Rear view Mirror
Discussion in '3rd Gen Tundras (2022+)' started by gametracker, May 23, 2022.
  1. May 23, 2022 at 9:15 PM
    gametracker
    gametracker [OP] New Member
    neil
    2022 Supersonic Red
    I have a SR% that came with the most basic rear view mirror. I want to add a Gentex auto dimming mirror but wondering if the connector is already there or will I need to run power to it from somewhere else.
    Thanks
  2. May 24, 2022 at 6:40 AM
    Tumbler
    Tumbler New Member
    2023 CrewMax Limited HV in MGM
    In some cases optional connectors are left in and hidden but I doubt they would leave one up in the headliner, potential for rattle right above your head. You will most likely need to run power up there from another location.
  3. May 30, 2022 at 9:03 PM
    omglas3r
    omglas3r Member
    There may be existing connectors. I added the rear view mirror with home link on my order via the dealer, of course whomever (port or dealer) installs it may just splice not sure if it’s auto dimming or not.
  4. May 30, 2022 at 9:52 PM
    docfnky
    docfnky New Member
  5. May 31, 2022 at 5:24 AM
    Buellride
    Buellride New Member
    Olympia
    THE BOULDER
    BD Lights, Banks PM, Fuel Vector 18" on 295/70R18 Cooper AT3 XLTs, Black-Out badges, TRD front grill
  6. May 31, 2022 at 5:39 AM
    docfnky
    docfnky New Member
    The mounting points will work. Not sure if there is a connector for your model but it’s pretty simple to hookup with ground, constant and ign 12V.
  7. Jun 18, 2022 at 6:42 AM
    jfletch133
    jfletch133 New Member
    Wayne
    2022 Tundra SR5 TSS Offroad
    I have the SR5 also looking to do the auto dimming upgrade with homelink, Has anyone pulled the above head console out to see what's available as far as wiring?
    mrfreeman likes this.
  8. Jun 18, 2022 at 8:22 AM
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    There are 3 connectors above the overhead console, one of which is for the Dashcam. I have made adapters to convert the 12v to 5v with part numbers to connector and pins(wires). This connector provides constant power, ignition power, and ground. You'll find that info in the Dashcam threads within the 3rd Tundra forums.
    The other 2 connectors, I have no information on.
    There is mention in the thread of a connector in the shroud covering the electronics of the windshield, there is where you would find the mirror connector, I believe. Instructions on how to remove the shroud is also in one of the Dashcam threads.
    Good luck.
    Soupbean77 and aeroo777 like this.
  9. Jul 18, 2022 at 8:14 AM
    jfletch133
    Wayne
    Anyone make a plug and play harness for adding the Kia mirror to the tundra?
  10. Jul 18, 2022 at 10:02 AM
    omglas3r
    omglas3r Member
    Can confirm that the Accessory listed above is the Gentex Prism frameless mirror. It is battery operated with Homelink, does not have auto dimming.
    https://www.voxxelectronics.com/gentex/frameless-mirrors-homelink/
  11. Aug 1, 2022 at 2:42 PM
    jfletch133
    Wayne
    Ok ordered the Kia mirror as suggested. It does not fit if you have the windshield camera on 22 tundra. I have the SR5 with the camera and the boom on the aftermarket mirror is not long enough to adjust mirror. I did figure out there is a plug already there behind the overhead console. its the white plug to the left(drivers side) Pink wire is constant 12v, Green is ignition 12v and white is ground. Mirror worked fine just couldn't adjust it enough with camera system there.
    aeroo777 and paradizecityz like this.
  12. Aug 3, 2022 at 11:26 AM
    Maharisc
    Maharisc w/Patty
    Karl
    That connector you described is for the Toyota Ingrated DashCam, if you get that later, you'll need to change your set up. It also helps others if you have pictures of mirror during install and after.
  13. Aug 3, 2022 at 7:50 PM
    jfletch133
    Wayne
    2707EE27-9C27-4477-8563-E1A3D6C5A640.jpg Ordered a 1” spacer for the mirror. If it works I’ll post the pics I already took. I did tap the wires so the plug for the dash cam will still be available.
    aeroo777 likes this.
  14. Aug 3, 2022 at 7:50 PM
    jfletch133
    Wayne
  15. Aug 6, 2022 at 12:17 PM
    jfletch133
    Wayne
    I ordered a 1" spacer for the mirror mount and works perfect. I tapped into the this plug, Pink wire is constant12v (connect to black wire on mirror harness) Green wire is ignition switched 12v (connect Black &white wire on mirror harness) The white wire is Ground ( connect ground)
    https://creativeaudio.net/genmm5/
    GrizzlyBall69, aeroo777 and SawF16 like this.
  16. Aug 6, 2022 at 3:24 PM
    Bobby
    Bobby New Member
    Bobby
    2022 Tundra SR5 TRD Off-road
    Ok. I have a 22 SR5 TRD OR premium. I don’t have the homelink mirror. You’re saying there is a plug I can tap into up there? So I can get rid of this 1999 basic mirror and get a homelink mirror? I don’t care if it dims. I just want the garage control. Lil ridiculous this doesn’t come standard in 2022.
  17. Aug 6, 2022 at 8:10 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    Are you in Canada? I checked out my TRD OR premium today and it has homelink and rear camera/screen in the mirror.
  18. Aug 6, 2022 at 8:24 PM
    Bobby
    Bobby New Member
    Bobby
    nope. Texas. You have to get the tech package or something with it.
  19. Aug 7, 2022 at 6:08 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    Alright. I didn't realize it was in another package. I thought it was part of the OR premium. Ya, you'd think for what these cost it would come standard on the truck.
  20. Aug 7, 2022 at 6:25 AM
    Bobby
    Bobby New Member
    Bobby
    I agree. I must say, I’m a little disappointed. These trucks should have some of these features cause they have been standard on other makes for years now. It’s been a while since I owned a Toyota. I forget they are always behind on the tech side. But come on, garage controls and driver seat memory presets should be standard. Especially at this price point. Hopefully I can figure out a way to put a homelink mirror or something in.
  21. Aug 7, 2022 at 6:48 PM
    DBWA
    DBWA New Member
    Dave
    2022 Tundra TRD Limited 6.5' Bed
    Anyone know if you can add the digital rear view mirror on a limited trim that came without it?
  22. Aug 8, 2022 at 6:02 AM
    jfletch133
    Wayne
    Yes the Kia (Gemtex)mirror has auto dimming compass and homelink. Had to add a 1” spacer and tapped in behind the overhead console. It works great. Read through this thread someone posted the mirror part number and I posted the spacer part needed along with pics and what wires go to what.
  23. Aug 21, 2022 at 11:56 PM
    jfletch133
    Wayne
  24. Aug 21, 2022 at 11:57 PM
    jfletch133
    Wayne
  25. Aug 22, 2022 at 7:48 AM
    Maharisc
    Maharisc w/Patty
    Karl
  26. Aug 22, 2022 at 9:38 AM
    Buellride
    Olympia
    THE BOULDER
    Huh, I would be interested in anyone experience installing that on a Tundra G3....
  27. Nov 2, 2022 at 7:04 PM
    aeroo777
    aeroo777 New Member
    2022 Tundra SR5 4x2 MGM
    @jfletch133 I just installed and it works great. However, my homelink buttons don’t light up at night. Do yours? Thanks for the info and pics!
  28. Nov 28, 2022 at 6:52 AM
    GrizzlyBall69
    GrizzlyBall69 New Member
    2023 Tundra SR5
    Looks like the spacer is more expensive than the mirror! I bought a cheap Broadway mirror on Amazon but I really want the auto dim function. I might try this out. Did the Kia mirror come with a connector or did you have to add one and if so, which one did you get? Thanks!
  29. Jan 15, 2025 at 6:13 PM
    RolandoPR
    RolandoPR New Member
    Rolando
    2016 Black Tundra SR DC
    Carplay Android radio.
    I tried this but ran into the issues, mainly my 2016 Tundra was not prewired. I tapped from the overhead exposed copper lines to get power (pardon my terrible soldering, my old RadioShack 15w iron lasted long enough to get this done before it broke, used hot glue to secure wires).Screenshot 2025-01-15 at 8.22.47 PM.png
    The mirror came out of an Infiniti Q50 it is a Gentex 453 with a 10-pin connector, but you only need three wires there is a video on YouTube of someone with a Kia using from the back of the mirror's bottom row rightmost pin (10) is +, middle pin (8) is -(ground), & leftmost pin (6) + switched. Some say you can use 3 as - (ground), also you do need about 8 inch long wires. Screenshot 2025-01-15 at 8.52.49 PM.png
    I got the mirror on eBay for $20 & wire for $13.
  30. Jan 15, 2025 at 10:26 PM
    rhinoj
    rhinoj New Member
    Joe
    2024 Tundra 1794 4X4
    Mud flaps, Truxedo X15 Tonneau cover, AVS hood shield, AVS Vent Visors
    If anyone needs a Genres mirror, PM me. I have two in excellent condition at a very good price. They both have Home link and compass.
