Recommendations for smoother ride
Discussion in '2.5 Gen Tundras (2014-2021)' started by wwolvverine, Dec 16, 2018.
  1. Dec 16, 2018 at 7:09 PM
    wwolvverine
    wwolvverine [OP] New Member
    2018 Tundra 1794
    Is it just me or are Tundras Jittery in their ride. You go over a small bump or crevice and you feel the rattle like for 2 seconds. I am considering getting some Michelin LTX's on the truck maybe it will help. Maybe its a shock dampening thing, any recommendations?
    Thanks,
    Rica25 likes this.
  2. Dec 16, 2018 at 8:32 PM
    snarkscarbine
    snarkscarbine New Member
    Alex
    Dallas
    2014 Silver Sky CM Ltd 4x4
    Bilstein 5100s Footwell LEDs Fold-A-Cover g4 elite TRD 18s
    Swapped my front shocks to 5100s on the middle setting and it helped a bit. Swapping from 20s to 18s also helped.
    bmcdds and Rica25 like this.
  3. Dec 16, 2018 at 8:36 PM
    Shelbie67
    Shelbie67 New Member
    Blake
    NorCal
    2018 tundra crewmax platinum
    RADFLO 2.5 suspension, apex rock sliders, BFG KO2, exhaust delete, Full Active Stereo
    What shocks you have now? Yellow or black?
    Rica25 likes this.
  4. Dec 17, 2018 at 9:10 PM
    phabej
    phabej New Member
    NO LONGER HAVE A TUNDRA... Waiting
    I think mine Jitters.. o well it ain't smooth like a Chevy.
    Rica25 likes this.
  5. Dec 17, 2018 at 9:16 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Aside from suspension upgrades, playing with tire pressure can also help.
    OR18TRD, 15whtrd and Rica25 like this.
  6. Dec 17, 2018 at 9:32 PM
    Rica25
    Ricardo
    Tulare
    What a good tire pressure you guys have found
  7. Dec 17, 2018 at 9:38 PM
    equin
    Ed
    DFW, TX
    I'm guessing it depends on the tire and your load. Usually, the lower the psi, the softer the ride. But too low can be risky, especially if carrying a load or towing.
    Inquiringone, OR18TRD and Rica25 like this.
  8. Dec 17, 2018 at 9:39 PM
    Rica25
    Ricardo
    Tulare
    I run my Nitto RGs 295 70 18 at 33 psi
  9. Dec 17, 2018 at 9:42 PM
    equin
    Ed
    DFW, TX
    When traveling with no load, 30 to 32 psi has less of harsh ride for me at least, but I like to keep mine around 36 to 38 for the most part.
    Rica25 and 15whtrd like this.
  10. Dec 23, 2018 at 6:24 PM
    wwolvverine
    2018 Tundra 1794
    I got 30psi front and 33 psi back. Ride is way to jittery, i mean bone shaking. I might do as a poster said, try front new adjustable shocks.
  11. Dec 23, 2018 at 6:25 PM
    wwolvverine
    2018 Tundra 1794
    Black!! Originals that came with truck brand new. maybe its the original crap bridgestones tires.
    Rica25 likes this.
  12. Dec 23, 2018 at 7:06 PM
    Shelbie67
    Blake
    NorCal
    Tire pressure has a big effect, but rear shackle has some to do with it
    Rica25 and equin like this.
  13. Dec 24, 2018 at 4:45 PM
    bmcdds
    bmcdds New Member
    CA
    2019 Barcelona Platinum
    Did the exact same thing.
    Rica25 likes this.
  14. Dec 24, 2018 at 4:51 PM
    bmcdds
    bmcdds New Member
    CA
    I had Cooper ST Maxx 295 70 18s installed at America's Tires on Black Friday. They had them inflated to 40 psi on all four. The same day, took the truck to Toyota for the airbag recall software update and a few weeks later to replace a faulty battery, and they didn't change the pressure at all. I called Cooper and gave the guy I spoke with the GWV weight, original psi recommendations, and current psi. He calculated that 35 up front and 37 in the rear was what he recommend.
  15. Dec 24, 2018 at 7:14 PM
    tundracap
    tundracap New Member
    NC
    2017 CM Limited 4x4 Silver Sky Metallic
    You went with tires that kept the same overall diameter as the 20's were running?
    I assume the better ride would be from more air between rim and road?
    Rica25 likes this.
  16. Dec 24, 2018 at 7:21 PM
    snarkscarbine
    Alex
    Dallas
    As I recall the first set were 265/60r20 and the replacements are 275/65r18s.
    Yeah you got it; just more air. Made a pretty noticeable difference.
    Rica25 likes this.
  17. Dec 24, 2018 at 8:26 PM
    Spitfire
    Spitfire New Member
    Long Island
    2018 Cement Limited Trd off road
    The black ones are actually smoother/softer.. the stock trd 4600 which are same as the 5100s which are more jittery bc they are stiffer.. eat up bigger bumps better then the black ones.
    Rica25 likes this.
  18. Dec 24, 2018 at 9:48 PM
    blizz86
    blizz86 New Member
    Depends on the roads.. sectioned concrete highways will rattle your brains out. Its a half ton pick up so nothing will make it feel like a camry or much less a 4runner. Weight in the bed will smoothen things out but not make it creamy smooth.
  19. Dec 26, 2018 at 4:34 PM
    wwolvverine
    2018 Tundra 1794
    I have asked around and its not just the Shocks. Springs make a big difference and so do the over leafs. Apparently if you take the latter out completely the jitter goes away. Wow, you are talking about 3 changes to the Toyota Tundra just to get a decent ride. 1) Adjustable Shocks 2) springs 3) Over leafs. And if you do all 3, your ability to carry massive loads of weight are gone, but i really don't care.
    Rica25 likes this.
  20. Dec 26, 2018 at 4:36 PM
    wwolvverine
    2018 Tundra 1794
    I don't care what anyone says the Toyota Tundra has the worst ride of all Pick-up trucks, this truck rattles your spine. For the money you pay for these thing it should not be the case. You go over a sewer and you think the truck was hit by a explosive mine.
  21. Dec 26, 2018 at 5:27 PM
    Snowcat4360
    Snowcat4360 New Member
    Derek
    2018 TRD Sport Crewmax
    Century topper, bed rug, ultimate rod case
    Guess my truck must be set up much differently... I think it rides great and get compliments on the ride quality from my fly fishing buddies that drive an 2014 F-150, 2015 GMC 1500, and 2016 taco.
  22. Dec 26, 2018 at 5:38 PM
    equin
    Ed
    DFW, TX
    My 1st gen ‘03 Tacoma rode surprisingly harsh for its much smaller size and lighter weight than our 2nd/3rd gen Tundras. But I look at it more in the sense that our Tundras are ladder framed vehicles designed to haul and tow much heavier weight compared to regular passenger vehicles.
  23. Dec 26, 2018 at 5:45 PM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    Mine rides great. No issues.
    Rica25 likes this.
  24. Dec 26, 2018 at 6:01 PM
    Kn4x2
    Kn4x2 Common sense is not so common!
    3rd rock from the sun
    2010 DC 2WD
    Afe Pro Dry filter Tinted windows Coverking seat covers Traxion tailgate ladder Auto vox M1 backup camera
    Certain road surfaces cause the jittery feeling with my 2010 work truck model. My 2004 Ford F150xlt felt the same if not a little worse. Maybe it’s the leaf spring suspension?
    Whatever it is........it’s a truck! If you want it to ride like a car, get a car (or a Chevy)!
    Rica25 likes this.
  25. Dec 26, 2018 at 6:56 PM
    Spitfire
    Spitfire New Member
    Long Island
    Really? I dont get it but ok.. friends f150 with 5100s drives same as mine with the trd 4600s.. both stiff but rides good
    Rica25 likes this.
  26. Dec 26, 2018 at 7:14 PM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    I think my '16 SR5 rides great? I've driven a Co-workers '15 Lariat and I didn't think it rode any better than my truck.
    I've had an '11 Platinum with 20's and a now a '16 SR5 with 18's.
    IMO the ingredients to the smoothest riding Tundra are: 18's over 20's, street tires over A/T. I've also heard the TRD suspension rides stiffer over the standard. Not sure if that makes a difference.
    Rica25 likes this.
  27. Dec 27, 2018 at 8:49 AM
    wwolvverine
    2018 Tundra 1794
    Yes i have heard the same, TRD rides even more stiffer because its built for battle on the off roads. Generally i am hearing the same thing, Tundras are built for massive loads not to be Escalades. Still need to find adjustable shocks or something to have the option for both smooth ride and normal truck usauge.
  28. Dec 27, 2018 at 9:17 AM
    yoneytan
    yoneytan New Member
    Asi
    14 CM
    Mine with 3/1 lift and 295/70/18 rides like a Cadillac. Occasionally I’ll get a little bouncy on the freeway but it’s nothing like my stock 07 CM used to be. I’ve been really impressed with the ride, especially considering the lift and bigger tires.
  29. Dec 27, 2018 at 9:25 AM
    wwolvverine
    2018 Tundra 1794
    What brand of Tires??
  30. Dec 27, 2018 at 9:33 AM
    yoneytan
    yoneytan New Member
    Asi
    14 CM
    Toyo OC
