Rear sway bar for lifted tundra
Discussion in 'New Member Introductions' started by Knoyes, Nov 14, 2018.
  1. Nov 14, 2018 at 7:07 PM
    Knoyes
    Knoyes [OP] New Member
    Karl
    MD
    2010 tundra
    RC 3.5 lift, 35x12.5, Fuel rims,
    I have a 3.5 inch lift on my 2010 tundra and want to add a rear sway bar.
    Will a TRD rear sway bar work on a lifted truck?
    If not can you reccomend another product?
    OR18TRD, Pinay and T-Rex266 like this.
  2. Nov 14, 2018 at 7:09 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Itll work, you need to mount it toward the back of the axle instead of below it, works with stock mounts.
    Helwig makes one as well that's made for lifted trucks but it's much more expensive. The trd will work without any modification
  3. Nov 14, 2018 at 7:25 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Good advise Pudge.
    Pinay and Pudge[QUOTED] like this.
  4. Nov 14, 2018 at 7:28 PM
    Knoyes
    Karl
    MD
    2010 tundra
    Awesome! Thanks.
    Pinay likes this.
  5. Nov 14, 2018 at 7:28 PM
    You can buy a Hellwig sway bar for a lifted truck. I have one and works great.
    Pinay likes this.
  6. Nov 14, 2018 at 7:29 PM
    Welcome from Ohio!
    Pinay likes this.
  7. Nov 14, 2018 at 7:30 PM
    Welcome
  8. Nov 14, 2018 at 7:34 PM
    Welcome from Texas, yes the TRD one will work, also Hellwig makes a beefier one with adjustable links
    Tundra_361 likes this.
  9. Nov 14, 2018 at 7:35 PM
  10. Nov 14, 2018 at 7:41 PM
    scotch
    scotch New Member
    Denver, CO
    2010 Tundra
    2010 Tundra Method 20x9 Fat Fives 18offset, 305/55/20 Duratracs, Bilstein 6112/5160, SPC/LR Upper Control Arms, TRD Rear Swaybar, OME/Dakar leafs with CB +1 Shackles, Husky Weatherbeaters, Du-Ha, Extang Solid Fold, Line-X, Toyota Bed Mat, Stoptech Cryo Rotors and pads, Goodridge brake lines, Stoptech STR-660, Rigid Fog Lights, Odyssey Battery, Firestone Airbags with CB spacer, etc, etc... Previous Toyota's: 97 4runner, 02 tacoma, 09 tacoma
    this is what I did with trd swaybar, ome/dakar springs, and coachbuilder shackles (3.5" lift)
  11. Nov 14, 2018 at 7:42 PM
    trdprobped17
    trdprobped17 New Member
    It worked on my 4” lift.
  12. Dec 27, 2018 at 4:00 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :wave: Hiya and welcome from SoCalif!!!
  13. Dec 27, 2018 at 4:43 PM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    Welcome from Ct
    Pinay likes this.
  14. Jan 5, 2019 at 5:51 PM
    Knoyes
    Karl
    MD
    2010 tundra
    New rear sway bar installed! Great investment
    WolfPac_Outdoors, OR18TRD and Pinay like this.
  15. Jan 5, 2019 at 5:57 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Reported
  16. Jan 5, 2019 at 5:58 PM
    Adriver71x
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    Welcome from Northeast Connecticut
  17. Jan 5, 2019 at 6:01 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    OR18TRD[QUOTED] likes this.
  18. Feb 10, 2019 at 2:59 PM
    Cement
    Cement ...
    2019 Cement Trundra TRD
    Anything ever come of the quick disconnect idea? I'd be interested in seeing how it was done up front and in the rear...
  19. Feb 10, 2019 at 3:10 PM
    Knoyes
    Karl
    MD
    2010 tundra
    I have a 4 inch lift. The sway bar improves the handling. I would buy it again. No reason to disconnect for me.
    Prostar 190 likes this.
  20. Jan 22, 2025 at 3:27 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    reviving this old thread. is there any performance-related reason to mount to the back of the axle as opposed to the bottom? other than clearance when it's mounted to the bottom. i'm picking one up tomorrow, probably install it this weekend
  21. Jan 22, 2025 at 8:20 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
