Rear turn lights signal problem
Discussion in 'Lighting' started by Amam66, Dec 2, 2018.
  1. Dec 2, 2018 at 7:32 AM
    Amam66
    Amam66 [OP] New Member
    Abel
    2015 sr5
    anyone have ant troubles with rear turn lights not coming on when you turn lights on !! But they do work when I use hazard and left and right signals
  2. Dec 2, 2018 at 7:44 AM
    Amam66
    Abel
    2015 sr5
    Yes sir I did they are still intact and working the lights just don’t stay on only when hazard and turn signals are used
  3. Dec 2, 2018 at 7:48 AM
    Ya need blinker fluid
    JoshuaA likes this.
  4. Dec 2, 2018 at 8:24 AM
  5. Dec 2, 2018 at 9:44 AM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Did you install aftermarket LED lights or tail lights?
    Amam66[OP] likes this.
  6. Dec 2, 2018 at 10:47 AM
    Amam66
    Abel
    2015 sr5
    Yes that’s sounds right thanks for your response Ron I appreciate it
    NewImprovedRon likes this.
  7. Dec 2, 2018 at 10:48 AM
    Amam66
    Abel
    2015 sr5
    Dan yes sir I did I’m thinking it had something to do with it but I reinstalled new standard bulbs
  8. Dec 2, 2018 at 12:01 PM
    GiantsFanDan
    Replace fuses:
    7.5A IG-LH fuse under the dash
    15A TAIL fuse under the dash
    15A TURN-HAZ fuse under the hood
    The Tundra uses mini fuses if you don't have and spares. Check your other lights too. It will probably tell more to the story. Like your fog lights, parking lights, and license plate lights.
  9. Dec 2, 2018 at 1:31 PM
    Amam66
    Abel
    2015 sr5
    Dan thank you sir I will do it thanks so much for your help
    GiantsFanDan likes this.
