Rear suspension
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Badge618, Jan 9, 2022.
  1. Jan 9, 2022 at 6:06 PM
    Badge618
    Badge618 [OP] New Member
    Lassen County, Ca
    2019 TRD Pro Voodoo Blue
    I bought my pro with a lift already installed. Blocks in the rear. Going to switch to coachbuilder shackles. Is the stock rear suspension just the leaf springs?
  2. Jan 9, 2022 at 6:11 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Not sure what you are asking but the rear suspension is leafs, shocks and shackle.
  3. Jan 9, 2022 at 6:14 PM
    Badge618
    Lassen County, Ca
    That's what I needed to know. Didn't know if there was a wedge or anything weird that would have been removed when the block was installed. Have the coachbuilder +3 shackles and new u-bolts ready to go in.
  4. Jan 9, 2022 at 6:15 PM
    Which Coachbuilders are you going with because you could end up with less lift than what the block is providing. What size is the block?
  5. Jan 9, 2022 at 6:16 PM
    Badge618
    Lassen County, Ca
    +3 replacing 2" block
  6. Jan 9, 2022 at 6:18 PM
    Ok. The +3 will give you 1.75 of lift. You probably won't notice the 1/4 inch difference.
    Badge618[QUOTED][OP] likes this.
