Rear windows won’t roll up
Discussion in '1st Gen Tundras (2000-2006)' started by jmh2020, Sep 9, 2020.
  1. Sep 9, 2020 at 7:27 AM
    jmh2020
    jmh2020 [OP] New Member
    2006 Tundra DC 4WD Waltrip
    none
    Recently, my rear (door) windows began to work intermittently and are now down a few inches and now I can’t get them to roll up. I also had (recently) a similar problem with the rear window but it is up now.
    Also, the door locks occasionally cycle on their own when I close the drivers side door. This started recently.
    I’ve checked the window lockout and tried the window switches on the rear doors (they behave as if there is no power)
    I’ve checked the fuses that I think are related to the power windows and they seem fine.
    The truck has lived in Colorado all its life and is not a flood truck.
    The problem was intermittent until a couple of days ago.
    1. Is there a relay(s) that controls power to the rear door windows and rear power window?
    2. Suggestions on what to check next?
    thanks!
    2006 Tundra, DC, 4WD, Waltrip edition
  2. Sep 9, 2020 at 11:12 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Sounds like you might have some wires touching in the main driver switch. I'd pull that, check the wires, and clean the contacts. Does the pass front window work on both switches?
  3. Sep 9, 2020 at 11:15 AM
    Professional Hand Model
    Hand Protectors
    My drivers switch for the pass side window was a little sticky/glitchy until I pulled the assy apart and cleaned it up. Used canned air blasts for computers on the dust build up and some sand cloth on the contacts. Smoovvv.
    jmh2020[OP] likes this.
  4. Sep 9, 2020 at 11:23 AM
    jmh2020
    none
    BMF4069, I'll check the driver's side switch assembly. Yes, the passenger's and driver's both work (from the driver's side and the passenger's side switches)
