Rear Suspension Slams
Discussion in '2.5 Gen Tundras (2014-2021)' started by Engineer4038, Feb 22, 2021.
  1. Feb 22, 2021 at 1:50 PM
    Engineer4038
    Engineer4038 [OP] New Member
    2017 Tundra SR5 CM 4x4
    Toytec 3” Lift
    I bought my 2017 SR5 Crewmax Tundra earlier this month for my birthday. It came with a Toytec 3” (what I assume) lift kit with the metal spacers for the front and the blocks for the rear. Truck has stock shocks on front and rear. Any time a hit a large bump, the rear suspension feels like it’s slamming down hard even though it’s soft going over. Small bumps in the road are smooth to go over. Any ideas?
  2. Feb 22, 2021 at 2:50 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Shocks are done...
    Elduder likes this.
  3. Feb 22, 2021 at 2:55 PM
    Elduder
    Elduder New Member
    Either the shocks are done and you have no dampening, hitting the bump stops. Or, the shocks are maxed out and youre topping out and theyre clunking.
  4. Feb 22, 2021 at 3:26 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    ^^^ This. Shocks are over extending.
    frichco228 likes this.
  5. Feb 22, 2021 at 3:28 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Welcome to the forum. You have posted in the General section. There are subforums by topic to cover specific issues, questions, comments ect..
    Try looking and posting here for your suspension needs. https://www.tundras.com/forums/suspension.19/
    Sorry to hear about your rear shocks and good luck fixing the issue.:thumbsup:
  6. Feb 22, 2021 at 3:48 PM
    Elduder
    Elduder New Member
    Yeah I just reread the original post and seeing as he is running OEM shocks, I would go with that.
  7. Feb 22, 2021 at 4:06 PM
    Engineer4038
    Toytec 3” Lift
    Thanks y’all for the help. Since stock shocks are not the correct size, would I need to upgrade the rears to height adjustable ones like RC and Bilstein?
  8. Feb 23, 2021 at 7:36 AM
    crewmaxlmt
    scott
    Yes. All of the kits that I had looked at came with longer shocks, or shock extensions, even if a small rear block was used in the rear.
