Rear TRD Sway Bar with Roadmaster Active Suspension?
Discussion in '2.5 Gen Tundras (2014-2021)' started by FlightMedicRN, Apr 14, 2021.
  1. Apr 14, 2021 at 8:56 AM
    FlightMedicRN
    FlightMedicRN [OP] New Member
    2020 Super White Crew Max- TSS SR5
    Interior chrome delete- AJT Designs, S&B Cold air intake, 10" BAMuffler exhaust system, color-keyed bumper covers, LED fog lights, TuffSkins interior inserts, black exhaust tail pipe and tip, Peragon tonneau cover.
    Hey all, this past weekend I installed the Roadmaster HD Active suspension and my questions are this: Does anyone out there have the Roadmaster suspension on their Tundra and if so, do think the TRD rear sway bar would make a significant difference if installed also?
    The reason I ask is Roadmaster advertises that among other things, their product improves rear sway (pic attached) when installed so I really don't want to waste money on something that really won't do much but add additional weight.
    bulldog93 and ATHiker like this.
  2. Apr 14, 2021 at 8:58 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    I got RAS put on too, but haven't driven it yet since I'm re-gearing at the same time, should be wrapped up this week, I'll report back on the differences on feel.
    FlightMedicRN[OP] likes this.
  3. Apr 14, 2021 at 10:45 AM
    lakedrum03
    lakedrum03 New Member
    Seth
    2021 Tundra Platinum
    Working on it.
    Cant wait to see these results. I am also considering doing the RAS.
    ATHiker and FlightMedicRN[OP] like this.
  4. Apr 14, 2021 at 11:11 AM
    art64
    art64 New Member
    Yes, with the addition of rear sway bar, it will make a big difference in reducing body roll. I have RAS installed on my 2010 Crewmax 4x4 right now. No sway bar though. On my previous 2007 Tundra RCSB, I had both installed. Great for highway stability specially with heavy loads, but not on trails.
    I have also installed Firestone airbags with the ras and it's even better. You can vary the ride height and the ras keeps the rear suspension tight.
    Rex Kramer and FlightMedicRN[OP] like this.
  5. Apr 14, 2021 at 11:23 AM
    FlightMedicRN
    I haven't towed our camper since installing the RAS yet, but I've noticed improved handling/ responsiveness unloaded so far this week. Tundra not as bouncy on bumps and the rear suspension just feels "tighter" in a good way. I do have the RAS springs dialed up to the black setting which is supposed to be 40% more support and the back end sits up at least an inch higher after install. I didn't think of measuring before and after install. I also removed the Sumo Springs I had on the Tundra and installed them on my Tacoma.
    I just don't want to waste money and added weight by installing the rear sway bar if there is no need for it if the RAS already provides that benefit....
  6. Apr 15, 2021 at 5:30 AM
    lakedrum03
    Seth
    Working on it.
    I have zero experience with either product on the Tundra, but just thinking out loud: The sway bar links the sides of the vehicle so that if something happens to one side, then the reaction is transferred to the other side. That is something that the RAS doesn't have, but since the RAS increases the spring rates, it would have a similar "feeling" at the rear end. I would think this feeling would be similar to independent airbags on the rear.
    Again, no experience, no expertise, just my $0.02.
  7. Apr 15, 2021 at 6:10 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I had the RAS and a Hellwig on my 2002 17 or 18 years ago, and they worked well together. I removed the RAS for two reasons: 1. the bed was jacked up when empty and not towing a trailer. 2. I stopped hauling & towing heavy loads.
    I think it's a great combo if you carry a heavy load in the bed full time.
  8. Apr 15, 2021 at 6:30 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Can you elaborate on the not good on trails part, I would assume less flex and less traction but I'd like to hear your experience.
    art64[QUOTED] likes this.
  9. Apr 15, 2021 at 6:30 AM
    FlightMedicRN
    Gotcha, yes the bed sits at least an inch higher after installing the RAS but it’s not a big deal for me as we do a lot of towing with a camper. I also may eventually replace the shocks with Bilstein 5100’s to give the front end a bit of a lift to even out the rake....Appreciate your insight, maybe the rear sway bar is in the cards in the future....
    Rex Kramer[QUOTED] likes this.
  10. Apr 15, 2021 at 10:47 AM
    art64
    art64 New Member
    Yes. Less flex resulting on one tire lifting off the ground. So now, you only have one rear tire doing the pushing. But the rear sway bar is easy to disconnect on the linkage and just tie them up with a bungee cord to keep them up against the frame. You can do the same thing with the sway bar so the ends won't point down.
  11. Apr 15, 2021 at 11:13 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Yeah that's typical with sway bars. I thought you meant the RAS was hindering the suspension off road.
  12. Apr 20, 2021 at 1:09 PM
    lakedrum03
    Seth
    Working on it.
    @Downytide any good news on the new set up?
  13. Apr 20, 2021 at 5:27 PM
    Downytide
    GTA
    Playing the beautiful game of waiting, dealership is trying to fix the fluctuating idle issue right now.
  14. Apr 24, 2021 at 12:16 PM
    Downytide
    GTA
    Got the truck back.
    Rear definitely sits bit higher, firmer on rough roads but I can't really tell the difference if it made the rear firmer or not, and yes it did stabilized the rear during turns with and without load.
    TunBrun and FlightMedicRN[OP] like this.
  15. May 10, 2021 at 3:00 PM
    mdrabicki
    mdrabicki New Member
    Mark
    2020 Toyota Tundra TRD PRO
    I just Installed the Roadmaster suspension on my 2020 TRD Pro last weekend and initially set it to roughly 30% using those 2 spacers as a guide. I noticed as you increase the tension on the spring it does incrementally raise your rear end up by pulling the leaf springs up. I then lowered to a bit less than 20% (white 20% spacer could no longer fit in between the RAS spring coils) and my rear sat about level. I left it there as a test and loaded 2000lbs of stall mats into the rear and there was noticeably less sag than without and it drove on the highway at 80mpg more confidently than without the RAS. Less rear end sway and bounce.
    I am running this setup with both TRD front and rear sway bars just because I already had them installed and there was no interference so I can not tell you how the RAS rides without the rear sway bar.
    bulldog93, diablodalton and TunBrun like this.
  16. May 10, 2021 at 4:06 PM
    Bulldog9
    Bulldog9 "My other car is a Porsche"
    NOVA
    2017 TRD PRO in Cement
    see sig for mods.....
    I've got both, had the Road Master for a year before the TRD Sway Bar. The Road Masters helped with stability and some with sway, but the sway bar really dialed it in. Immediate difference.
    You can adjust the Road Master assist level, the minimum setting is about a dime, the standard is a quarter, and max is about 2 quarters (Fit between the coil springs). Takes 20 minutes to adjust. Just lift the rear so the tires are off the ground, loosen the lock nuts and tighten or loosed the spring preload tension.
    diablodalton, AggiePhil and mdrabicki like this.
  17. Nov 7, 2021 at 11:50 PM
    diablodalton
    diablodalton New Member
    Dalton
    Oregon
    2021 Crewmax Platinum MGM
    8" Ready Lift, SPC UCA's., Bilstein B8 8125, Amp Steps, 37/12.5R 20 Cooper STT PRO, On order: Valhalla Armor, Dirty Deeds Exhaust
    Do you have pics on this set up? I’m worried about the two not working together, i.e. interference with the RAS.
  18. Nov 8, 2021 at 4:39 AM
    Bulldog9
    NOVA
    No issues, I have had both for a couple years.
  19. Nov 8, 2021 at 4:42 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Turns out the TRD sway bar won't fit with my RTX leaf kit so ill be running the stock sway bar with the roadmaster kit when I eventually install it.
  20. Nov 8, 2021 at 4:45 AM
    Bulldog9
    NOVA
    What stock sway bar?
  21. Nov 8, 2021 at 5:07 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Stock front sway and rear roadmaster will be my setup eventually. Currently only running stock sway bar on the front of the truck.
  22. Nov 8, 2021 at 3:19 PM
    Bulldog9
    NOVA
    OK, I thought you were saying there was a stock rear bar.
    I put the Road Master right when I bought the truck, I use them on any leaf spring vehicle. They add stability and settle the rear axle, make the truck feel better planted as well as reducing sag with a load. They also help some with handling and sway control. I had them on for about 2 years, and then added the rear TRD bar, which was immediately noticeable. The Truck handles and corners much flatter. Highly recommend both.
  23. Nov 8, 2021 at 3:52 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I wish there was a way to make it work with my leaf kit but it doesn't look like it will.
  24. Nov 9, 2021 at 3:29 PM
    Bulldog9
    NOVA
    I'm assuming the leafs are wider than the stock? They may have other kits that the shackle can fit.
  25. Nov 9, 2021 at 5:24 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Yeah, I'm looking at other options.
  26. Dec 4, 2021 at 7:13 PM
    What leaf springs do you have?
  27. Dec 4, 2021 at 7:26 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Icon RTX with the add a leaf installed. From what I've been told they are too wide to fit a sway bar.
  28. Jan 21, 2023 at 12:13 PM
    WillTunBlack20
    WillTunBlack20 New Member
    William
    Houston, Tx.
    2020 Tundra TRD PRO Midnight Black
    Grille Lights, Bumper Lights, Front Facing Camera, Interior Upgrade, Leer Topper
    2020 Tundra TRD PRO, got a call from a friend, he had space in the shop, so it was time for the installation RAS, Front and Rear Sway bars, took about 4 hours, with a hour for lunch, and admiring our work, we removed the spare, just in case extra room was needed, Thank to @RainMan_PNW, for your pictures, and to @SparkParts, sway bars arrived on time, and were packaged well, installation was awesome.
    bulldog93 and batman900 like this.
  29. Jan 28, 2023 at 4:45 PM
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    How does the ride compare to the stock ride? I have a limited and have the FOX pro Suspension that will be installed this spring (Hopefully) and also thinking he RAS may be needed since I pull a 3000#+/- trailer occasionally.
  30. Jan 28, 2023 at 5:20 PM
    WillTunBlack20
    William
    Houston, Tx.
    @Bergy24, it seems as though, I have better control, I will be pulling a trailer, with family aboard, in a parade, so this was a great time to install, doing both was a plus, suspension upgrade completed
    Bergy24 likes this.
