Rear U-Bolts
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tondra, Nov 13, 2017.
  1. Nov 13, 2017 at 5:18 PM
    Tondra
    Tondra [OP] New Member
    2018 Magnetic Gray Metallic SR5
    Hey guys how much torque are the rear U-Bolts?
  2. Nov 13, 2017 at 6:00 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Believe it or not it's tough to find this spec for some reason. I looked up the u-bolt torque based on the various diameters of the many u-bolts out there, and came up with 85-90 ft lbs. If you've messed with the u-bolts, torque to spec after install and again after a few hundred miles driving. Hope this helps.
    040Tundra likes this.
  3. Nov 13, 2017 at 6:11 PM
    muisejt
    muisejt New Member
    2017 Sunset Bronze 1794 Edition 4x4
    Auburn LSD, TRD rear sway bar, LED interior lights, Weathertech floormats, Fumoto valve
  4. Nov 13, 2017 at 7:46 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
  5. Nov 13, 2017 at 8:02 PM
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    that's it??? when I got my deavers he told me torque them at 95...
  6. Dec 14, 2018 at 9:20 PM
    Rica25
    Ricardo
    Tulare
    What happens if over torqued to about 120 lbs.?
  7. Dec 14, 2018 at 10:59 PM
    15whtrd
    15whtrd Mr. Blonde
    They’re tight AF!
    Rica25[QUOTED] and plumber802 like this.
  8. Dec 15, 2018 at 12:26 AM
    Erick
    Erick New Member
    Erick
    Thornton Colorado.
    Bronze 2016 SR5 TRD. CM cab.
    HID lights, Duratracs, Bilstein 5100's, 2" Spacer, Sumo springs.
    The spacer kit I purchased said 95lbs. The u bolts are much thicker than stock
    15whtrd and Rica25 like this.
  9. Apr 12, 2020 at 12:42 PM
    SonnyAde
    SonnyAde New Member
    Arlington, TX
    KatSkinz Leather seats 2 1/2” Eibach Pro-Truck Lift kit 1” Wulf Rear Lift Blocks 18X9 XD Monster, 295X70X Nitto RG 1” BORA spacers 2018 Honeycomb Grill Tonneau G2 Cover K&N CAI 77 Series Pedal Commander MGP Red calipers 20% Window Tint Chrome Bumper delete Carven Exhausts
    Thanks
  10. Apr 12, 2020 at 12:57 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Not sure if you noticed, but this thread is over a year old.
    Here’s some information:
    If you are using new OEM U-bolts, that torque setting of 74lb would apply.
    You should never reuse ubolts, the threads are designed to stretch when torqued.
    If you have after market bolts, the Toyota spec is meaningless. Use the torque recommendation from the mfg.
    SonnyAde[QUOTED] likes this.
  11. Apr 13, 2020 at 5:48 AM
    SonnyAde
    SonnyAde New Member
    Arlington, TX
    Thanks, I used mfgr’s torque settings instead.
    gosolo[QUOTED] likes this.
  12. Dec 29, 2023 at 10:16 AM
    TRD_Ghost
    TRD_Ghost New Member
    17 Superwhite TRD Pro
    Helpful thread. Just backing them off to slip in some SumoSprings, considering replacing the bolts.
    gosolo likes this.
