Rear suspension advice
Discussion in 'Suspension' started by MR9160, May 31, 2024.
  1. May 31, 2024 at 2:55 PM
    MR9160
    MR9160 [OP] New Member
    2021 TRD OFF-ROAD
    I am in the process of lifting (3/1) my '21 TRD off road crewmax. I have spent countless hours reading on these forums and there are so many different opinions and options. I spend about 90% of the time driving my truck on city roads. The rest is northern AZ forest service roads. I'd like a smoother ride than stock around the city and also washboard roads up north. I rarely tow. I am going to go coilover/UCA in the front, but I wanted to ask what setups you guys are running in the rear between AAL kits and aftermarket shocks etc. and how you like them compared to stock. I am looking to avoid a block in the rear.
    Thanks in advance :cheers:
  2. May 31, 2024 at 3:06 PM
    skylinekin
    skylinekin New Member
    Michigan
    2021 Tundra DC TRD PRO (Current), 2014 Tundra SR5 DC TRD OR (Sold)
    You can achieve that rear lift with the RAS suspension enhancement which will also improve your hauling and towing capability, just a consideration!
  3. May 31, 2024 at 4:25 PM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Second vote for RAS.
  4. May 31, 2024 at 4:41 PM
    MR9160
    2021 TRD OFF-ROAD
    Thanks fellas. I’ll do some research on the RAS. I see the warranty is voided if any aftermarket leaf work is done. Anyone running RAS with 1” of rear lift? Website doesn’t mention it…
