Recirc button problem
Discussion in '2nd Gen Tundras (2007-2013)' started by bleach, Aug 25, 2020.
  1. Aug 25, 2020 at 7:19 AM
    bleach
    bleach [OP] MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    I noticed that even when I hold the recirc button for more than 2 seconds as the manual says, it still automatically goes off and the outside air comes in.
    The mornings lately have been a little cold so I like shutting off the outside air. It's annoying when it goes off. There are also some areas I drive through that smell bad too so I shut it off then.
    How can I check this button? I followed the instructions in the manual:
    "If the ambient temperature drops, the air intake mode will automatically change from RECIRCULATE to FRESH after a few minutes. This automatic change control mode can be cancelled by pushing and holding the button for longer than 2 seconds."
    This does not work. It's like 3 to 5 minutes later the vents open.
  2. Oct 31, 2020 at 10:53 PM
    seabass1014
    seabass1014 New Member
    Sebastian
    2007 CrewMax SR5
    Eibach Level on ExoGrapplers
    I’ve been having this problem as well, hopefully someone figures it out
  3. Nov 1, 2020 at 7:16 AM
    bleach
    DJ
    Battle Ground, WA
    It's really annoying on a cold day when I don't really want to run the fan. It sometimes works and sometimes doesn't. PITA.
  4. Nov 1, 2020 at 10:57 AM
    CharlieS
    CharlieS New Member
    2010 Tundra Rock Warrior
    Doesn't work when in defrost. Any chance that is what you are seeing?
  5. Nov 1, 2020 at 11:05 AM
    seabass1014
    Sebastian
    2007 CrewMax SR5
    No I’m on head and foot, I think it was what was posted above and there’s nothing I can do about it since I’m in a cold climate now.
  6. Nov 1, 2020 at 11:12 AM
    bleach
    DJ
    Battle Ground, WA
    I've tried every setting and sometimes it works, sometimes it doesn't. It the flakiest system I've ever encountered.
  7. Nov 21, 2022 at 7:58 PM
    Caritaman1
    Caritaman1 New Member
    Charles
    2012 Tundra Crewmax 5.7 Texas Edition
    Did you ever figure out what to do? This happens to every winter.
  8. Nov 22, 2022 at 8:49 AM
    Notarobot
    Notarobot Jagged lines!
    2013 CM
    I have to push and hold mine for 5-10 seconds for it to stay on.
    Tundra3k likes this.
