Rearend Noise?
Discussion in '2.5 Gen Tundras (2014-2021)' started by countermantaylor, Jan 20, 2022.
  1. Jan 20, 2022 at 11:14 AM
    countermantaylor
    countermantaylor [OP] New Member
    Taylor
    14 Tundra
    Rear airbags
    Hey ive got a 2014 tundra bought new. Have pulled some heavy loads with it (about 10k plus) about 3 years ago but only hauling loads about 5k now. Last year installed rear air bags due to sagging with loads. About 3 weeks ago started dealing with rear end noise. Put it on jack stands and from a coulpe of feet away while running it 40mph you can tell its noisey but with a pry bar and ear i cant pin point it. Was wondering if anyone has had problems with this gen rearend before and difficulty of the rebuild? Ujoints are tight and no noise at carrier bearing. Thanks Taylor
  2. Jan 20, 2022 at 11:18 AM
    What does the noise sound like?
  3. Jan 20, 2022 at 11:31 AM
    countermantaylor
    Taylor
    14 Tundra
    Rear airbags
    howling noise but does not change under acceleration like a normal pinion bearing. But does get louder with a load bebhind the truck. Have not got a chance to change the fluild but it is at the correct level.
  4. Jan 20, 2022 at 12:16 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    gears in the rear diff? sometimes when ppl get regear done they complain about howling noises. Pretty sure if it ever happens under acceleration, you have a problem.
    Off chance maybe something with drive shaft or joints?
  5. Jan 20, 2022 at 12:31 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
  6. Jan 20, 2022 at 12:32 PM
    2mchfun
    Axle bearings would be my guess. Not a terrible job. Might be a little slow getting parts with the current crisis though. Just be patient. BTW, if you backed boats into the water, that could have allowed water to get in the differential breather.
  7. Jan 20, 2022 at 12:39 PM
    2mchfun
    Due to the title, this thread has massive potential! Let her rip boys!
    @hagrid
    Jaypown likes this.
  8. Jan 20, 2022 at 1:10 PM
    countermantaylor
    Taylor
    14 Tundra
    Rear airbags
    I was thinking axle bearings/wheel bearings as well. Do you think differential bearings/carrier bearings would change sound underload?
  9. Jan 20, 2022 at 1:17 PM
    2mchfun
    The axle bearings would be my guess because they take the most abuse. No bearing should have a significant change in sound loaded vs unloaded if it is in good condition and well lubricated. As I mentioned earlier, if water has entered the picture, then you might as well get ready to rebuild the whole works. Good luck!
