Recommendations for radiator
Discussion in 'General Tundra Discussion' started by swede78, Apr 1, 2016.
  1. Apr 1, 2016 at 10:42 AM
    swede78
    swede78 [OP] Not so new member
    Lars
    westminster co
    2019 tundra platinum mgm crew max
    Nothing yet
    So last Wednesday morning when I left from work the truck was blowing cold air,when I started driving it warmed up and everything was ok. So when I started the truck Wednesday night I got celebrated ran the code and it was P0125 low coolant. I found the lower pass side is leaking in the corner, What route should I go. 2008 tundra 5.7 del sr5.
  2. Apr 1, 2016 at 1:03 PM
  3. Apr 1, 2016 at 3:21 PM
    swede78
    Lars
    westminster co
    Nothing yet
    I could probably use some stop leak for now,but that is a temp fix,right
  4. Apr 1, 2016 at 3:58 PM
    This x1000
  5. Apr 1, 2016 at 4:03 PM
    Radiator shop, have them repair yours or build a new one. There is always the aftermarket aluminum route.
  6. Apr 1, 2016 at 4:04 PM
    swede78
    Lars
    westminster co
    Nothing yet
    Ya,you are probably right.buy I did it any way. I'll keep checking it . I'm going out of town for a week and when I get back I go right back to work until Wednesday.what would be a good radiator,I've kind or looked and prices are pretty broad,also the truck has the towing package, thanks
  7. Apr 1, 2016 at 4:07 PM
    swede78
    Lars
    westminster co
    Nothing yet
    I know I will replace it and most likely do a entire flush,FUCK!!
  8. Apr 1, 2016 at 4:15 PM
    How many miles are on your truck?
  9. Apr 1, 2016 at 4:37 PM
    swede78
    Lars
    westminster co
    Nothing yet
    150,000
  10. Apr 1, 2016 at 4:39 PM
    Well it is probably due. Real bummer still though.
  11. Apr 1, 2016 at 4:40 PM
    swede78
    Lars
    westminster co
    Nothing yet
    Sean what do you mean,for him to do the work or discount on a radiator?
  12. Apr 1, 2016 at 4:43 PM
    swede78
    Lars
    westminster co
    Nothing yet
    Ya,not a hard job by any means,just need containers for the flush and then get rid of it. Time consuming!
  13. Apr 1, 2016 at 5:19 PM
    swede78
    Lars
    westminster co
    Nothing yet
    Fuck it,tired of thinking of it ,going to the old bakers street pub,I'll be the one in the toyota visor doing the jager bomb shots,for you north siders in colorado thanks
    Black Wolf, ColoradoTJ and joonbug like this.
  14. Apr 1, 2016 at 5:24 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    Sounds like a good start! How long do you plan on keeping the truck? If a year or two you pick up a cheap new radiator swap it out and call it a day. Not a hard job at all. If you plan on keeping I would look into a oem or a aluminum upgrade.
  15. Apr 1, 2016 at 6:48 PM
    Now your talking!!!! I'm going to pound a few tonight as well.
  16. Apr 1, 2016 at 10:23 PM
    For suggestions/advice as he's a mechanic for Toyota..but also does side jobs.
    I just realized you're in Westy!
  17. Apr 1, 2016 at 10:49 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    That is near my place. Its called Lucky Dog now i think.
  18. Apr 2, 2016 at 8:48 AM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Worst idea ever. Never ever use stop leak. It does more harm than good. Radiators are pretty much all the same now adays.... I have an aftermarket in my taco, I have oe in my tundra....
    ColoradoTJ likes this.
  19. Apr 2, 2016 at 8:50 AM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Did realize you were in denver. Contact performance radiators. We use them at work, we give customers the choice of oe or performance. Quality aftermarket parts
  20. Apr 2, 2016 at 9:59 AM
    swede78
    Lars
    westminster co
    Nothing yet
    I'll contact them next week,gotta head to the airport now, out of town for work for a week
  21. Dec 8, 2019 at 12:16 PM
    Full Trucker
    Full Trucker New Member
    Evan
    [303]
    2006 Tundra TRD Double Cab SR5
    Hey y’all. Just diagnosed a leaking radiator on my ‘06 quad cab with a 4.7. I’m in Golden. Is the recommendation still Performance Radiator here in town for a replacement? Truck has about 250,000 miles on it, I plan on keeping it as long as it runs. Unfortunately I’m out of work at the moment so budget is a bit of a concern, probably wouldn’t go the aluminum route. Just want something as good or better than OEM that’ll likely go another 250k. Thanks!
