Hogue. It's a solid firearm, accurate, and even got all 9s and 10s when I certified with it for my CCW.
  9. May 10, 2023 at 7:42 AM
    SD Surfer
    Bruce
    So Cal
    That DW Bobtail though... Yowza! :bananadance:
  10. May 10, 2023 at 10:38 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    If you can find a used Para 1911 it should be pretty inexpensive and the quality is phenomenal. Unfortunately they don't make them anymore, but quality 1911 parts from other manufacturers work if you ever need them.
    I got this one for $350 used at a Cabellas a few years ago. I love it because it didn't cost a fortune and is 100% reliable. I've got other 1911s and some 1911 model variants that are far more expensive and this one can hang.
  11. May 10, 2023 at 10:39 AM
    Backslider
    Tooele, UT
    This is the part where I point out that Dan Wesson is a CZ company. If you want that same quality in a modern-frame pistol, get a CZ. Not that I'm a fanboy or anything...
    Booney and SC4333 like this.
  12. May 10, 2023 at 10:40 AM
    Backslider
    Tooele, UT
  13. May 10, 2023 at 9:44 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    I've handled a lot of CZ pistols in gun shows and shops over the years.
    They always felt good in the hand, but I never bought one..:eek2:
    Not a fan of DA/SA with a decocker, except my WG Sigs.
    I'm sure CZ makes a DAO, I've just never seen one locally, as well I don't go to gun shows anyone...:thumbsup:
  14. May 11, 2023 at 8:04 AM
    SD Surfer
    Bruce
    So Cal
    My CZ's ergonomics fit me like they were made from a mold of MY hand. The most intuitive and naturally pointing handgun I've had, with the 1911 a very close second.
    I can look at an object or spot on the wall across my 20' bedroom with the (empty) CZ in my hand, then close my eyes and present the weapon and be spot on. (or at least center mass)
    I have a few things to choose from, and the CZ SP-01 top right is what goes on the nightstand when I lay me down to sleep, pray the Lord my soul to keep... And the little P-01 next to it is what goes camping with me. (You know, gotta' conserve space and weight in the RV.) :p
  15. May 11, 2023 at 1:16 PM
    Backslider
    Tooele, UT
    Agreed 100% on ergonomics.
    I also have an SP-01 and a P-01 and really enjoy both of them, but the P-01 is my take anywhere, everywhere, always gun.
    SD Surfer[QUOTED] likes this.
  16. May 11, 2023 at 2:15 PM
    SD Surfer
    Bruce
    So Cal
    I like the OD Green!
  17. May 13, 2023 at 3:50 PM
    IowaGuy
    In Process
    I think I want a commander length in 9mm.
  18. May 13, 2023 at 4:02 PM
    blenton
    blenton New Member
    Fixed it for ya…:D
  19. May 14, 2023 at 8:40 AM
    hey smell this
    hey smell this New Member
    Houston
    2016 Tundra TSS
    IMG_5913.jpg IMG_4939.jpg IMG_4938.jpg 6 months ago I had the sudden urge for a 1911. Just wanted a .45 range toy and didn’t want to spend much money. I settled on Taurus bc it looked good and fit my budget. And I’ve got no complaints. I don’t have the experience with other brands to compare but I can say the Taurus feels solid, is accurate, and has never misfired. I love the way it looks.
    I have several Taurus guns bc I like the look and price and I’ve had good luck with all.
  20. May 14, 2023 at 8:46 AM
    hey smell this
    Houston
    2016 Tundra TSS
    I will defend Taurus. I’ve read about the quality problems but those seem mostly in the past. Half of my current handguns are Taurus (1911, .22, three revolvers) and I’ve got zero complaints with any. They fit my budget and I like the aesthetics. Just fine for me for range toys.
    My defense pistols are Glock Canik and Springfield but I’d have no fear trusting a Taurus.
  21. May 14, 2023 at 1:00 PM
    belairbrian
    belairbrian New Member
    2016 Crew Max 4x4 TSS
    Interesting about grips. I've had my SA Commander for years and put the Hogue on just after I got. Now has a Houge Laser grip.
  22. May 31, 2023 at 5:00 PM
    blenton
    blenton New Member
    I feel the same way. Not sure if it’s fully warranted as I don’t recall ever having problems with a Taurus. I did, however, have big issues with a S&W Shield 2.0 that didn’t like to go in to battery. It would hang up just at the last mm of engagement as the slide and barrel moved forward. It was almost visually imperceptible until you realize you have a dead trigger. Full magazine was the worst, but it would do it with out a magazine at all. Yes, rack and slap it would fix it, but I never trusted it. Sent it in 3 times and it always just came back with sand in it. Demonstrated it to the dealer and they just said ‘You need better training’. While I wouldn’t disagree 100% with the statement itself, the logic is flawed. I’ve never had that issue with any other pistol. Purposely riding the slide on reloads, limp wristing while racking the slide, using the slide catch as a release mechanism instead of slingshotting - whatever I tried on other pistols I couldn’t get them to replicate the SW issue. So I moved on.
  23. May 31, 2023 at 5:56 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Keltec for the win, if they make a 1911 model, which I doubt. I would also be very apprehensive about sooting it if they did so....biggest pos ever. Inherited one from an Uncle. Junk!!!!
  24. May 31, 2023 at 6:12 PM
    Tundra Dude 45
    Tundra Dude 45 New Member
    Eric
    2019 SR 4.6L DC 4X4
    8” BAMuffler, TRD airflow accelerator, front window tint/windshield sun stripe, debadged tailgate 4x4 emblem, trimmed mud flaps, antenna removed stainless screw added, TRD rear sway bar, AFE high flow air filter.
    The cheapest 1911 I recommend is a full size 45 acp Springfield Armory Mil-Spec. I’ve had one and it ran great. I did buy a Tisas Tanker 1911 (4.25” barrel) and I loved the size but after a few magazines I’d get feeding issues/fail to return to battery. I traded it in shortly after, I never keep firearms that aren’t reliable. I used new Wilson magazines and a few hundred rounds thru it to “break it in” but is was never 100%. Try to get a 70 series if possible, the way it was originally designed. I did have a new Colt 70 series full size that was excellent.
    equin likes this.
  25. Jun 1, 2023 at 3:12 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I got a SA Milspec “Defender” series about 4 years ago. I believe it’s the same as a regular Mildpec but a little cheaper since it came in a cardboard box instead of a plastic case and with only one mag instead of two. Maybe there are other minor differences, but mine has been flawless with no issues after almost 1000 rounds of a variety of whatever cheap FMJ and JHP I could find.
    Tundra Dude 45 likes this.
  26. Jun 1, 2023 at 3:35 PM
    equin
    Ed
    DFW, TX
    Here’s mine:1A9CE4CA-79CA-4A0B-9F9B-9D549B7EFC6D.jpg
  27. Jun 1, 2023 at 4:13 PM
    IowaGuy
    In Process
    As a follow-up to an old thread I just ordered a Tisas 1911 Carry B9 9mm 4.25" 10rd Ed Brown Bobtail for $550 shipped to my dealer including transfer.
  28. Jun 6, 2023 at 7:15 PM
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    I was looking into that Tisas today and discovered the full-size .45 version
    Looks like when added to cart it could be had for $420 shipped. So id be all in $440.
    https://battlehawkarmory.com/product/sds-1911-b-45acp-5-blk-8rd-eb-bobtail-1
    did you pickup yours from FFL yet? Any further opinion on it?
  29. Jun 7, 2023 at 6:00 AM
    IowaGuy
    In Process
    Family Firearms is where I ordered mine from and they already had my FFL on file.
  30. Jun 7, 2023 at 6:39 AM
    Musicmasterd12
    Southern Louisiana
    I was wondering if it had come in yet and you were actually able to handle it in person. But then I realized it’s been less than a week bc i don’t even know what day it is anymore :rofl:
