Rear Window Switch Relocation
Discussion in '2.5 Gen Tundras (2014-2021)' started by eric.t.lindgren, Nov 6, 2019.
  1. Nov 6, 2019 at 11:44 AM
    eric.t.lindgren
    eric.t.lindgren [OP] New Member
    Corpus Christi, TX
    2016 - SR5 CM w/ TSS
    Howdy.
    I’ve seen some rear window switch relocation kits that have a longer wiring harness and been thinking about getting one. Having the switch on the panel with the light switches sometimes isn’t super convenient. Has anybody relocated their rear window switch and where did you move it too?
    Stocky Balboa likes this.
  2. Nov 6, 2019 at 11:48 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Following for Ideas too.
  3. Nov 6, 2019 at 11:52 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    I hate that they moved it! In my 08 it was on the right side of the steering wheel not the left.
  4. Nov 6, 2019 at 11:54 AM
    BackHandHighballer
    BackHandHighballer New Member
    2017 White Tundra Crewmax 1794
    Yeah bastards, on my 1989 it's by the shifter! Center console
  5. Nov 6, 2019 at 12:09 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I wish cheaper kits were available too, my problem is that with the platinum, there are no blank switch spots. so I would need to swap it with a different switch which would require another extension kit for that switch.
    jewsNbrews, OR18TRD and bmann7 like this.
  6. Nov 6, 2019 at 12:15 PM
    bmann7
    bmann7 Silver Sky Platinum Pro
    WA
    2019 SSM Tundra Crewmax Platinum
    See signature line
    Watching...
    And while we're there (on that part of the dash), why aren't the mirror adjustment switches backlit?? WTF?
    rockmup, panicman, Jaypown and 2 others like this.
  7. Nov 6, 2019 at 12:54 PM
    Pudge
    CT
    Yeah that's really annoying. I added a cheap, small ,low lumen, led bolt light to mine and it lights it up. I do not understand why it's not backlit though.
    panicman, bmann7[QUOTED] and Cthulhu like this.
  8. Nov 6, 2019 at 1:12 PM
    bmann7
    WA
    See signature line
    @Roman any way to replace our dark switch with a backlit one from another model/year?
  9. Nov 6, 2019 at 1:16 PM
    Pudge
    CT
    There is a switch that can be wired and fit, it's not from a Tundra and it's not plug and play. I think maybe from a 4runner or maybe sienna.
  10. Nov 6, 2019 at 1:29 PM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Not any from another Tundra, but possibly from a different model. Definitely not plug and play, though.
  11. Nov 6, 2019 at 1:43 PM
    bmann7
    WA
    See signature line
    But a direct fit in that same dash location?
  12. Nov 6, 2019 at 2:28 PM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    I moved mine to the panel in front of the shifter. I figured that if I put it there the front passenger can control the rear window too.
    BackHandHighballer and Pudge like this.
  13. Nov 6, 2019 at 2:39 PM
    Rebel Tundra Man
    Rebel Tundra Man New Member
    Tyler
    Western Kentucky
    2016 Black Limited CM
    4" RCX Lift, 20x10 Fuel Coupler's, 35x12.50x20 Nitto Ridge Grappler's, Color Match Front End, LED Bulbs, RCX Tube Steps, Green LED Underglow
    Moving this switch into the driver door window switches would be amazing. I hate having to reach down especially in the dark to fumble and find that switch to roll the back window down.
    biebs96 and Jsnake89 like this.
  14. Nov 6, 2019 at 2:44 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
  15. Nov 6, 2019 at 3:38 PM
    bmann7
    WA
    See signature line
    Got any photos? How hard was it to get over there wire-wise?
  16. Nov 6, 2019 at 3:48 PM
    djhase
    djhase member
    David
    Southern Illinois
    2019 Silver Tundra TRD
    Agreed WTF Toyota? Plus the location is stupid. Every other vehicle I've owned has these controls on the arm rest where its easy to get to and use. Not on the dash where its completely inconvenient to access if you can find it in the dark.
  17. Nov 6, 2019 at 4:21 PM
    careyrob
    Carey
    Massachusetts
    Sorry about the picture quality. It's already dark here.
    I moved the Tow/Haul button to where Toyota should have placed it from the factory as well. It wasn't hard. I just cut the pigtail from the wiring harness and spliced in enough wire to get it to the socket I wanted.
    panicman, saybng and Pudge like this.
  18. Nov 6, 2019 at 4:30 PM
    careyrob
    Carey
    Massachusetts
    Oops! I just realized that this thread is in the 3rd Gen forum.
    Sorry everyone. Mine is a 2nd Gen in case you can't tell from the picture.
    Pudge likes this.
  19. Nov 6, 2019 at 4:33 PM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    Why does it matter? I've rolled mine down once when I farted real bad that I couldn't even stand to smell it and that was it.
    BravoDeltaRomeo likes this.
  20. Nov 6, 2019 at 5:37 PM
    Borador
    Borador New Member
    Olive Branch, MS
    2016 Crewmax 4x4 w/1794 Interior upgrade
    I was actually thinking the exact same thing yesterday as I was enjoying the cooler weather with my rear window down. I logged into the forum and saw this post.
    Rebel Tundra Man and biebs96 like this.
  21. Nov 7, 2019 at 6:45 AM
    Roman
    Roman
    Franklin, TN
    Possibly. I'd have to order in both switches and test them out first. First, I have to find a model that has a back lit switch. I was thinking the Land Cruiser, but we don't have any Land Cruisers in inventory. :(
    bmann7[QUOTED] likes this.
  22. Nov 7, 2019 at 6:49 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    That's fine that you don't use yours. But those of us on here looking for information on relocation do, and we're looking for options.
    bmcdds and Rebel Tundra Man like this.
  23. Nov 7, 2019 at 6:50 AM
    bmann7
    WA
    See signature line
    Let me know if I can help - I'm sure many of us would be interested to figure out a solution for this. Thanks Roman!
    Roman[QUOTED] likes this.
  24. Nov 7, 2019 at 6:53 AM
    Loved it on the right when I briefly had my '13, wasn't crazy bout it being on left with all other switches, but I got used to it, no biggie for me
    Boerseun and BravoDeltaRomeo like this.
  25. Nov 7, 2019 at 7:28 AM
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    I think it is from a Prius and is a slightly different color, greenish tint.
    Pudge[QUOTED] likes this.
  26. Nov 7, 2019 at 7:31 AM
    jtwags
    League City, TX
    2018 Tundra CM
  27. Nov 7, 2019 at 8:12 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    good thing you eventually found the switch!
    :help:
  28. Nov 7, 2019 at 8:31 AM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Sorry to break peoples hearts and hate to be the bearer of bad news but I don’t “believe” there is a single switch Toyota makes that will fix this issue. I spent a few full days at work (I know... bad employee) going over numerous platform wiring diagrams and researching every illuminated switch Toyota makes to see if it’ll work.. the tundras are the only platform I found that uses a CAN system for the mirrors... even the 2019 land cruisers don’t use the can system. Pretty disheartening after all the research.. I thought for sure the newer models LCs or LXs would have it.. nope. I could (and hope) I’m wrong, but figured I’d save some people a whole bunch of time. That being said, I’m hopeful Toyota will shift future vehicles over to this system and hopefully grab a switch of a 2022 LC or something.
    there is one post where a guy bought an illumated switch and essentially used the clear piece and put that on our switch and added tiny leds. It’s a lot of work and not PNP, plus an increased risk of electrical fire. You can go that route but I wouldn’t. Anyway, just my $.02 on the topic.
  29. Nov 7, 2019 at 9:03 AM
    00Tyler10
    00Tyler10 WETT Expeditions
    Tyler
    Bowling Green, Ky
    2020 MGM Tundra Plat 4x4
    PTM Mirror Caps Spray in Bed Liner Window Tint XD Buck 20x9 Wheels 275/65/20 BFG K02s Bamf 10" exhaust
    Really? I have that thing down EVERY time it's nice out. It is one of my favorite Toyota features. Same goes when I'm in my Bronco!
  30. Nov 7, 2019 at 9:06 AM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    I was just messing around with you guys. I have horrible tinnitus and drive with the windows up year round can't stand the noise
