Rear Sway bar
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sixpack, Oct 3, 2016.
  1. Oct 3, 2016 at 4:00 AM
    Sixpack
    Sixpack [OP] New Member
    Central Florida
    2014 Silver Sky Tundra CM TRD 4x4 Limited
    Moto Metal 951 18x9 rims with 285x75x18 Nitto Terra Grapplers , ESP lockable under seat storage, Husky mats front and rear, ReadyLift 3/1, Undercover Flex trifold bed cover, Bed Rug, interior LED's, 15% tint all around, TRD CAI, Bully Dog Platinum GT tuner, TRD rear sway bar, Flowmaster Series 44 dual exhaust system, LED head lights and Fog lights, 32" LED light bar in lower bumper cover, Switchback running lights, much more to come...
    Asking for pros and cons to adding the rear sway bar to my 14 CrewMax. I have the opportunity00505_cNvS5PmtLlb_600x450.jpg 00h0h_bvLS06aZTrg_600x450.jpg to pick one up cheap. Thanks in advance for your opinions & advice...
  2. Oct 3, 2016 at 5:01 AM
    15whtrd
    15whtrd Mr. Blonde
    The rear won't articulate as much for off-roading , but the on the street manors is a night and day difference.
    Krezz, Sixpack[OP] and NewImprovedRon like this.
  3. Oct 3, 2016 at 5:01 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    + should have more stability while cornering and towing, less body roll
    - less articulation while off roading, when the suspension on one rear wheel is compressed, it will also compress the other side. I believe someone one here was trying to come up with a quick disconnect to temporarily disable the sway bar when going off road. Not sure what the outcome was...
    I think someone one here said they were having problems with bed bounce after install, but I would imagine that has a lot to do with their current suspension setup and weight distribution.
    Sixpack[OP] likes this.
  4. Oct 3, 2016 at 7:21 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    I'm in the same boat, thinking of getting one. I don't do any off roading, all street.
    ChucklesToy and Sixpack[OP] like this.
  5. Oct 3, 2016 at 2:03 PM
    Sixpack
    Central Florida
    Same here 99.9% on the streets. 4x4 gets me off some slimey boat ramps here in Fla...
  6. Oct 3, 2016 at 2:05 PM
    AxelsHumanDad
    AxelsHumanDad Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    I love mine. My girlfriend hates it since she gets pinned to the door or console when I corner now :rofl: Guess that what the passenger side "oh shit" handle is for!
  7. Oct 3, 2016 at 3:56 PM
    bandit
    bandit New Member
    2011 Supercharged Mazzulla Long Travel Rock Warrior
    Duh Tundra
    A sway bar will not limit or reduce the amount of articulation in the rear. It will only slow down the rate at which it happens. Do it. If you plan on driving on the street more than dirt and don't have intent of going long travel it works extremely well. I removed mine because i'm LT.
  8. Oct 3, 2016 at 10:28 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Thanks, that info kinda took me by surprise. I've seen your truck. I'm guessing you know a lot more about suspension than I do..ha ha.
    bandit[QUOTED] likes this.
  9. Oct 3, 2016 at 10:35 PM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    Been using one for about a month now and have noticed a huge different right away. Primarily just normal drive, road and such, so no thought to off-road affects. My wife who doesn't give a whoop about vehicles also noticed the handling on our first drive out once it was added. I give it a :thumbsup:
  10. Oct 3, 2016 at 11:59 PM
    bandit
    bandit New Member
    Duh Tundra
    Enjoy your sway bar, it adds about 5mph of confidence in the corners lol. Mine is still sitting in storage trying to find itself a good use lol.
  11. Oct 4, 2016 at 5:19 AM
    Very good point.
  12. Oct 20, 2016 at 6:10 PM
    polox40
    polox40 New Member
    2016 DC Limited
    LineX Toyota black running boards
    Get worth it! if you a road warrior like me.
  13. Oct 20, 2016 at 7:00 PM
    Inferno16
    Inferno16 New Member
    Will this fit if you have a lift kit in rear with toytec shackles?
