Reccomendations
Discussion in 'General Tundra Discussion' started by Blackout, Aug 18, 2018.
  1. Aug 18, 2018 at 2:15 PM
    Blackout
    Blackout [OP] New Member
    2014 crewmax
    Does anyone have recommendation f for rear underseat storage for 2014 limited crewmax? Any thoughts on ESP products
  2. Aug 18, 2018 at 2:24 PM
    Blueknights75
    Ron
    Clayton, NC
    First and best mod I did! Can’t go wrong with the ESP storage. It’s easy to install once you build up the courage to cut into the floor...
  3. Aug 18, 2018 at 2:26 PM
    Blackout
    2014 crewmax
    Thanks that's what I'm struggling with bc I'm not mechanically inclined? Which model did you go with?
  4. Aug 18, 2018 at 2:34 PM
    Cajuntex
    Cajuntex New Member
    2018 Tundra Limited CrewMax 2wd
    Added Digital Processor,amp,speakers and sub; ESP storage tray, Driver Handle, husky mats, Diamondback se, TSS rims and BFG KO 2s
    I installed the 3 tray as well. Just follow their video on YouTube and buy their recommended tools primarily the flooring cutter. Really easy to do. The piece itself covers all the holes and surrounds so minor mistakes are easily covered. Don’t forget to keep the box because the template is printed on the outside. Good luck!
  5. Aug 18, 2018 at 2:46 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Budget? The ESP trays are $189.95, if you want lockable covers $449.95 and the long lock box is $699.95. They come with templates to cut into the carpet. On a budget I've seen DIY metal food warmer trays, same concept as ESP trays. Or a cheap rifle case with the foam inside removed, secured with zip ties, no cutting into the carpet.
  6. Aug 18, 2018 at 3:37 PM
    Blackout
    2014 crewmax
    Thanks for all the advice... Just not handl and hate to damage the vehicle.. Do all of there products require mods
  7. Aug 18, 2018 at 4:46 PM
    Cajuntex
    Cajuntex New Member
    Unfortunately there is not a lot of choices since there is no room back there. I had a Ram which had a ton of storage in comparison. I primarily use it to hide my laptop case and a few tie downs. I rationalized it this way, if I messed it up I could put back the foam (which came out pretty easy in one piece) and have the carpet taped back perhaps by a professional if necessary. If worse I also cover it all up with Husky rear mats.
  8. Aug 19, 2018 at 10:50 AM
    Blackout
    2014 crewmax
    Definitely don't want to go over 600.. budget .I like the look of the trip locking one but don't know the depth of each compartment.. Could I fit a 4 way like not wrench inside? Mail just jumper cables or first aid kit type stuff..cajuntex I may have to get your assistance on install...lol
  9. Aug 20, 2018 at 6:32 PM
    Blackout
    2014 crewmax
    Did anyone install the 3 bin lockable?
