Rear view mirror and garage door opener??
Discussion in 'General Tundra Discussion' started by offshore2005, Apr 22, 2018.
  1. Apr 22, 2018 at 3:13 PM
    offshore2005
    offshore2005 [OP] New Member
    TEXAS
    2022 Tundra Limited 4x4 RC leveling kit and 295/65/20 Cooper STT PROs
    I have a question on how this works..
    I have a 2018 Tundra and have programed my mirror to open the garage door… My truck sits in the driveway and will not fin in the garage. If someone was to break in can they just hit the button and open the garage door? If so is there a way it will only work if the truck is started?
  2. Apr 22, 2018 at 3:14 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I have a 16 and it does work with the truck off. As far as turning it off, not that I know of. Maybe someone else will chime in....
  3. Apr 22, 2018 at 3:16 PM
    offshore2005
    TEXAS
    Ok... Thanks I am sitting offshore and she just asked me.. I will have to try it when I get home..
  4. Apr 22, 2018 at 3:20 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    You can delete and resave when you get back.
  5. Apr 22, 2018 at 3:26 PM
    offshore2005
    TEXAS
    why would I need to delete and save it again?
  6. Apr 22, 2018 at 3:28 PM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    There's usually a lock feature on the main opener controls inside your garage, but you just have to remember to turn it on and off.
  7. Apr 22, 2018 at 3:29 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Are you referring to the opener or the remote?
  8. Apr 22, 2018 at 3:35 PM
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    The switch/panel inside your garage that you'd use to open the door normally from the inside. I guess it depends on how old your door opener is, but most built within the last 10-15 years have it. It just keeps remotes from being able to open the door.
    nk1794 likes this.
  9. Apr 22, 2018 at 3:37 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I guess I need to update my opener then cause I don’t have this feature and worry someone could get. Into the garage through my vehicle.
    Then they’ll have access to the house but then again that’s what the alarm and guns are for, right?
  10. Apr 22, 2018 at 3:38 PM
    offshore2005
    TEXAS
    Bingo!!
  11. Apr 22, 2018 at 6:40 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    The mirror gets power all the time. You'd have to cut that wire and then run a new wire up to it from an ignition source.
  12. Apr 22, 2018 at 6:56 PM
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    Go to bobsmirrors.com explain what you want He made me a short jumper wire harness that goes between the mirror and the wire coming from the headliner. My homelink now only works with the ignition on.
    offshore2005[OP] likes this.
  13. Aug 22, 2019 at 11:09 AM
    DireWolf
    DireWolf The Dark Lord - Tundra Owner
    North East Florida
    2016 Dark Gray Tundra SR5 (MGM)
    none
    The point is moot, since most likely you leave the remote garage opener in the car to start with we all do. So if they break in and use the remote would that be any different than using the mirror to open it, what id suggest is to program a different button rather than the obvious first one to begin with. By the way I have a 2016 and have been unsuccessful in getting the mirror programming to work for me.
    Update, finally got it to work, I had to go to the garage door unit and press the learn button, it worked first time i tried, so all its good now. Thanks for the help.
  14. Aug 25, 2019 at 6:18 AM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    I have a key fob garage door opener for this reason
