Recall on lower control arms?
Discussion in '2nd Gen Tundras (2007-2013)' started by Coba, Dec 3, 2016.
  1. Dec 3, 2016 at 6:59 PM
    Coba
    Coba [OP] New Member
    08 Tundra
    Does anyone know if there has been a recall on the lower control arms? On a 2008 tundra
  2. Dec 3, 2016 at 10:13 PM
    Coba
    08 Tundra
    Yes, I just couldn't wait until Monday, I was just helping someone move it we call the girls to replace those to stop the shaking when I hit my brakes will cost me another 1K and I just installed new brakes and rotors think and what was the problem! Thanks for your help I will check on it Monday
  3. Dec 3, 2016 at 10:47 PM
    Coba
    08 Tundra
    Tires are in great shape, not even a year old, and going down the freeway at 70 or 80 rides very smooth soon as I apply the brakes shaking starts
  4. Dec 3, 2016 at 11:02 PM
    Coba
    08 Tundra
    Right! These came from AutoZone, and they were midgrade Bosch, with brand-new Dura last gold brakes top-of-the-line
  5. Dec 3, 2016 at 11:07 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    yep, had the same happen on my truck not too long after I bought it. Only shaking when braking. Rotors and pads took care of it.
    NewImprovedRon and GNTundra like this.
  6. Dec 4, 2016 at 12:08 AM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
  7. Dec 4, 2016 at 5:17 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    On my previous 2015 Tundra I replaced all four rotors with Auto Zones mid grade rotors and brakes. I had the exact same issue! So I went back to auto zone and they replaced all the rotors and I upgraded to the gold series rotors and it fixed the problem.
    First set of rotors I installed. (They had problems at higher braking speeds.)
    Replaced them with the Durolast rotors and had no issues after that. IMG_1725.jpg
  8. Dec 4, 2016 at 8:29 AM
    Coba
    08 Tundra
    Ok, so if I left my will and tug and wiggle the rim and don't feel anything it's not the lower control arm bushing's? More likely the rotors off A millimeter or two out of run out!
  9. Dec 4, 2016 at 10:02 AM
    1UPPER
    TEXAS
    Flux capacitor!
    If your truck drove fine before you replaced your rotors and its only happening when you brake then it's probably your replacement rotors.
    FlashCulprit and joonbug like this.
  10. Dec 4, 2016 at 4:08 PM
    Coba
    08 Tundra
    Ok, I understand all this, but for the past six months my truck has been shimming, and shaking only when I apply the brakes and high-speed! So I automatically thought it was my front rotors because they looked A little worn down ! So I replaced them, and it still is doing the same thing, that's why am wondering if it is the lower control arm bushing's? But under 50 it stops great it's speeds above 50 to 80 where my shaking occurs when I hit my brakes
  11. Dec 4, 2016 at 4:53 PM
    Coba
    08 Tundra
    No, I did not have time to replace an exchange the rotors, I'm going to have a guy look at my lower control arms and bushings to see if that is the situation, I'm having a hard time thinking that it's the new rotors because it rides really well and even at 90 miles an hour I have no issues until I kick the brakes on
  12. Dec 4, 2016 at 5:09 PM
    Coba
    08 Tundra
    I have 170k miles,
  13. Dec 4, 2016 at 5:09 PM
    thumper7799
    thumper7799 Bad Girls Drive Bad Toys!
    Erika
    2007 Nautical blue Tundra SR5 duel exhaust
    You can also look at toyota.com/recall. You just need your VIN number
  14. Dec 4, 2016 at 5:10 PM
    Coba
    08 Tundra
    I have 18's on it, only one size larger than OEM,
  15. Dec 4, 2016 at 5:16 PM
    1UPPER
    TEXAS
    Flux capacitor!
    From what your saying is happening, I would say it's your rotors. As I was saying in my earlier post I bought a brand new set of rotors from auto zone and had the same problem as you. If it was your lower Control Arms then the vibration would be happening without brakes IMPO.
  16. Dec 4, 2016 at 5:42 PM
    Coba
    08 Tundra
    Ok, that's good to know on the lower control arms, I guess it's only three hours of my time to change out these rotors, again! I guess it's good practice! For future Nascar training! Lol
    1UPPER and thumper7799 like this.
  17. Dec 4, 2016 at 7:04 PM
    SlickRick2013Tundra
    SlickRick2013Tundra #10
    Rick
    Mandeville, LA
    13 TRD CM MGM 4x4
    Toytech Boss 3in Lift kit Iron Cross side step TRD Sway Bar TRD Cold Air Intake Blacked out Badges Blacked out front and rear bumpers
    Nice looking rotors
    1UPPER[QUOTED] likes this.
  18. Dec 5, 2016 at 2:27 PM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    on my new tundra, there was a high speed vibration under braking - I could have sworn it was a rotor issue.... took it back to the dealer and they did an alignment... that fixed it.
    If you have a dial gauge, take a wheel off and check the run out on the rotors, both sides and if you're being super detailed, check three points, inside, middle, outside in case you have a weird manufacturing fault.
  19. Dec 5, 2016 at 9:02 PM
    Coba
    08 Tundra
    Ok, it just puzzles me to do 80 miles an hour straight with no issues vibrations or shakes, and soon as I apply the brakes my steering will shakes not sure why a fun end alignment would have any affect on that because you would feel it without hitting my brakes
  20. Dec 6, 2016 at 9:53 AM
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    try rotating the tires and see what that does, I know you said it runs smooth but its easier than the brake job and doesn't cost anything it just may be a tire out of balance worth a shot
  21. Dec 6, 2016 at 11:58 AM
    Coba
    08 Tundra
    Did that all ready, Thanks
  22. Dec 6, 2016 at 10:23 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I was going to say rear rotors until you said the steering wheel shakes - does it shimmy side-to-side, or you just feel the shake up through the steering column?
    If I'm understanding correctly, you only replaced the front rotors and pads, correct?
    Did you make sure the hub face was clean or any rust scale and dirt, and torque the wheel nuts with a torque wrench?
  23. Dec 7, 2016 at 4:33 AM
    Coba
    08 Tundra
    Hub face is clean! No rust! No Turque wrench, but it's tight, my steering wheels when I apply the brakes side to side , yes I just replace the front rotors and brakes
  24. Dec 7, 2016 at 6:22 AM
    cdkenne
    cdkenne Toyota Master Technician
    Corey
    KS
    2002 Tundra SR5 TRD Offroad
    285/70R17, '15 4Run Trail Wheels, Westin Shopping Cart Basher, SnapOn license plate cover that adds >50 HP
    Roughly 80% of the Autozone rotors I have installed are not true straight out of the box. They are so bad I turn them before installing now without question. I can almost guarantee your rotors need turned. I do a couple sets of Autozone rotors a month and they almost always come back with vibrations soon after unless I turn them prior to installing.
  25. Dec 7, 2016 at 7:15 AM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    how are your steering rack bushings? Are they the originals? If the bushings are worn they will allow a lot of play during braking and allow for vibration. That said, I have had brand new rotors shimmy too, had to have them turned to correct.
  26. Dec 7, 2016 at 8:21 AM
    Coba
    08 Tundra
    Ok, Thanks this weekend I am taking them off and changing them!
