Rear wheel hop, traction bar ideas?
Discussion in 'Performance and Tuning' started by Nailgun, Dec 14, 2019.
  1. Dec 14, 2019 at 7:50 AM
    Nailgun
    Nailgun [OP] New Member
    2016 black Tundra TRD
    TRD sway bars “3 lift, rear air bags, bumpers/winch, TRD exhaust- air intake
    I installed sway bar hoping that might cure wheel hop, sway bar did help pulling 10k lbs 5th wheel
  2. Dec 18, 2019 at 10:26 AM
    swank501
    swank501 New Member
    2007 single cab 4x4
    TRD S/C Crewmax window conversion Auburn LSD Custom interior
    I knocked off the cal-trac design for about $100 all in. No more wheel hop
    Nailgun[OP] likes this.
  3. Dec 20, 2019 at 4:23 PM
    awq735
    awq735 New Member
    Anthony
    Ohio
    2019 Tundra Sport, MGM
    When you are getting wheel hop do you have all of the nannies on or off? The auto lsd and traction control can wreak havoc on solid launches and burn outs.
  4. Dec 20, 2019 at 4:26 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I hung the leaf packs under my axle... wheel hop & axle wrap went away.
  5. Dec 23, 2019 at 10:36 PM
    Nailgun
    They’re off, axle wraps anywhere, I carry at least 600lbs. of tools/shell all the time. I’m thinking complete leaf spring replacement is in order
    awq735[QUOTED] likes this.
  6. Dec 24, 2019 at 3:22 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    We have the same setup and but I might be carrying a few hundred pounds over yours. My rear is Bilstein 5100, TRD swaybar, Firestone Air Rite 35psi, 10ply tires 40-45psi. My '16 had OEM shocks and Air lift 35psi with no rear swaybar 44psi tire preasure. I always make my air springs softer than the tires. I may upgrade to a better rear shocks due to the payload I carry. The 5100 rebound is not tuned for airbags in my opinion, but way better than the OEM. I might go with the 5160 at first. Or find a larger diameter piston shocks.
