Recommendations for 2nd gen tundras diff and transfer case oil
Discussion in '2nd Gen Tundras (2007-2013)' started by ERROD10, Oct 26, 2024.
  1. Oct 26, 2024 at 2:55 PM
    ERROD10
    ERROD10 [OP] New Member
  2. Oct 27, 2024 at 1:25 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
  3. Oct 27, 2024 at 1:41 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Depends in the year of his truck. Older transfer cases used 75W-90 gear oil. I think the newer TC came in 2014 or so.
    Those ez-fill containers that Valvoline uses are great and refilling the diffs is much quicker and easier than using the hand pumps.
    Mdl likes this.
  4. Oct 29, 2024 at 5:02 PM
    superman86
    superman86 New Member
    Jonathan
    2008 Slate Metallic SR5 4x4
    When I financed my used 2008 Tundra 4WD 5.7 with 153,000 miles I took it to the dealership for the Front/Rear Transfer Case this is the following info on my receipt:
    Installed 7590 Gear Oil 16@4.95 = 79.20
    Installed 12157-10010: Gasket, Drain Plug 3@2.68 = 8.04
    Installed 90430 - A0003: Gasket 2@3.08 = 6.16
    Installed 90430 - 24017: Gasket 1@3.40 = 3.40
    All for $149.95
    Had more things done cuz I didn't know what the other owner did or didn't do and as of now at 185,000 can hear a thing and the engine gears are running all smooth :)
    On top of it they let me inside the bay pointed out everything and showed me the parts so at least to me in this instance I felt like they did care
  5. Oct 30, 2024 at 6:51 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    I use 75w90 full synthetic in all three for my 2012. Usually go with good ol Mobil 1, but they didn't have any when I last did the transfer case. It currently contains the purple stuff.
    Aisin transfer case calls for 75w90
    Borg Warner (2014+) wants straight 75w
