Recommendations for a trickle charger
Discussion in '2.5 Gen Tundras (2014-2021)' started by Netmonkey, Feb 22, 2022.
  1. Feb 22, 2022 at 8:16 AM
    Netmonkey
    Netmonkey [OP] Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    Hey there,
    Because I work from home now, I rarely drive my truck. This is causing the battery to not get charged regularly. I have replaced the battery 3 times in the last 2 years and the current battery is down to 525cca. So I figured that I could maintain it with a trickle charger. I looked on Amazon and there are so many options and widely varying prices that I cannot figure out which would be the best to get. Some of the chargers only work with a specific battery type. I did not realize that automotive battery types matter for a trickle charger? Any suggestions?
    Thanks,
  2. Feb 22, 2022 at 8:45 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I, Spraynard, endorse teh Optimate line of maintainers. Others seem to like the NOCO brand.
  3. Feb 22, 2022 at 8:45 AM
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    2018 Crewmax 1794 4x4
    hANNAbONE likes this.
  4. Feb 22, 2022 at 9:01 AM
    hANNAbONE
    hANNAbONE T U N D R A M A
    Des Moines / Dull Moan, Iowa
    still lookin' for my first one
    trevorklat, Spyker and baron like this.
  5. Feb 22, 2022 at 9:03 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Star, Idaho
    TRD Lowered and Supercharged
  6. Feb 22, 2022 at 9:07 AM
    Outbound
    Aaron
    Northern Alberta
    I have a CTEK as well. It does a good job keeping my boat batteries charged up over the off season and when we leave a vehicle parked for an extended period.
    trevorklat, coldcanuk and hANNAbONE like this.
  7. Feb 22, 2022 at 10:31 AM
    baron
    baron New Member
    Brett
    2021 TRD Pro
    CTEK fan as well. Just had one fail after about a decade of service. Always use on my non-daily driven vehicles. I believe the model I have is MXS 5.0
  8. Feb 22, 2022 at 10:50 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Schumacher SP1297 Fully Automatic Battery Charger, Maintainer, and Auto Desulfator - 3 Amp, 12V - For Cars, Motorcycles, Lawn Tractors, Power Sports, Marine Batteries
    I bought the above for my automotive battery needs. I've killed way too many batteries by letting my Tundra sit too long without driving.
    This thing works like a champ and was relatively inexpensive.
    My compadre has more vehicles that I can count ~ most of which are on one battery tender or another. He has expensive ones ~ he has inexpensive ones.
    They all seem to do the job.
    Battery Tender Plus 12V Battery Charger and Maintainer: 1.25 AMP Powersport Battery Charger and Maintainer for Motorcycles, ATVs, UTVs - Smart 12 Volt Automatic Float Charger - 021-0128
    I sourced the above for the BMW motorcycle we have in the garage. Since the bike rarely gets used it's necessary to have it on a tender as well.
    Never had an issue with either one of these and you quite likely will have the same result. Just my two cents worth . . .
  9. Feb 22, 2022 at 10:57 AM
    BlueprintYota
    BlueprintYota New Member
    Ryan
    22 Blueprint TRD Offroad
    I've had a few of the expensive ones and to be honest, they've bit the dust. I use a basic battery tender one and it's never had an issue. This one has been the best one hands down that I've owned.
    I would recommend NOCO for the compact battery booster box though. Well worth having.
    https://www.amazon.com/Battery-Tend...5556181&sprefix=battery+tender,aps,119&sr=8-8
    Mad Max likes this.
  10. Feb 22, 2022 at 11:29 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I've got a small, old Schumacher. Very dependable.
    panicman likes this.
  11. Feb 22, 2022 at 11:59 AM
    acmesupply
    acmesupply New Member
    2018 SR5 CM Silver TRD
  12. Feb 22, 2022 at 1:14 PM
    hANNAbONE
    I have my FJR hooked up on the same BTender -- all winter season and thru the riding season too.!
    YardBird[QUOTED] likes this.
  13. Feb 22, 2022 at 1:18 PM
    SSPey
    SSPey .
    Oregon
    2021 DinoSR5
    I use Battery Tender Jr for my boat, cheap and works great
  14. Feb 22, 2022 at 1:34 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    $10 harbor freight special works fine for me
    Fallingblock and bflooks like this.
  15. Feb 22, 2022 at 2:14 PM
    Radarninja
    Radarninja New Member
    Ryan
    Ca
    We use these at work, these are the only reliable ones we’ve found.
    The larger 1.25 amp shit the bed after a short time. Stay away from any battery tender. Unless it’s the size this guy posted.
  16. Feb 23, 2022 at 5:23 AM
    Netmonkey
    Georgetown, TX
    thanks for all the feedback.
  17. Feb 23, 2022 at 5:28 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    + on the NOCO Genius 1, smart charger with temperature adjustment, have them on small engines and the lesser used autos i own.
    https://no.co/genius1
  18. Feb 23, 2022 at 6:09 AM
    Rolling Biome
    Rolling Biome New Member
    Denver, CO
    2019 Tundra CM Limited TRD Off Road
    How about a solar panel? That was my solution since the truck is parked on the street and running a power cord wasn't an option.
    I also have a CTEK just in case
    trevorklat likes this.
  19. Feb 23, 2022 at 10:31 AM
    Nueces
    Nueces New Member
    Texas Hill Country
    2002 Tundra SR5 AC
    I wanted a permanently underhood mounted one for the Jeep, but the makers I spoke to all recommended against that because their electronics would not survive underhood temps. Then, NOCO came out with the NOCO Genius2D 2 amp unit, which is designed for the underhood environment. It's permanently wired to the battery and needs only to be plugged in to an AC outlet. It's small enough to be easily secured with zip ties. I now have one in three vehicles, including the 2002 Tundra. The power pigtail leads out in front of the radiator, so plugging it in is easy. They have worked well over two winters.
    Warreng likes this.
  20. Feb 23, 2022 at 4:28 PM
    Tundra1078
    Tundra1078 New Member
    Peter
    Los Angeles
    2018 White Platinum 4x4
    TRD dual exhaust, sway bar, TRD skid plate, grab handle (future), husky liners
    I use the one from Costco (in store) I have it on 4 of my vehicles and no problem So far.
  21. Feb 23, 2022 at 10:10 PM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    If they still have them, the Noco Genius G750 has been tending my same Optima Red Top 6 volt battery for 10 years.
    But never discount the staying power of the stolid ELECTROMITE…
    The older ones that still work will always be reliable, consistent, and bulletproof until they die. The Electromite absolutely still works.
    The newer ones have some handy technology, are smaller and more convenient, but seem to be less consistent. Noco for sure has pissed a few people off.
    Netmonkey[OP] and 1lowlife like this.
  22. Feb 23, 2022 at 10:14 PM
    panicman
    Eric
    I should point out that I have charger/tenders that feed 6 and 12 volt batteries. That drove my choice when purchasing.
  23. Feb 23, 2022 at 10:19 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Seems like there is a preferred smart charger that many like, but I can't remember the name. Others posted, it's CTEK. I would have got that but got the NOCO on a black Friday deal
  24. Feb 23, 2022 at 10:28 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  25. Feb 24, 2022 at 4:18 AM
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    Big fan of CTEK! Would recommend
  26. Feb 24, 2022 at 5:04 AM
    DSTundra
    DSTundra New Member
    Dave
    Albuquerque, NM
    2017 Tundra Platinum
    NOCO Genius 5
  27. Mar 1, 2022 at 2:34 PM
    GREENwithENVY
    GREENwithENVY New Member
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    I've got a CTEK with a Comfort Control (wires on the battery posts, has LEDs, and plugs directly into charger). My question: Do you all think there is any harm in using the control and charging the battery without unhooking it from the vehicle? I've got mixed feelings on doing that and frying electronics.
    Any thoughts?
  28. Mar 1, 2022 at 2:38 PM
    Moe2o4
    Moe2o4 New Member
    Corey
    2020 Tundra SR5 Extended Cab TRD Offroad Package 8ft. Bed
    Bilsten 6112's with 2.5" Front Lift w/Bilstein 5160 Rear Shocks
    I purchased a Noco about 2 years ago and I use it regularly and their great! Highly recommend them off of Amazon! I also use a Noco GB70 jump starter and I love that thing as well!!!
    Netmonkey[QUOTED][OP] likes this.
