Rear Sway Bar: OEM TRD vs Others?
Discussion in '2.5 Gen Tundras (2014-2021)' started by bmoreitdan, May 16, 2018.
  1. May 16, 2018 at 11:03 AM
    bmoreitdan
    bmoreitdan [OP] New Member
    2017 Black Tundra Limited
    None
    I want to add a rear sway bar to my stock 2017 Limited because I do a lot of towing. Wanted to know if any other non-OEM sway bars are better than the OEM TRD sway bar.
    Y0TA PR0 likes this.
  2. May 16, 2018 at 11:06 AM
    ToyotaTundraMike
    2015 Tundra
    The only other one I have seen is the Hellwig which is a gray color whereas the TRD is red. Both have good reviews, believe the hellwig one is a little beefier.
    I can vouch for the TRD one, big improvement from stock. Although now that I have gunmetal rims I really want the Hellwig one. May just powdercoat it along with the front one.
  3. May 16, 2018 at 11:12 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    WELCOME
  4. May 19, 2018 at 12:48 PM
    Paul84
    Paul84 New Member
    Paul
    2014 4x4 Crewmax
    I just put a a TRD rear sway bar on my 14 crewmax. It was a huge improvement and I’m happy I did it. I have a 4wheel camper that stays on full time so I imagine that i would like it even more without the weight on the back.
  5. May 19, 2018 at 1:05 PM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    When I was shopping/researching swaybars, I chose the Hellwig over TRD's model. Paid nearly the same price for a thicker bar that isn't RED. Well pleased so far.
