Rearview Camera on Aftermarket HU without Reverse
Discussion in 'Audio & Video' started by TRDFerguson, Feb 21, 2019.
  1. Feb 21, 2019 at 2:12 PM
    TRDFerguson
    TRDFerguson [OP] SSEM #99/RGBA #8-ish?/It’s a funny name.
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    For those that have installed an aftermarket head unit and retained the factory backup camera, have you had any luck viewing the rear camera when not in reverse? My Pioneer AVH-w4400NEX has the option to view my front and rear cameras at any time, but only my front camera is visible in Camera View. The rear camera works fine and activates as expected when I shift into reverse. I've read somewhere that the rear camera may be powered by the reverse lights, but I haven't found any diagrams to confirm that. I'm mostly just wanting to make sure I didn't miss a connection when hooking up the wiring harnesses during installation, but I've gone over the diagram for that a few times and don't see anything obvious.
    I also know that I can "safely" activate the rear camera while driving over 25 MPH and shifting into reverse... but no thanks...
    15whtrd and 040Tundra like this.
  2. Feb 21, 2019 at 9:04 PM
    JTL
    JTL New Member
    Jon
    Phoenix, Az
    '17 MGM Platinum
    Trd CAI, Trd Dual Exhaust, ESP Locking storage, Center Console Safe, Trd Rear Sway Bar, BFG Ko2, Pioneer Avic 8400nex, Husky Liners, 19 Trd Headlights, iHacker Harness, Tech12Volts Sub Upgrade
  3. Feb 23, 2019 at 2:34 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Anyone have ideas on this? I'm about to go pull the head unit out and recheck the wiring, but if it's just a matter of the camera receiving power from the reverse lights, I won't waste my time.
  4. Feb 23, 2019 at 3:01 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    What harness did you use to hook up the pioneer with?
  5. Feb 23, 2019 at 3:03 PM
    Berdine
    Binghamton, NY
  6. Feb 23, 2019 at 3:32 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I used the Crux harness recommended by Crutchfield: https://www.crutchfield.com/p_249TY...io-Interface-W-SWC-BUCam-Retention-11-up.html
    Thanks for linking that. I had run across that one a while ago and it definitely helped refresh some things. I was under the impression that the head unit would handle the diode/power portion and make that mod unnecessary, but now I guess I just have to pull the head unit and check my wiring... Thanks!
    Berdine[QUOTED] likes this.
  7. Feb 23, 2019 at 3:46 PM
    Berdine
    Binghamton, NY
    Maybe something along the line of the frac harness? I know I've seen it posted somewhere where someone did what you want.
  8. Feb 23, 2019 at 7:32 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    FRAC is a little different than what I'm looking for, since the new head unit already does all the heavy lifting that the FRAC mod would accomplish, at least for my case. The only thing that I can think of is that Tundra backup cameras are indeed powered on the same circuit as the reverse lights, so I'll need to add the diode and ignition power mod mentioned in the TundraTalk link.
    Now I'm just trying to decide if I care enough about having this ability to pull the head unit out and rewire/troubleshoot the whole thing...
    Berdine likes this.
