RECALL/ FUEL SMELL AFTER REPAIRS MADE
Discussion in '2.5 Gen Tundras (2014-2021)' started by LILBITMOM, Apr 25, 2021.
  1. Apr 25, 2021 at 8:46 AM
    LILBITMOM
    LILBITMOM [OP] New Member
    BARBARA
    2019 TUNDRA 1794 MODEL
    I have a 2019 Tundra with only 16,000 miles on it. I received a recall notice for a fuel pump problem. When I took it to the dealer he advised me they would have to drop the fuel tank to do repairs. At that time I also was having a problem with the remote start. After having the truck for 4 days I got it back. I live out in the country and about 25 miles from the dealer, when I was almost home I started to notice the smell of gas, NOT exhaust fumes, actual gas fumes. Any suggestions on what they did or did not do that may have caused this? When I got home I checked under the hood but did not smell anything. There was however a slight small around the gas cap, I took off the gas cap and put back on. But the smell continues, I do not see a leak under the truck? Any suggestions on what else this could be?
  2. Apr 25, 2021 at 10:03 AM
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    OEM LED headlights, Rigid SAE foglights, Go Rhino RB10 running boards, ARE Classic CX
    I would recommend checking that all the connections to the tank were reinstalled. The filler hose connection is on the rear of the tank. Since you did not have any issues driving, i'm assuming the fuel feed and return hoses were properly installed. Have you tried putting any gas in and if so, were there any leaks? I've read that some dealers forget to reattach the gas fill hose. Also, if you park in an enclosed garage, i would not put the truck in until you get this issue resolved.
    Bob and TheBeast like this.
  3. Apr 25, 2021 at 10:16 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Both my Tundra and my wife’s Highlander had the gas smell after the fuel pump recall was done. The smell went away after a couple days. We keep our vehicles in the garage so were able to leave the windows down overnight.
    If it’s still going on I’d definitely take it back to the dealership for a check.
  4. Apr 25, 2021 at 10:53 AM
    Welcome from NY.
    If that smell isn't gone by tomorrow I would be going back to the dealership. I also wouldn't park that inside a garage until the issue is resolved.
    TheBeast likes this.
  5. May 4, 2021 at 12:27 PM
    BulldogDan
    BulldogDan New Member
    Cement…Tundra #9
    I am getting my recall done tomorrow. Did the gas smell ever go away?
  6. May 4, 2021 at 1:04 PM
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    Ugh... which gamble to take? Fuel pump quitting at an inopportune time, or Toyota service tech screwing up my Tundra (and/or my 4R)? One of these instances seems to occur at a higher rate than the other...
    Joe333x and Shark Bait like this.
  7. May 4, 2021 at 1:10 PM
    Liperonus J
    Liperonus J New Member
    Jerry
    2008 tundra SR5 white
    None-stock
    That happened to me,mine is a 2008,my fuel gauge quit working after a year,I had less than 15k miles.Thats serious in my opinion because fumes ignite first.They dropped my tank,and I went across the street to fill up because they had emptied my tank to drop it, and when I immediately took it from the gas station back over to the dealer they called me the next day and told me the gasket had been pinched. That's just my experience. Come to find out something had chewed through my wire harness, they said a rodent of some sort somehow got into my dash and chewed a bunch of wires in my harness, they replaced the whole harness under warranty. I'm assuming the pinched gasket is the gasket between the tank and cap that goes on top of the tank after the fuel pump has been lowered in.Jerry
  8. May 4, 2021 at 4:35 PM
    fytedapowr
    fytedapowr New Member
    Jake
    Austin TX
    '15 1794 4x4
    Bilstein 6112/5160, CB +2 shackles, SPC UCA's, CB bumper shims, 35's
    There is a thin breather hose nearby the filler hose that needs to be disconnected when dropping the tank. both are located at the rear of the tank, near the front side of your rear wheel well. I'd do a quick visual check on both so see if that's the issue, as it will take less than a minute. filler tube connects at the tank on its rear/driver side, and is a phillips head worm clamp (or 10mm). Breather tube doesnt disconnect at tank, its connection is further up the wheel well on the way to the gascap/door, in between your front side leaf spring and the fiberglass. if you find an open connection in that area with no hose attached, then the breather line was probable left laying on top of the tank before tankstraps were fastened and may be inaccessible.
    Hope it's an easy solution!
  9. May 4, 2021 at 4:41 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Yeah I'm not bringing mine in, unless I start having a problem. I hate letting anyone touch my vehicles.
    WILLINH and Jernik[QUOTED] like this.
  10. May 4, 2021 at 4:50 PM
    :thumbsup:
    X2
    Jernik likes this.
  11. May 5, 2021 at 4:36 PM
    BulldogDan
    Cement…Tundra #9
    I had my fuel pump recall completed today. There is no gasoline smell whatsoever, thank goodness. But there is a “unique” odor coming from the new TRD Dual Exhaust (with black chrome tips) I had them install after the recall work was done. Love the sound…and the look!
  12. May 8, 2021 at 10:22 AM
    Oats87
    Oats87 Dirt Rider
    Sunnyvale, CA
    A Non-Toyota
    Odor and smoke are perfectly normal for a brand new TRD dual. I installed mine at ~1000 miles and had this.
    @ViktorG 's video is great on showing the process to drop the tank: https://www.youtube.com/watch?v=O97GvWp8LdI You can follow it, look for the connections that he has to undo, and verify they are all still attached.
    ViktorG likes this.
  13. May 19, 2021 at 2:30 PM
    fytedapowr
    Jake
    Austin TX
    '15 1794 4x4
    ^video is great but note that flex fuel trucks will have a slightly different pump assembly with an additional fuel line connection. For anyone lurking in the future that doesn't want to accidently rip it off while dropping the tank like I almost did.
    Oats87 likes this.
  14. May 19, 2021 at 2:51 PM
    jsteph89
    jsteph89 The wish list continues to grow
    Joseph
    South Texas
    2019 Limited 4x4
    Blacked out emblems, Leer 100XL camper shell, Magnaflow exhaust, ProComp 3/1 level kit, 285/55R20 Falken Wildpeaks AT3, WeatherTech mats, full led interior swap,
    I also had that smell but went away within 2 days
  15. May 25, 2021 at 11:14 AM
    Chugbug
    Chugbug New Member
    2023 Platinum, Midnight Black
    After mine was done I had the same thing.....cracked the windows and it was gone. But beware, some of the replacement pumps are defective, lost all of the safety features, cruise control, trade control yesterday check engine light came on, traction control gone.....they think it has to to with the new pump
